[Z1-C69XX]KitSlim_AMG [Evo 9][02/08/2014]The power is nothing without the mastering
Hen Ry
Hen Ry
Enthusiast
1.640
Aktuelle Version
[Z1-C69XX][Z1-C69XX]KitSlim_AMG[Evo 9][02/08/2014]The power is nothing without the mastering
ältere Versionen
[Z1-C69XX]14.4.A.0.108-KitSlim_AMG [Evo 7]
14.4.A.0.108-KitSlim_AMG [Evo 6]
14.3.A.0.7XX | KitSlim_AMG [Evo5][24/06/2014]
  • Merged on 761 baseband
  • SemcApk at day
  • Sound Option (Thanks @Rajeev and his team)
  • Live on YouTube™ (if it's available in your country)
  • Pen Mod (Thanks @RyokoN)
  • NFC disable at first boot
  • Fix my error msm thermal in "set_governor.sh"
  • Of best tweaks
  • Best stability
  • Best rendering
14.3.A.0.7XX | KitSlim_AMG [Evo4][12/06/2014]
14.3.A.0.757 | KitSlim_AMG [Evo3][04/06/2014] & 14.3.A.0.757 | KitSlim_AMG [BlackEvo3][04/06/2014]
14.3.A.0.757 | KitSlim_ AMG [Evo2Fix][01/06/2014][Fully Stable] & 14.3.A.0.757 | KitSlim_ AMG[BlackEvo2][01/06/2014][Fully Stable]
14.3.A.0.757 | KitSlim_ AMG [Evo1][28/05/2014][Fully Stable][/URL] & 14.3.A.0.757 | KitSlim_ AMG [BlackEvo1][28/05/2014][Fully Stable]
14.3.A.0.757 | KitSlim_AMG [Edition][21/05/2014] & 14.3.A.0.757 | KitSlim_AMG [BlackEdition][21/05/2014]
GENERAL FEATURES:
KitSlim_AMG [Evo 6]:
_14.4.A.0.108
_Deodexed
_Zipalign
_Optimised
_Efficiency Optimal
_Stamina Optimal
_FullRoot
_FullOption
_DualRecovery
_AMG Performance Center
_Z2 features imported
_Z2 Cam
_4K, 120Fps timeshift video,...
_Live on YouTube™ (if it's available in your country)
_Option reboot
_Phone records, "HD" image id,...
_Smart Call Handling
_Wallpapers Z1, Z, AMG
_Themes Z1, Z, AMG
_Clock Theme accent color
_TaskKiller button
_Metalic AMGTheme [Bicolore (Gray/Red)]
_Slim
_Fast
_Enduring
_The Best Of Sony
_Two Gapps Available:
SlimGapps
------------------}Works Whitout the Gapps
FullGapps
Changelog
KitSlim_ AMG [Evo3][04/06/2014][Fully Stable]
[Evo3][04/06/2014]:
- Governor "ondemand" by default for a better stamina and less of heat (set_governor.sh)
- Scheduler "deadline" by default for a better stamina and less of heat (init.d)
- Fix "servicemenu"
- Fix of errors (init.qcom.post_boot.sh,...)
- Added of art-filter from Z2 (with the ��
ältere Changelogs
KitSlim_AMG [Evo2][Fully Stable]
-Fix overheating (Sysmon, Thermalengine, Read Cache, Good drivers for Camera, Tweaks, Proximity Sensors, Conflict)
-Fix battery drain (Overheating, Read Cache, Tweaks, Proximity Sensors)
-Fix proximity sensors (hw.config.sh)
-CyanogenMod apns-conf.xlm (all operartor)
-Remove R2R services (not need)
-Back on the old tweaks (stability)
-Tweaks for a better compromise stamina and efficiency
-Back on the old camera (V4.1 drivers, framework, apk)
-Clock with text accent color (as on the Blackedition)
-Mirror Link Available*
*(or dev host Rom+Gapps, or uploded Rom+Gapps... It's same, but for dev host, I am limited at 512MB by files... I have modified the packages for that...)
