1. BananenAffe, 28.11.2011 #1
    BananenAffe
    BananenAffe Threadstarter Android-Guru
    Wer mir für meine Mühe eine Banane ausgeben will kann das gerne tun :smile:
    [​IMG]
    Hier Universal Monkey Themes,Universal Statusbars,Icon Pack und Wallpaper als Packet zum Download (Mit Winrar oder 7zip entpacken) :
    PART 1
    PART 2
    PART 3
    PART 4
    PART 5
    Please make a Backup with CWM before install my themes !
    All themes are Morphing zip files.The zip files only changes the png files on your phone.
    Attention !
    You have a other theme or a battery Mod of your phone ? Then install the firmware or custom rom again before install my themes.
    Only tested on CheckRom 3.1.1 and Stock Firmware KJ3 with Siyah Kernel 1.8 with CWM4.
    You need a Root Kernel that has CWM to install my themes.
    How to install what you find here:
    Copie Zip File in the root directory of the Internal SD to your mobile phone.
    Go into recovery mode (High Volume + Home Button + Power On Button) or press on the Power menu to recovery.
    Install zip from sdcard
    choose zip from sdcard (not aplly /sdcard/update,zip)
    Search the Zip File
    Then Yes - Install Theme.zip
    Do not despair, because it takes about 10 minutes to flash the Theme and the reboot also takes a while.
    Note :
    If after installing the theme the battery not change,then install the drawable-hdpi-v4.
    Depending on firmware changes the designation in the framework-res.apk in drawable-hdpi or drawable-hdpi-v4.
    The Honecomp Slider and the colored letters in the screenshots are from my Monkey Themes for the CheckRom : Link
    My Monkey Theme Universal Dialer Collection for all Roms Thread : Link
    Icon Morph Pack´s for all Roms
    New Collection of Samsung Keyboards
    Swype Colored Morphing Collection
    Extra accessories for my Monkey Themes ( Batterys,Wallpaper,Lockscreens,Icons,Animations and Extra Statusbars ) -
    Frankenstein's Black Monkey Universal Theme v1
    [​IMG]
    Screenshots :
    [​IMG][​IMG][​IMG]
    More Screenshots here : Screenshot Galerie
    Download for Stock Roms
    Download for Custom Roms
    Download drawable-hdpi-v4 for Stock Roms
    Download drawable-hdpi-v4 for Custom Roms
    Frankenstein's Blue Monkey Universal Theme v1
    [​IMG]
    Screenshots :
    [​IMG][​IMG][​IMG]
    More screenshots here : Screenshot Galerie
    Frankenstein's Green Monkey Universal Theme v1
    [​IMG]
    Screenshots :
    [​IMG][​IMG][​IMG]
    Frankenstein's Orange Monkey Universal Theme v1
    [​IMG]
    Screenshots :
    [​IMG][​IMG][​IMG]
    Frankenstein's Red Monkey Universal Theme v1
    [​IMG]
    Screenshots :
    [​IMG][​IMG][​IMG]
    anime, buehler_11, kurt0815 und 6 andere haben sich bedankt.
  2. BananenAffe, 28.11.2011 #2
    BananenAffe
    Reserviert....
  3. Galaxydroid147, 29.11.2011 #3
    Galaxydroid147
    Galaxydroid147 Android-Hilfe.de Mitglied
    Hallo möchte einer dieser Themes installieren. habe den Stock Firmware KI4 Android 2.3.4. Kann ich das ohne weiteres Installieren oder muss ich iwas beachten?
  4. Metzi, 29.11.2011 #4
    Metzi
    Metzi Android-Guru
    @galxydroid147
    du brauchst root und solltest, wie bereits in Post 1 erwähnt,
    ein Systembackup via CWM erstellen.
  5. Galaxydroid147, 30.11.2011 #5
    Galaxydroid147
    Hab ich das richtig verstanden oder kann man , wenn man ein Battery Mod bereits drauf hat, diesen Theme nicht mehr Flashen?
  6. BananenAffe, 30.11.2011 #6
    BananenAffe
    Da es oft zu Bootloops kam wenn man ein Battery Mod oder anderes Theme was nicht von mir ist drauf hat,rate ich dazu vorher die Firmware oder Custom Rom noch einmal zu flashen um eine saubere Grundlage zu haben.
  7. NiciN, 01.12.2011 #7
    NiciN
    NiciN Android-Guru
    @BananenAffe
    Wie schaut es eigentlich aus, jetzt wo die KK5 raus ist, da gibt es den CF Root ja nur noch mit CWM5, werden Deine Themes dem auch angepast?
