[Kernel][G920F][TW 5.1.1]*31.10.2015*GoogyMax-S6 1.5
Sven65
Gast
GoogyMax-S6 1.5 [TW 5.1.1]
Dieser Kernel ist nur für das S6 G920F
Features:
- Based on XXU2COH8 Samsung Lollipop Sources
- Updated to latest XXU2COH8 ramdisk with Auto-root included
- Patched to latest Linux 3.10.90
- Compiled with toolchain gcc 5.2.1
- SELinux set to permissive
- TCP congestion controls: bic - westwood - htcp - hispeed - hybla
- IO schedulers: cfq - bfq - deadline - fiops
- LZ4 compression
- A lot of changes and tweaks for better performance & battery life
Installation
1.Download
2. Kernel auf dem Smartphone speichern
3. Download ins Recovery (TWRP oder Philz)
4.Kernel flashen
5. Cache und Delvik-Cache leeren
6. Neustart
Zur Sicherheit vor dem Flashen ein Backup machen
Downloads & Changelogs
[10OCT] Version 1.3 :
- Correctly Patched to 3.10.90 (thx Swapnil Solanki for pointing me to the faulty patch)
- Fixed sensors issue
- Added LZ4 support
- Added DriveDroid support
- Added bfq-fiops-deadline schedulers
- some changes from note5 latest sources
- some minor changes (cpufreq-hotplug)
[03OCT] Version 1.2 :
- Patched to 3.10.90 (partially as some net patches caused booting problems)
- Compiled with gcc 5.2.1 + optimization flags for cortex-a57.cortex-a53
- little GPU fine tuning
- Reverted some commits causing performance regression
"You're going to like this one"
[29SEP] Version 1.1 :
- Updated with S6 Edge+ Samsung Sources
- Fixed sound issues
- Boosted GPU preformance
- More minor changes/tweaks
[25SEP] Version 1.0 :
- Patched to latest Linux 3.10.89
- Compiled with linaro gcc 4.9.3
- TCP congestion controls: bic-westwood-htcp-hispeed-hybla
Googy-Max-S6_Kernel_TW_1.0_CWM.zip - [Click for QR Code] (16.14 MB, 624 views)
XDA-Thread
Update auf 1.5
Changelog:
- Patched to 3.10.92
- little compiler optimization
LORD HELMI
Sven65
Wicki
FlashMaster Android
