holzloeffel
Stamm-User
- 693
FlorianZ schrieb:Ach misst. Dann fürchte ich geht das bei IOS nach wie vor nicht
*Go to shortcuts, add a new shortcut (plus sign in the upper right hand corner)
*in the search bar at the bottom, type “choose from menu” and select that option
*Where it says prompt, enter whatever category your folder will be (ex: food, streaming, games, etc)
*delete the text that says one and two. Add new item and type whatever app you want to put (ex: Reddit, Netflix, etc)
*in the search bar at the bottom, search “open app”. Click it.
*Drag the “open app” bar below your first app name.
*Select the “app” button and choose the app from the list
*repeat for all apps ***select the i at the bottom of the screen
*click “add to Home Screen”
*click the small icon that is circled in blue, select choose photo and pick the photo you want as your icon
*either delete the words next to the icon or rename it
*click add at the top left of the screen!
FlorianZ schrieb:Nicht ganz was ich suche
MMI schrieb:t weil es ja eher ein iOS 26 Homescreen statt
Kannst du das Bild zur Verfügung stellen ? DankeRebelSoldier schrieb:Bei mir eigentlich auch immer das gleiche
Hier 1. Seite + Lockscreen![]()