    Mag mich nämlich nicht von deinem Blue Monkey trennen da er mir so unwarscheinlichgut gefällt, deshalb warte ich noch mit der KK5
  8. BananenAffe, 01.12.2011 #8
    BananenAffe
    Das hier im Thread sind ja meine Universal Themes.Die theoretisch mit jeder Firmware und jedem Kernel gehen sollten.Ich betone Theoretisch.Ich habe CWM 5 bis jetzt wegen der vielen probleme immer gemieden.Getestet habe ich meine neuen Themes mit CWM 5 nicht.Die neue CheckRom ist ja noch nicht erschienen.Wenn die raus kommt werde ich meine Themes auch wieder anpassen.Und sollte es wieder probleme mit CWM 5 geben kann man sich ja einen Kernel mit CWM 4 flashen,mein Theme installieren und danach wenn man möchte einen Kernel mit CWM 5 flashen.
    kurt0815 und NiciN haben sich bedankt.
  9. NiciN, 01.12.2011 #9
    NiciN
    NiciN Android-Guru
    Aber für die kk 5 muss man doch den cwm5 nehmen, dass es mit cwm 4 nicht läuft
  10. BananenAffe, 01.12.2011 #10
    BananenAffe
    Sagt wer ? Ich konnte bis jetzt mit jeder Firmware oder Custom Rom einen Kernel mit CWM 4 benutzen.Warum soll das jetzt anders sein ? Ich denke mal du meinst das weil es nur CF-Root KK5 mit CWM5 gibt.Es ist aber trotzdem kein Problem sich einen anderen Kernel mit CWM 4 zu flashen ;) Aber erstmal abwarten wann jetzt eine neue CheckRom Version kommt.
    NiciN bedankt sich.
  11. NiciN, 01.12.2011 #11
    NiciN
    NiciN Android-Guru
    Ah Ok....na dann mal abwarten..
  12. Scope, 03.12.2011 #12
    Scope
    Scope Neuer Benutzer
    ich habe gerade versucht das monkey theme zu installieren, hat geklappt, nur beim rebooten ist das android männchen dauernd da gewesen und ich bin nicht zur pin eingabe gekommen jetzt hab ich wieder durch mein backup alles zurückgestellt, kannst du mir bitte sagen wie ich das theme jetzt so installiere dass alles funktioniert??
    dankee!! :)
  13. NiciN, 03.12.2011 #13
    NiciN
    NiciN Android-Guru
    Dann hängst du im bootlop, ausschalten, und nochmal neu flashen
  14. Scope, 03.12.2011 #14
    Scope
    ok hab jetzt neu geflasht, dann hab ich das theme wieder neu installiert und das gleich problem ist wieder aufgetreten, was soll ich tun????
  15. BananenAffe, 03.12.2011 #15
    BananenAffe
  16. Scope, 03.12.2011 #16
    Scope
    Öhh, ich habe nachdem ich von dir den kernel zum flashen bekommen hab das handy geflasht, danach hab ich versucht das theme zu installieren, und nachdem ich das CheckRom auf meinen pc geladen habe kann ich es nicht mal entpacken und auch nicht auf die sd card auf das handy spielen :(
  17. MrMiller, 04.12.2011 #17
    MrMiller
    MrMiller Android-Hilfe.de Mitglied
    bevor ich hier etwas falsch mach!
    wozu ist dies nötig?
    drawable-hdpi-v4 for Stock Roms?
    ist der JKay auch direkt dabei?
    hab die Stock 2.3.6 KK5 installiert mit CWM5
  18. BananenAffe, 04.12.2011 #18
    BananenAffe
    Versuche mal etwas mehr geordnet zu schreiben ;) Ich verstehe nicht wirklich was dein Problem ist ? Wieso CheckRom entpacken ? Die wird als Zip auf deine Interne SD kopiert und so installiert wie man auch ein Theme installieren würde.Beschrieben auf der ersten Seite.Aber entpacken wäre theoretisch möglich um sich die dateien dort drin anzusehen.Ist dies nicht möglich dann ist dein Download schief gelaufen.
    Aber die CheckRom hat ja nicht wirklich was mit meinen Themes hier zu tun.
    @ MrMiller
    Die drawable-hdpi-v4 musst du dir nur installieren wenn sich die Battery nicht geändert hat nach dem install des Themes.
    Je nach neuer Firmware ändert sich der Ordner Name in der framework-res.apk.Manchmal heisst er drawable-hdpi und manchmal drawable-hdpi-v4.
    JKay ist nicht dabei weil sich mit diesen Themes nur die PNG ändern im Handy.
    MrMiller und Scope haben sich bedankt.
  19. Scope, 04.12.2011 #19
    Scope
    Hab es scon geschafft mit dem check rom danke :)
  20. MrMiller, 04.12.2011 #20
    MrMiller
    wie bekomme ich nun JKay installiert ohne das Black Theme zu verändern?
    Stock 2.3.6 KK5
