nozama
!!! Knox 0x1 wird ausgelöst und Samsung Pay ist nicht mehr nutzbar !!!
WICHTIG : Ihr handelt auf eigene Gefahr! Ich übernehmen keinerlei Haftung für euer Handeln oder einen Brick!!!
Kernel Samsung Galaxy S7 G935F/G930F International
KERNEL FUTURES
- Source base G935FXXU1APG3
- Aroma installer
- Synapse support
- busybox&sqlite3
- working fingerprint (@jesec)
- gzip/lz4 compression
- init.d support
- system WR
- encryption enforced
- KNOX removed
- ramdisk SU prepared
- OС/UV CPU cores (UP to 2.9 MONGOOSE and 1.8 APOLLO)
- UV DVFS
- OC/UV GPU (UP to 806 MHz)
- VDD voltage correction on kernel INIT stage (aroma) (up to -25 mV)
- CPU Governors
- IO schedules
- power suspend support
- UKSM
- LED Control
- frandom driver
- f2fs
- N7 ports support
DOWNLOADS
Prometheus v1.5.2
old versions
CHANGELOG the post #2
THANKS
Samsung team
@jesec (init work by jesec kernel)
friedrich420 (code samples)
@amarullz (aroma installer)
@osm0sis (AIK)
@Tkkg1994 (code samples)
@teckauz (banners)
@Shuuin (aroma logo)
SOURCES
GitHub: s7e_marshmallow
BANNERS
designed by @teckauz
designed by daughter
[NOPARSE]XDA
Prometheus, Kernel for the Samsung Galaxy S7 Edge
Contributors
lyapota
Source Code: GitHub - lyapota/s7e_marshmallow
Kernel Special Features:
Version Information
Status: Stable
Current Stable Version: 1.5.2
Stable Release Date: 2016-08-24
Created 2016-07-16
Last Updated 2016-08-24
XDA orginal Link : [KERNEL][G935F/G930F][Aug 05] Prometheus 1.3 | TW 6.0 MM | Aroma | Synapse
CHANGELOG
v1.5.2
+DVFS: added Decision Mode
+Synapse: added DVFS tab
*Thermal: restored ECT freq table
Installer change vendor GPU lib to r12p0 compatible.
Before switch to old kernel with r9p0 you must restore system first.
v1.5.1
+ added smartmax_eps CPU governor
*Thermal: ECT little modified for CLUSTER0, CLUSTER1.
v1.5.0
*base G935FXXU1BPH6
+Synapse.GPU: added option Enable/Disable TMU (thermal menagment).
+Aroma: added option to shift temperature levels on the 5 and 10 degrees (CLUSTER0, CLUSTER1 and GPU).
*Thermal: ECT corrected for wide freq tables (CLUSTER0, CLUSTER1 and GPU).
v1.4.0
*GPU driver updated to version r12p1
Installer change vendor GPU libs to r12p0 compatible.
v1.3.2
*RAMDISK: fix init.d support
v1.3.1
*RAMDISK: remade init.d support
*Synapse: allow write to "power_efficient"
v1.3
+Aroma: custom set CPU hotplugs MAX freq limit for 2 and 4 cores active (presets)
+F2FS support (select patch in aroma)
+N7 ports support (experemental)
*Revert MNGS hight freq voltage to ver 1.1
*Synapse: write read_ahead_kb into correct places for internal and external SD
v1.2
*base G935FXXU1APG3
*compiled with -Ofast
*a little tuned ASV algorithm
*removed ASV restrictions for BIG less then 11
v1.1
*updated f2fs support
+frandom driver
+more TCP Congestion
+ROW IO scheduling
+supersu support upped to ver 2.76
-back to gzip ramdisk compression
*Synapse: rolled up some tabs(A72, A53, GPU...)
*Synapse: restored build.prop tweaks
*Ramdisk: restored missed cortexbrain-tune.sh
v1.0
*base G935FXXU1APFG
+lz4 compression
*update Synapse support (@Tkkg1994)
*slightly improved aroma-config
v0.9
* speed Up to 2.9 GHz Mongoose
* speed Up to 1.8 Ghz Apollo
* a litlle weak of termal control
v0.8
+ LED Control
+ G930F/D model support (aroma)
* up to date thermal control
* a little aligned voltage tables
v0.7
+ FIOPS IO sched
+ UKSM
+ power suspend support
* restored power suspend logic in smartass2 CPU gov.
v0.6
first public release
1. TRWP öffnen
2. Cache und Dalvik wipen
3. Prometheus Kernel installieren
4. Aroma einstellungen vornehmen
5. Reboot'en
Meine Aroma settings :
MIN APPOLO - 338MHz
MAX APPOLO - 1,794GHz
MIN MONGOOSE - 312MHz
UP SCALE MONGOOSE - 2.8GHz
MAX MONGOOSE - 2.8GHz/2.7GHz
MAX Mali-T88x - 702MHz
Undervolting - 18.75
Reset dynamic freq - 5 sec
Use f2fs - Disallow
5. Reboot'en
MIN APPOLO - 338MHz
Use f2fs - Disallow
