Scum
Moderator
Teammitglied
- 11.806
Hatte die mal drauf gehabt aber mir ist nix negatives aufgefallen.
Downloads:ChangeLog:
HTC Rebase changes:
- Rebased to 4.19.401.8
- Added device support for Int, ATT, Tmous, Sprint and Verizon Props Hawknest & Baadnewz
- Added option to choose Stock or Blue theme in Aroma
- Almost all mods are ported
- Added Blue Bootanimation Props Cmylxgo
- Removed Flashplayer as Google withdraw support couple of months ago
- Added optional blue Beats bootanimation (Propss cmylxgo)
- Updated blue theme
- Added option to disable mtp notification Props Baadnewz
- Added option to disable htc sync notification Props Baadnewz
- Hide developers options by default in Settings due to some user errors causing the launcher and animation to break (Enable it again by ticking build version)
- Aroma dirtyflash detection script to prevent user errors while dirty flashing when it aint supposed to
- Added white battery % mod props Fisha21
- Disabled Quicktips Props Baadnewz
- Added several transparent status and navigation bar options
- And many more i forgot during cookt time
Tmous - AT&T Sprint & Verizon support still needs some testing so expect bugs
- Android 4.4.2 update
- Security enhancements
- Cloud Printing
- New Bluetooth Profiles to support more media interactions
- Support for FlashPlayer removed from browser
- White Battery Icon
Elegancia ONE v25.3.0
New release with new goodies, bugfixes and possible Device Model fixes.
With this release a couple of changes have made to take the rom in a certain direction.
Which is that all customizations mostly will be available in myHUB.
So to on the Aroma installer.
Why? to reduce rom size and the maintenance will be easier as for now i have maintain both rom and myHUB if something new is added.
This also count for the APM optional choice in Aroma
To many choices make to many variables, which is to hard to maintain and mistakes are easy to make as you can read in the last posts in the XDA thread.
Full Rom & OTA:
v25.3.0 will be due to request available as OTA or Full Rom .
In the main download page if stated what will be changed in OTA or Full Rom.
Some changes will only be applied in full rom as the OTA as mentioned earlier in the thread can't handle these deep system changes as a OTAcan't be seen as a HTC OTA but more as dirty flash.
OTA and risk of screwing up:
You will lose a lot of mods which you have installed.
Those mods are available in myHUB.
Also i can't count all mods you installed.
So there is a possibility that your device will not boot anymore after applying the OTA due to your manual taken actions to install mods.
Thats the downside of a rom to rom ota where i can't see what a individual user has done with his rom.
Tried to avoid this as much as i could.
So if your device aint booting or giving you force closes then download a full rom and flash it as full wipe before reporting anything.
Rom & OTA release schedule:
Rom is release after this post.
OTA will be released in phases just incase and to monitor the reports of the OTA on several device models![]()
OTA for International devices will be release at the same time as the release of the rom.
Other device model will release day by day.
OTA is avialable from 25.2.0 and 25.1.0
ChangeLog:
Sidenote for optional APM removal:
- Added volkey to skip track tweak Props Lyapota and Baadnewz thx for the port (Full rom / OTA)
- Added Captive buttonlight tweak Props Lyapota and Woodstock-(Full rom / OTA)
- Added advanced AutoBrightness tweak Props Lyapota and Woodstock-(Full rom / OTA)
- Added Long Press to Kill Apps tweak toggle Props Lyapota and Woodstock-(Full rom / OTA)
- Fixed Chinese language-(Full rom / OTA)
- Added myHUB Props Mikrosmile-(Full rom / OTA)
- Optimized Verizon support with stock Verizon files-(Full rom)
- Optimized Tmobile US support- Props Baadneqz & Hawknest (Full rom)
- Optimized ATTT Support-(Full rom)
- Optimized Sprint Support-(Full rom)
- Updated all Prism Ext Menu languages-(Full rom / OTA)
- Added Sense5 weather as default-(Full rom / OTA)
- Updated SystemUI png files-(Full rom / OTA)
- Optimized Transparent png files-(Full rom / OTA)
- Updated Theme-(Full rom / OTA)
- Massive rom unused files cleanup-(Full rom)
- Updated Playstore apps and Google Framework-(Full rom)
- Added Elegancia Wallpapers Props Manup456-(Full rom)
- Removed Advanced Power Menu as optional selection-(Full rom)
OTA Sidenote:
Also i cant count all mods you installed.
So there is a possibility that your device will not boot anymore.
Full Rom = Only available via Full Rom
OTA= available via Full Rom and OTA (ota available from 25.2.0 / 25.2.1 to 25.3.0)
