Import Fehler beim Navigation Drawer
Androide231198
Hallo Zusammen,
ich bin versuche gerade einen Navigation Drawer zu erstellen. Leider werden die Imports:
Code:
import android.support.design.widget.FloatingActionButton;
import android.support.design.widget.NavigationView;
import android.support.design.widget.Snackbar;
rot unterstrichen.
Der komplette Code der MainActivity sieht wie folgt aus:
Code:
package de.androidnewcomer.partypeople;
import android.os.Bundle;
import android.support.v4.view.GravityCompat;
import android.support.v4.widget.DrawerLayout;
import android.support.v7.app.ActionBarDrawerToggle;
import android.support.v7.app.AppCompatActivity;
import android.support.v7.widget.Toolbar;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
public class MainActivity extends AppCompatActivity
        implements Navigationview.OnNavigationItemSelectedListener {
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
        setSupportActionBar(toolbar);
            } FloatingActionButton fab = (FloatingActionButton) findViewById(R.id.fab);
            fab.setOnClickListener(new View.OnClickListener() {
                @Override
                public void onClick(View View) {
                    Snackbar.make(View, "Replace with your own action", Snackbar.LENGTH_LONG)
                            .setAction("Action", null).show();
        DrawerLayout drawer = (DrawerLayout) findViewById(R.id.drawer_layout);
        ActionBarDrawerToggle toggle = new ActionBarDrawerToggle(
                this, drawer, toolbar, R.string.navigation_drawer_open, R.string.navigation_drawer_close);
        drawer.setDrawerListener(toggle);
        toggle.syncState();
        NavigationView navigationView = (NavigationView) findViewById(R.id.nav_view);
        navigationView.setNavigationItemSelectedListener(this);
    @Override
    public void onBackPressed() {
        if (drawer.isDrawerOpen(GravityCompat.START)) {
            drawer.closeDrawer(GravityCompat.START);
        } else {
            super.onBackPressed();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
    @SuppressWarnings("StatementWithEmptyBody")
    @Override
    public boolean onNavigationItemSelected(MenuItem item) {
        // Handle navigation view item clicks here.
        android.app.FragmentManager fragmentManager = getFragmentManager();|
        if (id == R.id.nav_first_layout) {
            fragmentManager.beginTransaction()
                    .replace(R.id.content_frame, new FirstFragment())
                    .commit();
        } else if (id == R.id.nav_second_layout ) {
                    .commit();
        } else if (id == R.id.nav_third_layout) {
                    .commit();
        } else if (id == R.id.nav_share) {
        } else if (id == R.id.nav_send) {
        return true;
Könnte mir bitte jemand helfen?
Schöne Grüße
Andro
a) lösche mal alle Imports
b) gehe dann an das ende der jeweilig rot gefärbten Zeilen und drücke ALT + ENTER
leider steht nur folgendes zur auswahl, wenn ich Alt und Enter drücke:
"Create Test", "Create Subclass", "insert APP Indexing api code" und "make package lokal"
Hat jemand eine Lösung für dieses Problem?
Schöne Grüße
Dominik
  • Data2006
jogimuc
  • AnimaAngelo85
swa00
swa00
  • Sempervivum
Sempervivum
