[ROM][4.4.2] Resurrection Remix® KitKat [AOKP|CM|PA|Omni|Remix]
"Funktioniert der Playstore nicht mehr" ist eine sehr vage Fehlerbeschreibung. Wird ein Fehler angezeigt? Wenn ja, welcher? Wird die App direkt beim Starten beendet?...
Resurrection Remix ROM
CHANGELOG
Source Code: http://github.com/ResurrectionRemix
Website: Resurrection Remix - Android in all its Glory
For extended changelog, track github activities
# Resurrection Remix KitKat 4.4.2 - v5.1.5-20140609 # Basic
- Navigation bar dimensions
- Ability to disable hardware keys via nav bar settings
- Add android:key in hardware keys enable/disable option to forward enable this option
- Themes: Delete icon resources during uninstall
- Themes: remove unused code
- Themes: uninstallThemeForAllApps shouldn't check if map is empty if it's null
- base: remove extra checks
- Don't cleanup overlay mapping for non-theme apps
- appops: enforce appop for bluetooth disabled action
- About Resurrection: devcard layout - fix FC devcard on lanscape mode
- settings: FC on quick settings editor on tablets without a vibrator
- Add a HAF access permission
- Fix layout recreation check
- CameraTile: Launch default gallery app when long pressing active camera tile
- SystemUI: prevent NPE on clear recents double press
- MtpDatabase JNI: Fixed a memory-leak in getObjectPropertyValue().
- Correct stride for drawing to cached glyph bitmap
- Use alpha channel instead of red in drawCachedGlyphBitmap
- Temporarily hide lock screen unlock targets if opening a widget
- fw: media: Handle NPE due to threading race
- FW: LS Notification: fix FC when an expanded notification gets reposted without bigContentView
- fix derp on INotificationListener
- WallpaperCropper: do not display null bitmaps
- Make theme change broadcast a protected broadcast.
- Reduce memory leaks by removing all views.
- appops: do not prune apps that are not present
- apn: national roaming for ONO (Spain)
- fix more keyguard derp
- Mms: Clear notifications and mark messages read in certain situations
- galaxys2-common: fix front cam video recording
- Recovery - Version 6.0.4.9
- included all cm-11.0 m7 updates
- Check out the source activities for more details https://github.com/ResurrectionRemix
# NOTE:
- This is the final release of Resurrection Remix android kitkat series.I ll catch you guys on next android version A.K.A 4.5 or 5.0 . See you soon .Thank you !
westcrip
ENJOY!
Hi, kann mir bitte jemand sagen wie ich den Hintergrund im Systemmenü ändern kann. Geht das vielleicht mit xposed? Gruß Fiedl
Normalerweise mit dem theme-chooser... Aber eigene Bilder einfügen? Keine Ahnung!
Reaktionen: Fiedl
Hab es schon ne Weile am laufen.Bei mir läuft es sehr gut.Finde es läuft flüßiger als das LS ROM.
Danke für`s herholen.
Gruß Fiedl
Habe mal die neue Version 5.4.1 (LP 5.1) in einem neuen Thread vorgestellt
Hab die Rom mal angetestet und die gefällt mir echt gut ^^ nur fehlt mir die E-Mail app vom den Stock roms wo man auch Bann Listen anfertigen kann ^^
Gibts da ne möglichkeit die App auf der Rom zu bekommen? (Mit TB hats nicht funktioniert)
Bigmoomba es gibt diese Rom mittlerweile als 5.4.3 bzw lollipop 5.1.1
Dort ist die E-Mail APP enthalten
Dr.No
Astra-Celly
scheues.alien
scheues.alien
Silverblade
Nufan
Nufan