KitSlim_FullPowerV4.1 Final Stage[14/05/2014][Fully Stable]
  • Bugs Fix
  • Fix Networks Loss
KitSlimFullPowerV4[14/05/2014]
  • Bugs Fix
  • Fix Networks Loss
KitSlim_FullPowerV4 Final Stage[11/05/2014]
  • Fix reboot inside the recovery
  • I have changed some settings
  • Best stamina
  • Best responsiveness
  • More smooth
KitSlimFullPowerV3.4.2[09/05/2014]
  • Little fix for Google Search
  • The rom is fully stable now, all works well, very well
  • There is only the Gapps that were modified
KitSlimFullPowerV3.4.1[03/05/2014]
KitSlimFullPowerV3.4[02/05/2014]
  • I set the read cache to 1024 (only for the phone, not for the sd)... And not by tweak init.d, or by tweak on build.prop
  • I fixed the forced closure of the new album
  • I have put the real "reader by sony" instead of shortcut, because according your account, it was not necessarily available
  • I have add torch apk
  • Update of "TvSideView"
  • I fixed the problem for the Rom without GAPPS ( request of your language, at all the reboots)
  • Gapps update for paste with the rom
KitSlimFullPowerV3.3.1
  • Reboot in aroma disable (ROM)
  • Gmscore update (ROM)
  • GMS_Maps update (GAPPS)
  • Velvet update (GAPPS)
  • YouTube update (GAPPS)
  • Livewaremanager update (GAPPS)
KitSlimFullPowerV3.3[29/04/2014]
  • Fix walkman fc
  • Boost mod sound (integrated)
  • Z2 caméra (integrated)(not supercam 4K)
  • Bgdefocus (integrated in Gapps Slim and Full...)
KitSlimFullPowerV3.1[26/04/2014]
  • fix Aroma 6903
  • deleted intelligente gesture (the port not work (25%) for the moment)
  • Added playstore and these serv in the rom... (you can flash just the rom but not recommanded)
  • 2 Gapps modified for the romV3.1
  • The number build is stock no name from rom
  • The patch are update
KitSlimFullPowerV3[24/04/2014]
  • New Concept
  • New uploader (dev-host)
  • Fw14.3.A.0.757 (C6903 by default)
  • TWRP
  • FullRoot
  • Deodexed
  • Optimized
  • New tweak
  • Great Stable
  • Great Fast
  • Great Smooth
  • Great Sony Design
  • Reboot Options
  • Full Options
  • One Rom Package
  • Two Gapps Package ( slim or full )
  • Three True Patch for C6902/C6906/C6943 with good build.prop)
14.3.A.0.757KitSlimFullPower[19/04/2014]
  • Rebuild 14.3.A.0.757 UB/LB
  • DualRecovery
  • FullRoot
  • Deodexed
  • Optimized
  • Slimized
  • Great Sony Design
  • Fix localisation (Gps, wifi, réseau)
  • Fix charge off line
  • Fix updater script
  • Full Options (Z2 intelligent gesture, my Xperia, Sony select is back)
  • Option reboot
  • Themes XperiaZ 2012Colors
  • Best of Sony in small size
Download
ROM
  1. 14.3.A.0.7XX-KitSlim_AMG [Evo5][24/06/2014]
  2. 14.3.A.0.7XX-KitSlim_AMG [Evo4][12/06/2014]
  3. 14.3.A.0.757-KitSlim_AMG [Evo3][04/06/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo3][04/06/2014]
  4. 14.3.A.0.757-KitSlim_AMG [Evo2][01/06/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo2][01/06/2014]
  5. 14.3.A.0.757-KitSlim_AMG [Evo1][28/05/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEvo1][28/05/2014]
  6. 14.3.A.0.757-KitSlim_AMG [Edition][21/05/2014] & 14.3.A.0.757-KitSlim_AMG [BlackEdition][21/05/2014]
  1. KitSlim_FullPower-V4.1Fix_Final_Stage ->
  2. KitSlimFullPowerV4 -> wurde gefixt -> wird nicht mehr angeboten
  3. KitSlimFullPowerV3.4.2
  4. KitSlimFullPowerV3.4.1
  5. KitSlimFullPowerV3.3.1
GAPPS
  1. FullGAPPSKitSlim_AMG [Evo5]
  2. SlimGAPPSKitSlim_AMG [Evo5]
  1. FULL GAPPS-AMG-Evo3
  2. SLIM GAPPS-AMG-Evo3
  1. FullGAPPSKitSlim_AMG-Evo/Evo2
  2. SlimGAPPSKitSlim_AMG-Evo/Evo2
  1. FULL GAPPSV4
  2. SLIM GAPPSV4
  1. FULL GAPPSV3.4.2
  2. SLIM GAPPSV3.4.2
  1. FULL GAPPSV3.4.1
  2. SLIM GAPPSV3.4.1
  1. SLIM GAPPSV3.3
  2. SLIM GAPPSV3.2
  1. SLIM GAPPS
Kernel
StocKernel_761 - Flashable zip for C6903 UB/LB
StocKernel_757 - Flashable zip for C6903 UB/LB
Patch FwC6903 + build.prop -> MD5: 760dcdcd218a60c0a8180a00bf93d670
BLACK APPS
BLACK MIXTE SERIE EVO5
BLACK MIXTE SERIE EVO4
Mod
[Volume Boost XZ2-XZ1-XZ1C] Increase internal-external speaker and headphone volume Boost mod sound (integrated)
Screenshots 1-3 ohne Gapps, 4-6 mit Gapps
ohne Gapps läuft die ROM auch (es wird aber empfohlen die Gapps zu installieren)
Ohne Gapps (nicht empfohlen, funktioniert aber).jpgOhne Gapps (nicht empfohlen, funktioniert aber)_1.jpgOhne Gapps (nicht empfohlen, funktioniert aber)_2.jpg mit Gapps.jpgmit Gapps_1.jpgmit Gapps_2.jpg
Reaktionen: Nemeziz, Robby57, infiltrator und eine weitere Person
ich finde den Akkuverbrauch spitzenmäßig (DooMKernel v16)
Besser als bei iHackers ?
