[SENSE KERNEL] 2.6.32.27 (BFS/BFQ/SLQB/HAVS/OC1190Mhz/EXT4/CIFS/TUN/AUFS)
Gast5050
Gast
I forked LeeDroid v2.2f, so we have all usual patches (GPU, SDFix etc), kernel is then patched it up to 2.6.32.27.
BFS363,
BFQ enabled
SLQB slab allocator enabled
Sibere charging fix applied (thanks to sibere)
HAVS@875mV and 925mV (Thanks to Richard Trip)
vorkKernel compiler optimisations. (Thanks to benee)
Camera Overclock (Thanks to Cyanogen!)
Various Cyanogenmod patches (Thanks to Cyanongen for the fantastic job they do!)
**DISCLAIMER**** I don't take any responsibility for any damage this kernel may cause to your device.
Only use this if you have a Sense ROM (no defrost/cyanogenmod/AOSPDesire/opendesire/). It works great with the new HD roms.
Download at http://mirror.couttstech.com/android...Sense%2FBFS%2F
DO NOT GO POKING ABOUT IN SUB FOLDERS OR DOWNLOADING ANYTHING WITH TEST IN THE NAME
"couttstech-2.6.32.28_OC1190_HAVS@875mV_BFS_BFQ.zip"
"couttstech-2.6.32.28_OC1190_HAVS@925mV_BFS_BFQ.zip"
"couttstech-2.6.32.28_OC1190_BFS_BFQ.zip"
CFS versions download at http://mirror.couttstech.com/android...Sense%2FCFS%2F-:
"couttstech-2.6.32.28_OC1190_HAVS@875mV_CFS_BFQ.zip"
"couttstech-2.6.32.28_OC1190_HAVS@925mV_CFS_BFQ.zip"
"couttstech-2.6.32.28_OC1190_CFS_BFQ.zip"
Please visit the sponsors and help pay for bandwidth!
Source -
git://git.couttstech.com/couttstech-bravo.git
***CHANGES
24 - Nov - 2010 - Changed from SLAB to SLUB
24 - Nov - 2010 - Latest HTC kernel updates patched (Thanks to ziggys kernel for this patch)
25 - Nov - 2010 - Added 128MHz as requested
27 - Nov - 2010 - Audiomod added to BFS kernels
05 - Dec - 2010 - Removed OC1113 kernels
05 - Dec - 2010 - Added camera overclock patch ( http://review.cyanogenmod.com/#change,35 )
05 - Dec - 2010 - Various cyanogen patches applied see git log for details
05 - Dec - 2010 - Change from SLUB to SLQB slab allocator
06 - Dec - 2010 - Change to ondemand by default (initial testing showing better battery life with HAVS, thanks melethron)
07 - Dec - 2010 - HAVS SetCPU clock speed out by one step issue fixed.
09 - Dec - 2010 - Changed Audio min gain for handset and headset
10 - Dec - 2010 - Added AUFS module
14 - Dec - 2010 - Patched to 2.6.32.27
16 - Dec - 2010 - BFS patched to version 360
17 - Dec - 2010 - Charging on lock screen fix included (many thanks to snq-)
23 - Dec - 2010 - Headset max gain lowered, also video compiled into kernel instead of being modules
01 - Jan - 2011 - BFS updated to v363
06 - Jan - 2011 - Full ck2 patch set applied (for BFS kernels)
09 - Jan - 2011 - Car dock working
09 - Jan - 2011 - Revert to stock battery driver
09 - Jan - 2011 - Sibere battery fix applied
09 - Jan - 2011 - Patched to 2.6.32.28
09 - Jan - 2011 - Reiserfs enabled
09 - Jan - 2011 - CFS builds added
10 - Jan - 2011 - CGROUPS sorted on CFS builds
11 - Jan - 2011 - Voltages raised for higher freq on SVS versions, should be stable for all now
14 - Jan - 2011 - Revert ck2 patch set for BFS kernels
Full changelog -:
http://git.couttstech.com/?p=couttst....git;a=summary
IRC - irc.freenode.net - #coutts99
Quelle:
[SENSE KERNEL] 2.6.32.27 (BFS/BFQ/SLQB/HAVS/OC1190Mhz/EXT4/CIFS/TUN/AUFS) - xda-developers
Reaktionen: blackmail und BO4573
cargo schrieb:
Mit welcher Version hast es den Probiert? Ich bin grad am flashen, mit einer leicht für mich geänderten Version3.:)
Grüße cargo
Version 2. Gib mal kurz bescheid wie er bei dir läuft.
Grüße
Grüße
Hallo, welche Version des Kernels hast geflasht?
EDIT//
Diese Version hab ich grade geflasht: couttstech-2.6.32.27_OC1190_HAVS@875mV_CMBattFix_BFS_BFQ.zip:D:D
Ohne Probleme! Das Desire ist sofort gestartet ohne Fehlermeldung oder Bootloops.
EDIT2//
Hab gerade die zweite Version hinterher geflasht: couttstech-2.6.32.27_OC1190_HAVS@925mV_CMBattFix_BFS_BFQ.zip
Ebenfalls keine Probs und/oder Bootloops...:D
Hast du evtl. eine Testversion geflasht?
Ich habe einfach (vorher Backup erstellt) beide Kernelversionen per AmonRA geflasht. Ohne irgendwas vorher oder nachher zu ändern.:cool2:
Geflasht haben ich den hier:
http://mirror.couttstech.com/android/bravo/kernel/couttstech-2.6.32.27_OC1190_CMBattFix_BFS_BFQ.zip
Bootloop ist auch das falsche Wort. Das Desire startet und bleibt ziemlich lange bei dem HTC Schriftzug, dann kommen die HW Key (Beleuchtung) und das wars dann.
