[ROM][5.0.2][OFFICIAL]Euphoria-OS 1.0[7-März] [D85x/LS990/VS985]
  • 139 Antworten
gewürzwiesel
gewürzwiesel
Philosoph
2.055
Vorwort:
Alle Downloadlinks sind am Ende des OP´s zu finden!
Für Schäden oder ein G3 das zum Briefbeschwerer wird seid ihr verantwortlich :D
Moinsen!
Ich habe auf meiner Suche nach einem guten, gleichzeitig schnellen CM12 Derivat folgendes entdeckt, die "Euphoria":
Features der Rom:
Under The Hood
AOSP Based
Un-encrypted
Theme Chooser
Customize Quick Settings
Delta Updates
Disabled tether checking
IME selector notification control
Advanced reboot
Adb notification control
Adb over network
Long press back to kill
CPU info overlay
Status bar brightness control
Superuser built into privacy gaurd
Battery Icons options
Option to disable lock screen carrier label
Slim heads up options
Headsup - don't show if notification drawer is visible
HeadsUp: Swipe options
-left swipe dismiss
-right swipe put into background
-swipe down opens notification drawer and moves the notification into it
cLock widget
Notification weather panel
Disable battery saver bar color
Dialer - reverse number lookup
HSPA+ Icons
Statusbar clock and date customizations
Sound
AudioFX
Eleven
Increasing volume ringtones
Profiles
Increasing ring volume
Less frequent Notifications
Long Press Volume Keys to skip track
Disable volume adjust sound
Separate Ringtones & Notification volumes
Expanded Volume Panel
Navigation
Navigation bar options - Size & Hide
Left Handed nav bar in landscape
Double tap to wake
Double tap statusbar to sleep
Wake on charge
Keyboard cursor control
Quick settings quick pulldown
Long Press recent buttons to switch apps
Long press back to kill app
Customize clear all button location
Security
Privacy guard with advanced app opp control
Blacklist for calls and sms
Dialer
Forward lookup
Speed dial
Vibrate on answer
MMS
Updated to material theme
Pinch and zoom conversation screen
Custom vibration patterns
Quick reply
Delay message timer
Mms import & export
Flashvorgang:
Wenn ihr Euphoria das erste mal flasht oder von einem anderen Rom kommt:
- Seit sicher, dass ihr eine funktionierende Custom Recovery habt
- Gapps und Rom auf eure externe SD kopieren
- in die Recovery booten
- Macht einen DATA WIPE / FACTORY RESET
- Flasht die Rom.zip von eurer externen
- Flasht die Gapps von eurer externen
- Reboot
- Keine Systemdateien mit Titanium restoren
Upgrading:
- Rom auf eure externe SD kopieren
- Reboot
Changelog:
3/17/15
- Fix navigation bar dimensions
- Theme chooser updates
- Option to disable lock screen visualizer
- Long press lock screen lock icon to sleep
- Add LiveDisplay settings (Display color tuning options from cm)
- Settings reorganization
- Added advanced mode toggle in developer settings to hide most custom options
- Quick settings improvements
- Force expanded notifications
- Double tap to sleep on navigation bar
- Smart pulldown
03/07/15
- Initial release
Funktionierende Custom Kernel:
Der Furnace und der 777 sind beide mit der Rom kompatibel.
Die Features des Furnace:
- Kexec-hardboot support
- Furnace boot mode
- Custom user restart reason support
- Userspace voltage control
- Live userspace sharpening control
- simple_ondemand devfreq governor
- fsync userspace toggle
- KCAL_CTRL RGB driver (replaces LCD_KCAL)
- Sound Control 3.6 GPL from faux123
- laf reboot mode (bootloader)
- exFAT-nofuse filesystem support
Die Features des 777:
Bumped
* Linux 3.4.106
* Built with latest SaberMod 4.9.3 Toolchain
* Sweep2sleep
* Powersuspend 1.6 by @faux123
* Intelliplug from @faux123
* IntelliMM from @faux123
* FIOPS, ROW, SIO, DEADLINE, NOOP, CFQ Schedulers
* Added GPU Governors: msm-adreno-tz, performance, simple_ondemand
* OC to 2.7Ghz and CPU Limiter by @Tectas
* GPU: OC to 657MHz, Idle on 27MHz and add 100MHz Step
* Added Kexec Hardboot Patch (MultiROM support)
* Voltage Control Support
* FauxSound App Support
* 2-Way Call Recording Support
* Live userspace sharpening control from @savoca
* KCAL_CTRL RGB driver (replaces LCD_KCAL)
* Frandom
* Dynamic FSync
* exFAT-nofuse filesystem support
Für Leute die Probleme mit Wakelogs haben hier mal eine App die Cpt empfohlen hat: Stop Log
Hier nun alle entsprechenden Links:
Orginal - Thread: Euphoria OS
Rom - Download: Euphoria OS Download
Gapps - Download: Lollipop - PA - Gapps
Furnace - Kernel: Thread - Download
777 - Kernel: Thread - Download
Bei Fragen und Erfahrungsberichten einfach posten!!​
Reaktionen: meine-Handywerkstatt, Black-Angel und deviceX
Bei der Rom hatte ich diverse probs
Wie zB beim Akku laden. Die Ladedauer betrug 2.5 - 3 std bis der Akku voll war darüber hinaus war er schnell wieder leer
Das WLAN hat nur mukken gemacht manchmal hat es 5 min gedauert bis es aktiviert war und man ein Netzwerk suchen konnte
Die Kamera war wirklich. Schlecht
Habt ihr auch sowas bei der Rom beobachtet.