Bin derzeit auf ner SlimKat und habe dort 1,5T fast 7 Stunden Display on.
Grüße
meet
Wie schnell ist Dein CPU?
Meiner läuft mit 960.
Helligkeit minimum automatisch, nach 15 sec. Ruhezustand.
Hab derzeit 1,1Ghz im schnitt.
Werde die ggf. mal runterregeln => bis wieviel Hz läuft das System noch flüssig ?
Grüße Meet
Meiner ist auf max. 960 gestellt, reicht mir. Wie weit man runterregeln kann, habe ich noch nicht getestet.
Der Antutu war mit 2,419 MHz.
Große Unterschiede bei Trickster, Performance Control, Pimp My Z1 und Faux.
Man sollte nur mit einem davon arbeiten und die anderen deaktivieren?
Mit Trickster Frequenzsperre 300MHz eingestellt.
Die anderen Apps zeigen alle 652MHz und die Regler stehen alle auf Null.
652MHz ist vermutlich die Grenze für max. nach unten.
Ich habe mit LBE Security Master alles was geht geblockt, Werbung, Verbindungen, Standort etc.
Reaktionen: Robby57 und meetdaleet
Liest sich gut.
Habe mich jetzt an Criskelo gewöhnt, aber die SlimKat zu testen kann ja nicht schaden.
Warum sind die Gapps nicht zu empfehlen?
Nene, Henry empfiehlt das installieren der Gapps. Zumindest verstehe ich das jetzt so :)
LG meet
Danke euch.
Habe ich mich verlesen.
Bin am downloaden. Ist halt ärgerlich alles wieder neu einzurichten. Aber ohne Fullwipe macht das keinen Sinn.
Ich bin einfach über monX drüber mit Wipe Cache und Dalvik.
Erstmal zum testen und anschauen, Daten übernohmen läuft.
Super werde es dann auch erst mal ohne Fullwipe testen.
Rom ähnelt monX? Ohne Schnickschnack, nur wert auf Performance gelegt.
Ich habe noch viele Apps entfernt, den kompletten Minilauncher etc.
Apps die ich bei monX und KitSlim entfernt habe, sind bei beiden ROM's nicht indentisch.
Liste app: 36 entfernt
  • AdAway.apk
  • Browser.apk
  • CloudPrint.apk
  • ExternalKeyboardJP.apk
  • Gmail2.apk
  • GoogleLyricsPlugin.apk
  • GoogleTTS.apk
  • GooManager.apk
  • Home.apk
  • JapaneseIME.apk
  • MediaUploader.apk
  • PlayGames.apk
  • PrintSpooler.apk
  • psmselfupdater.apk
  • PSCertifiedSettings.apk
  • SemcTvLauncher.apk
  • smallbrowser.apk
  • SmallApp-Calculator.apk
  • SmallApp-Timer.apk
  • SmallAppManagerService.apk
  • SmallAppsLauncher.apk
  • SmallAppWidget.apk
  • SmartSearch.apk
  • sneiaccountmanager.apk
  • socialife.apk
  • talkback.apk
  • textinput-chn.apk
  • TouchBlock.apk
  • Torch.apk
  • VMwareReady.apk
  • WikipediaPlugin.apk
  • WirelessControllerManagerService.apk
  • xperialounge.apk
  • YouTubeKaraokePlugin.apk
  • YouTubePlugin.apk
Liste priv-app: 24 entfernt
  • EnterpriseService.apk
  • MyXperia.apk
  • SEMCFacebookProxy.apk
  • SemcTvOut.apk
  • ShareApplication.apk
  • socialcast.apk
  • SocialEngineCore.apk
  • SocialEngineFacebookPlugin.apk
  • SocialEngineFacebookShareFrwkPlugin.apk
  • SocialEnginePicasaPlugin.apk
  • SocialEngineTwitterShareFrwkPlugin.apk
  • SomcMirrorLinkManualSwitch.apk
  • SomcMirrorLinkServer.apk
  • SomcMirrorLinkSystem.apk
  • SomcPlayAnywhere.apk
  • SomcPodcast.apk
  • SOMCTwitterAccount.apk
  • Velvet.apk
Liste SlimGapps: Ordner system\etc\product\applications
  • com.sony.tvsideview.phone-1.apk
  • officesuite.apk
  • SemcTorch.apk
  • tracktv.apk
Entfernt habe ich auch das Dualrecovery, da ich meinen angepassten DooMKernel mit TWRP und Vibration=disable nutze.