Habs auch so versucht wie Du. Einfach ein Backup erstellt und geflasht.
Weiters hab ich dann noch versucht: Wipe Cache und Dalvik Cache, Amon Ra 1.7.x.x bzw. 2.0.1 flashen. Rom neu aufsetzen und dann den Kernel flashen... will aber alles nicht.
Inter. jeder andere Kernel läuft ohne Probleme. Verwende zb. grad den von Ziggy (471Kernel-BRAVO). Ist auch einer der wenigen die den Bat Fix implementiert haben.
Welches format hat denn deine ext. Partition? Ext4? Vielleicht wird deswegen meine ext. Partion nicht mehr erkannt. Habe nur ext3.
So hab mir grad die gleiche Version geflasht, wie du.
"couttstech-2.6.32.27_OC1190_CMBattFix_BFS_BFQ.zip"
Die Installation ist Ratzfatz durchgelaufen, Neustart keine Probleme. Funktioniert.
Ich hab die Version3 (noch ein par Apps raus).
Die ext Partition ist eine ext3. Daran liegts also auch ned...:confused2:
Gruß cargo
Vielleicht hat er ja was gefixt. Upload Datum ist ja der 18.12.
Ich versuchs einfach nochmal :)
So grad nochmal geflasht. Wieder das selbe.
Vielleicht erstell ich mal ein Bootlog und schicks mal an Cout.
Edit:
Mir hat einfach keine Ruhe gelassen und denke hab das Problem gefunden.
SetCPU habs einfach deinstalliert und nun läuft der Kernel.
Inter. weise: Installiert man SetCPU setzt diese Automatisch max. 128 min 245. Klar das kann dann nicht funktionieren.
Grüße
Aha, ich hatte vorher kein SetCPU drauf, habs mir erst danach installiert.:smile:
Notiz an mich... ;)
Erst SetCPU abschalten... dann Kernel installieren....
besser als mit dem stock kernel der dabei ist? der zieht nämlich dick am akku, aber auf die schnelligkeit möchte ich nun auch nicht verzichten :p
läuft der kernel einfach nur gut oder kannst du verbesserungen zum stock kernel feststellen (beim newSense rom von baadnwz) ?
Akku mäßig komme ich locker auf meine 24h.
Und dazu lasse ich mein Desire nur auf 1Ghz laufen.
und mit dem stock kernel war das extrem viel weniger oder mehr oder weniger gleich? ich muss nämlich schon 2mal aufladen am tag, wenn ich auf meine 24h kommen will. das ist einfach zuviel :(
Nun komme mit beiden kernel gut 24h hin. Aber normaler Nutzung, haber aber kein Facebook laufen.
mh anscheinend bin ich poweruser :p
benutze es viel als taschenrechner, mails, chat, skype, telefon, internet, zocken, mucke....
da hilft wohl kein kernel mehr :(
der hier ist aber ein havs kernel oder? mit 1113mhz wohl zu knapp dann. werde ihn bei gelegenheit mal testen. danke dir meastro! :)
Nein, ich glaube da hilft nur nen kleiner Atomreaktor für die Tasche.
Würde bei deinem Vebrauch mal nen UV Kernel testen und auf ungefähr 900 MHz takten und mal testen. Wobei halt UV Kernel meiner Erfahrung nach etwas instabil sind
ja das habe ich schon bei cargos rom gemerkt. mit 875mV gings, aber irgendwie fehlte da so ein bisschen die power. will ja auch nicht immer warten, bis er ne seite aufgebaut hat oder wenn man mehrere apps parallel benutzt, dann wird es auch schon manchmal eng. muss mir endlich so einen range extender kaufen. schon schade, dass die akkulaufzeit so gering ist. am meisten merke ich das aber, wenn ich nicht im wlan unterwegs bin. 3g netz ist für mich der akkutot. wenn ich wlan habe, dann habe ich ja normalerweise auch eine steckdose und dann ist es ja nicht so das problem. aber ohne wlan, mit musik und normaler nutzung komme ich maximal 6h weit :(
@actionjackson4k
hast dir schonmal gedanken bezüglich des Akkus gemacht?
Evtl. ist er nicht mehr der frischeste??
Also ich nutze mein Desire auch Täglich: auch Taschenrechner, Dataviz Office(Excel), kleinere Spiele, sehr oft 3g Inet an, Wlan ist aus nur wenn ein Hotspot in der Nähe ist gehts an:smile:, im Inet rumschwirren, an manchen Tagen mehrere Nand-Backups und anschliessender Neuflash eines anderen Roms(zum testen).
Ich komm so auf min. 12h, also für Unterwegs/auf Arbeit reicht es...
Ich hab bei SetCPU min 245MHz und bei max schwankt es, mal 500+irgendwas MHz oder sogar noch weniger.
Das Inet Seiten deswegen langsamer geladen werden, konnte ich nicht unbedingt feststellen, aber vielleicht liegts auch daran das da wo ich langfahre teilweise nur Edge zur Verfügung steht, und ich es darauf schiebe...:rolleyes2:
PS.: Vergessen: Telefonieren und SMSen mach ich damit natürlich auch...:D
Gruß cargo
Notor1ouS
Claus3006
Claus3006
  • Dr. Stain
Claus3006
Claus3006
sartorius
  • sartorius
sartorius
sartorius