Bin im mom auf. Der hier |ROM| LG G3 D855 Dirty Unicorns. v 9.1 Unofficial. Akku ist top. Kamera wie WLAN auch. Bin mit der super zufrieden
Bei mir alles top.
Das W-lan spinnt bei mir im Geschäft, aber das liegt am Router. Ich hatte den Bug mit dem aktivieren des W-Lans bei CM12, da hat aber ein Baseband-Flash Abhilfe gebracht.
Der Akku ist bei mir topp und auch das Laden geht sehr schnell. Oder eben normal schnell wie mit einem 2A Netzteil üblich.
Die Cam schlecht? Alles relativ. Abhilfe schaffen die zig Alternativen im play store.
Reaktionen: deviceX
Eindeutig das beste ROM für das G3.
Kein Rom läuft so flüssig wie Euphoria.
Mit WLAN usw. hatte ich bis jetzt noch keine Probleme, dafür habe immer noch Probleme damit, dass die Kiste nicht in den Deepsleep fährt. Habe schon alle möglichen PAGapps Versionen und auch die aktuellen Banks Gapps ausprobiert. :(
Das Laden funktioniert bei mir einwandfrei und die Standard CAM ist Geschmackssache.
Ich verwende grundsätzlich den Port der Lenovo Supercam.
Reaktionen: deviceX
So ist es, das mit den langen lade Zeiten habe ich zwar auch, aber ich lade immer über Nacht, also egal. Die cm cams sind immer etwas mies, deswegen nehme ich auch schon lange den Lenovo Port. Ansonsten die beste cm/aosp rom zur Zeit. Wer Quick Remote nutzen möchte, was bei mir der Fall ist, da die remote app von LG die beste ist, kann den aosp Port nutzen.
http://forum.xda-developers.com/lg-g3/themes-apps/app-quickremote-port-aosp-t2929146
Hierfür muss man dann aber die app" selinux Mode changer" laden und auf permessiv stellen.
Das Problem mit dem Deepsleep habe ich immer noch. Allerdings tritt es nach der ersten Installation erst nach einem Neustart auf. Habe alle möglichen Gapps ausprobiert. Das nervt mich ungemein.
Liegt an Google und da heißt es wohl warten, oder die gapps vom 01.03. nutzen, da ist der Bug noch nicht drin. Ist also kein rom Problem.
Auch mit den vom 01.03. habe ich das Problem. Mit dem Darkobas ROM funktioniert sogar mit dem PAGapps vom 07.03. alles einwandfrei.
Okay das habe ich auch schon gelesen, wirkt sich auf jedem Gerät wohl anders aus.
Ich hoffe, dass bald ein Update kommt und sich das Problem dann erledigt.
Edit :
Habe gerade noch mal mit MyAndroidTools geguckt und festgestellt, das bis auf einen alle Update Services deaktiviert waren.
SystemUpdateService$SecretCodeReceiver
Darunter steht noch irgendwas mit Telephony Secret Code. Auf jeden Fall gibts nach Deaktivierung jetzt auch bei mir den Deepsleep Modus wieder.
Moin,
hab auch die Probleme mit den waklocks.
Kannst dubuns kurz sagen welche Sachen man da deaktivieren muss?
Bin bei dem von dir besagten APP bei Service und dort dem Punkt Google Play Service. Da sind aber so viele Sachen die man deaktivieren kann.
Greetz
Du musst unter Service und Broadcastreceiver auf den Google Play Dienst gehen und alles deaktivieren, das mit System Update Service zu finden ist.
Ich habe einen "amüsanten" Fehler:
Mache ich einen HotReboot funktioniert meine mobile Datenverbindung nicht mehr.
Habe ich eine funktionierende mobile Datenverbindung funktioniert mein W-lan im Geschäft nicht.
Habe ich nach einem HotReboot keine mobile Datenverbindung und aktiviere mein W-Lan im Geschäft funktioniert die W-lan - Verbindung.
WTF?!? :eek:
Cache dalvik wipe schon versucht? Nach dem Boot etwas warten und nicht gleich den Pin eingeben. Hatte ich auch und so hat es funktioniert. Außerdem nutze ich wifimatic, die app regelt das ganz gut.
Reaktionen: gewürzwiesel
Hast du vielleicht einen Link zur App? Da gibt's 2 :D
Pin hab uch ausgestellt und es ist auch nur bei HotReboot. Was mich viel mehr wundert ist, dass WiFi im Geschäft nur mit ausgeschalteter mobiler Verbindung geht. Bei mir daheim geht's auch mit. Sehr strange...
Ich wollte einfach mal ein anderes Baseband flashen, find nur keine :D
Fettes Merci.
Ist das 20i das neuste? Ich hab keine Ahnung wie ich beim LG das Baseband lese um festzustellen welche Version ich überhaupt habe. Bin jahrelang Samsung gewöhnt :D
20i ist die neueste!
Der Vergleich ist schwierig, da LG nicht immer zwingend eine neue Nummer vergibt. Bei den früheren vom G3 konnte man es sehen, jetzt seit 20f (?) keine Unterschiede mehr zu sehen an der Nummer... Oder es ist seitdem das gleiche Baseband, alles möglich
Muhahaha, also doch was was bei Samsung besser war :D
Sag nicht so ein sch..... Seit dem note 3 bin ich sowas von weg von diesen Panzerbauern. Efused knox usw... Bonbon Optik loser Verein!
Edit : hatte den vergessen