4u5yqe3a.jpg -> ohne SmallAppsLauncher.apk
Mit was machst du die setcpu?
neue Versionen KitSlimFullPowerV3.4[02/05/2014] -> 14.3.A.0.757KitSlimFullPowerV3.4.1
meine Einstellungen, z.B. CPU in MHz: min 300, max 960
Ich habe und angezeigt wird:
  1. CPU Control: min 300, max 960
  2. FauxClock: min 300, max 960
  3. Performance Control: min 300, max 960
  4. Pimp My Z1: min 960, max 960
  5. Trickster MOD: min 300, max 960
  6. ROM Toolbox: min 300, max 960
Ich weis noch nicht genau was ich nehmen soll, ist auch eine Frage in wie weit die ROM's voreingestellt sind?
Mit Pimp z.B. läßt sich Governor pro Kern einstellen und Voltage Boost ein/aus. Im DooMKernel v16 ist Snake Chamer an, ließ sich mit Pimp im DooMKernel v15 ein/ausschalten.
Reaktionen: meetdaleet
Also bei mir läuft die ROM bisher wirklich zufriedenstellend.
Mir gefällt die leichte und dezente Änderung der UI wirklich ausgesprochen gut.
Habe heute mal alles auf Herz und Nieren getestet und werde die ROM jetzt für den Alltag nutzen. Für Spielereien weiterhin meine geliebte slim Rom immer mit dabei :)
Danke für deine Empfehlung, auch hinsichtlich der Kombination mit dem DooMKerneL.
Lg meet
Henry2o1o schrieb:
Ein Problem habe ich jetzt, Fullwipe und Rom ist neu drauf.
Wie bekomme ich jetzt meine Emailkonten wieder hergestellt?
Mit dem Titanium Backup funktioniert es nicht.
Konten sind kurz da und dann gleich wieder weg?
An dem Rom liegt es nicht hatte das Problem auch schon bei anderen.
Mitunter ein Grund warum ich nicht die Stock-Mail App nutze.
Bin schon seit geraumer Zeit auf Aquamail (Auch schon aufm Nexus, Note und Z).
Hab mir zu Anfang mal kurz die Stock-Mail App angeschaut, um zu sehen, ob die sich verbessert hat im Vergleich zum Xperia Z -> aber musste leider eines besseren belehrt werden.
Die Anwendungsdaten mit TB (Systemdaten => Mail App) lassen sich also nicht wiederherstellen ? Oder hast du nur Benutzer-Apps gesichert ?
LG meet
Aquamail habe ich auch schon lange in Betrieb.
Seit KitKat habe ich mir mal zusätzlich meine 5 Konten bei der Stock-Mail App mit IMAP eingerichtet.
Mit TB habe ich alle Anwendungen und Daten gesichert.
Jetzt mit TB alles zurück nur bei der Stock-Mail gibt es Probleme.
Gerade habe ich im Recovery "Data" zurückgeholt.
Werden die Konten nicht bei Google gesichert? -> Konten -> E-Mail -> Konten (bei mir 5) -> Jetzt synchronisieren
Afaik bezieht sich das nur auf die über GMAIL genutzten Konten.
Achso, hast du die Aqua-Free Version zu laufen ? Da is ja ne Beschränkung von 2 Mail Konten drin - oder ?
LG meet
Nein, ich habe den Pro Key.
Also die Rom ist nicht verkehrt das ist richtig.
Nur zwei Dinge.
Ohne Fullwipe geht bei mir Google Suche nicht mehr. FC Fehler, Kamera in Verbindung mit Gravitybox keine Navigationsleiste mehr.
Bei Criskelo hatte ich das Problem nicht.
Wie schon gesagt habe keine Lust Fullwipe zu machen und alles neu einzurichten.
Wills mal so ausdrücken. Man kann jedes Rom schmaler machen in dem man alles unnötige runter wirft und damit Performance gewinnt.
Deshalb zurück zum Backup.
Bitte nicht überbewerten wollte nur meine Meinung abgeben. Kitslim ist für jeden der einfach nur auf Stockrom steht eine gute Wahl.
Für mich einfach zu viel Aufwand um alles auf meine Zufriedenheit anzupassen.
LG Robby
  • 1DROID
1DROID
Sarahlein
  • Sarahlein
Aaskereija
Aaskereija
Netbook
Netbook
