Trina
ElementalX OP3 Oxygen 0.23 / CM 13 0.31
Stock Rom Oxygen OS 3.x / CM 13
Features:
Download:
OnePlus 3 – elementalx.org
GPL Source code:
GitHub - flar2/android_kernel_oneplus_msm8996
Info
ElementalX-OP3, Kernel für das OnePlus 3
Contributors
flar2
Source Code:GitHub - flar2/android_kernel_oneplus_msm8996
XDA Thread: [KERNEL] [August 4] ElementalX-OP3 0.10 (stock) 0.17 (cm)
G+ Community: ElementalX Kernel – Community – Google+
Update 23.09.2016
OxygenOS/Stock-based ROMs
ElementalX-OP3-0.23
Cyanogenmod-based ROMs
ElementalX-OP3-0.31-cm
Changes:
-prevent speaker gain from resetting
-update installer
Features:
- Easy installation and setup with Aroma installer
- Wake Gestures support (sweep2wake & doubletap2wake)
- Notification LED control
- Advanced color control
- Sweep2sleep
- Backlight dimmer
- Overclock or underclock CPU
- Adjust or disable vibration
- FIOPS, BFQ, CFQ, deadline, noop and SIO i/o schedulers
- NTFS r/w support
- Option to disable fsync
- performance and power optimizations
- USB OTG support
- Dash charge
- Supports MultiROM
- Does not force encryption
- Does not modify system partition
- Does not overwrite modules
- Compatible with systemless roo
Download:
GPL Source code:
Info
Contributors
flar2
Update 23.09.2016
ElementalX-OP3-0.23
Changes:
-update installer
Bearbeitet von
Trina
- Grund: Trina
