ALE-L21 Dual-SIM Android 5.1.1 - B010 Custom ROM [7 HD 1.2 by S3V3N]
  • 51 Antworten
JohnDoe710
Bin bei den Kollegen von xdaDevelopers gerade über diesen Beitrag gestoßen! Habe es selbst leider noch nicht testen können. Interessant ist für mich wäre vor Allem, ob damit endlich O-T-G funktioniert
Android Lollipop 5.1.1 Custom ROM für ALE-L21 Dual-SIM based on C432B010 by ☆ 7 HD 1.2 to S3V3N ☆
Quote:
Originally Posted by S3V3N
Key features of the ROM 1.2:
- Fixed problem with login to FaceBook
- Fixed problem with Google Plus
- Fixed problem with logging and sending messages in Hangouts
- Added a new bootanimation Android Marshmallow
- Changed the NavBar on 28x28 size
Key features of the ROM 1.1:
- Fixed problem with the BT connection
- Fixed problem with displaying the BT connection
- Fixed an issue with Google Chrome
- Fixed an issue with the Phone Manager
- Fixed a problem with the HP Print Service
Key features of the ROM 1.0:
- Contains a modified kernel by me
The kernel has a feature AutoROOT - we do not need to install the SU binary and SuperSU
Kernel has BusyBox - check and installation, if necessary
Added TWEAK zipalign for all applications during start up of the system
Added optimization database using sqlite3
The kernel has full support for init.d (activated the ramdisk!)
- Modified been the custom partition (removing unnecessary ballast)
- Removed all unnecessary applications (Huawei and Google)
- Updated all other applications (Huawei and Google)
- It looks basic - Android L
- Optimized to consumption of RAM
- Fixed an issue with the record on the SDCARD
- Unlocked feature DTS mode Headset
- Added call recording
- Optimized applications (leaving only the 64bit version if the application of this required)
- Integrated SuperSU
- Integrated BusyBox
- Added Tweak's in build.prop
JPG compression 100%
lack of collecting logs for Kernel
new settings for Wi-Fi
new settings for DeepSleep - Sleep
new settings for Dalvik
new settings for rendering
new settings for sensitivity and speed of the screen
....and many others
Installation:
- Download ROM
- install with TWRP recovery
- full WIPE
Download:
7 HD 1.2 ROM by S3V3N
MD5 : 4c344a262d347c707b4285b16db71d42
Reaktionen: loomy
Habe schon heute Morgen auf xdadevs gesehen.Endlich tut sich etwas.
Hi, habe heute die Rom geflasht.. Antutu 29572.
soweit stabil und recht schnell alles.
Hallo bin neu im Android Sektor habe jetzt folgendes vor um diese Custom Rom zu Flashen, Bootloader Unlock, Handy rooten, TWRP APP installieren am Handy, Custom Rom auf Speicherkarte und Image über die APP wiederherstellen....
Funktioniert so mein Vorhaben???
MFG
Johann
Und wohl auch schon wieder vorbei...
Was ist vorbei?
Hört sich bei xda so an als ob die Rom nicht weiter entwickelt wird!
Der Thread wurde geschlossen:confused2:
Der Dev. Der Rom hat sich über sinnlose posts aufgeregt und hat den Thread schliessen lassen ;D hab die Rom ohne Wipe mit TWRP über b170 geflasht, läuft super, manchmal wlan probs aber sonst keine wirkliche veränderung spürbar.
Auch die Navigationsleiste am unteren Bildschirmrand lässt sich nicht wie im Video Ein/Aus-blenden
Hmm. Schade.
Bei mir geht wlan und auch Maps.
Habe es vorhin getestet.
BT geht auch. (Hatte da auch noch nie Probleme).
Ich habe auch erst TWRP (über ADB) und dann über die B136 drüber geflasht.
Gibt es ein Tutorial wie ich diese Custom Rom installieren? Kann mir wer helfen?
Erst Bootloader entsperren, dann Root, dann TWRP, dann Rom, dann kleines Gebet das es auch noch bootet...
[doublepost=1452282852,1452281449][/doublepost]Wenn einer noch die .zip Datei 7HD.... Und TWRP Image braucht, ich habe sie noch auf Rechner und sd Karte.
[doublepost=1452283020][/doublepost]Warum steht da jetzt eigentlich für P8?
Bin mir sicher da stand letzte Woche noch P8 Lite...
Reaktionen: AnonUser und johination
Habe die ROM auch gestern geflasht, soweit alles gut... Es scheint so als wäre der Akkuverbrauch niedriger....
Hmmm, also bei mir so wie vorher. Aber minimal schneller finde ich.
Mich würde die Dual Sim Funktion interessieren evtl. mehr Einstellmöglichkeiten?
Nutze die Funktion eigentlich nicht, aber hier ist ein Screenshot von der Custom Rom.
Finde nicht das sich da was geändert hat.
SIM jetzt gar nicht mehr aktiv. Lassen sich auch nicht aktivieren. Downgrade über Stockrecovery auch nicht mehr möglich.
Wenn man mit fastboot eine andere Version flasht, sind die SIM-Karten nach wie vor tot.
Ist gleich geblieben..
habe aus obigen Link auch noch diesen Modempatch installiert. Denke mal, dass der geschützt ist und es daran liegt.
Bräuchte wahrscheinlich eine funktionierende Modemimage.img und Modemnvm1.img.
Edit: Läuft wieder, lag wie vermutet am Modemimage (geschützter Bereich, nicht über Fastboot flashbar).
Mit dem Huawei Update Extractor die 120er Boot/Cust/Recovery/System eingespielt.
Danach ging auch das Update über dload, hier erst 136, dann 170 und am Ende 188.
Wenigstens weiß ich jetzt, warum der Entwickler alles rausgenommen hat.....
Hallo wie komme ich wieder zurück auf b170 von der b010 ?
danke im vorraus
