Problem mit Android ViewPagerIndicator
  • 0 Antworten
Cracksoldier
Hi, Ich habe die letzten 2 Tage mit dem Versuch verbracht die folgende
Bibliothek per Maven zu installieren:
https://github.com/JakeWharton/Android-ViewPagerIndicator
Maven und das JDK sind ordnungsgemäß installiert. Wenn ich jedoch
versuche die Bibliothek per "mvn install" zu installieren erhalte ich
folgende Ausgabe in der CMD:
Code:
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for com.viewpagerindicator:library:apklib:2.2.0
[WARNING] 'build.plugins.plugin.version' for com.jayway.maven.plugins.android.generation2:maven-android-plugin is missing. @ line 36, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for com.viewpagerindicator:sample:apk:2.2.0
[WARNING] 'build.plugins.plugin.version' for com.jayway.maven.plugins.android.generation2:maven-android-plugin is missing. @ line 48, column 12
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Build Order:
[INFO]
[INFO] Android-ViewPagerIndicator (Parent)
[INFO] Android-ViewPagerIndicator Sample
[INFO]
[INFO] Building Android-ViewPagerIndicator (Parent) 2.2.0
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ parent ---
[INFO] Installing C:\Users\Cracksoldier\Desktop\JakeWharton-Android-ViewPagerIndicator-3db7585\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\viewpagerindicator\parent\2.2.0\parent-2.2.0.pom
[INFO]
[INFO] Building Android-ViewPagerIndicator 2.2.0
[WARNING] The POM for android.support:compatibility-v4:jar:r4 is missing, no dependency information available
[INFO] Reactor Summary:
[INFO]
[INFO] Android-ViewPagerIndicator (Parent) ............... SUCCESS [0.334s]
[INFO] Android-ViewPagerIndicator ........................ FAILURE [0.169s]
[INFO] Android-ViewPagerIndicator Sample ................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1.839s
[INFO] Finished at: Wed Dec 21 22:28:52 CET 2011
[INFO] Final Memory: 10M/108M
[ERROR] Failed to execute goal on project library: Could not resolve dependencies for project com.viewpagerindicator:library:apklib:2.2.0: Failure to find android.support:compatibility-v4:jar:r4 in http://r.jakewharton.com/maven/release was cached in the local repository, resolution will not be reattempted until the update interval of com.jakewharton has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :library
Durch meinen Eintrag unter Issues habe ich vom Coder erfahren das ich
bei den Depencies auf r6 umstellen muss und hier beginnt mein Problem
und zwar wenn ich die "pom.xml" bearbeite und unter den Eintrag
unter Depencies bearbeite bleibt der Fehler erhalten. Ich habe folgende
Variationen ausprobiert:
compatibility-v4-r6
compatibility-v6
compatibility-r6
Desweiteren habe ich auch versucht die Android Support Version auf
r6 zu setzen aber es hat auch nix gebracht er findet die benötigte
Library einfach nicht.
Nun hatte ich gehofft das hier vlt. schon jemand Erfahrung mit der
Bibliothek gemacht hat und mir vlt. helfen kann oder mir ein aktuelles
Tutorial empfehlen kann. Habe bisher noch keinerlei Erfahrungen mit
Maven daher kann es sein das es ein leichtes Problem ist aber ich
steh gerade total an.
Ich habe auf der Issue Site von github auch einen Threat eröffnet:
https://github.com/JakeWharton/Android-ViewPagerIndicator/issues/40
Und habe den maven-android-sdk-deployer installiert. Wobei ich jedoch
folgende Meldung erhalte:
Code:
[INFO]
[INFO] Maven Android SDK Deployer
[INFO] Android Platforms
[INFO] Android Platform 1.5 API 3
[INFO] Android Platform 1.6 API 4
[INFO] Android Platform 2.1 API 7
[INFO] Android Platform 2.2 API 8
[INFO] Android Platform 2.3.3 API 10
[INFO] Android Platform 3.0 API 11
[INFO] Android Platform 3.1 API 12
[INFO] Android Platform 3.2 API 13
[INFO] Android Platform 4.0 API 14
[INFO] Android Platform 4.0.3 API 15
[INFO] Android Add-Ons
[INFO] Android Add-On Google Platform 1.5 API 3 (Maps)
[INFO] Android Add-On Google Platform 1.6 API 4 (Maps)
[INFO] Android Add-On Google Platform 2.1 API 7 (Maps)
[INFO] Android Add-On Google Platform 2.2 API 8 (Maps)
[INFO] Android Add-On Google Platform 2.3.3 API 10 (Maps and USB)
[INFO] Android Add-On Google Platform 3.0 API 11 (Maps)
[INFO] Android Add-On Google Platform 3.1 API 12 (Maps and USB)
[INFO] Android Add-On Google Platform 3.2 API 13 (Maps and USB)
[INFO] Android Add-On Google Platform 4.0 API 14 (Maps and USB)
[INFO] Android Add-On Google Platform 4.0.3 API 15 (Maps and USB)
[INFO] Android Extras
[INFO] Android Compatibility Extra V4
[INFO] Android Compatibility Extra V13
[INFO]
[INFO] Building Maven Android SDK Deployer 1.1.2
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ maven-android-sdk-deployer ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\maven-android-sdk-deployer\1.1.2\maven-android-sdk-deployer-1.1.2.pom
[INFO]
[INFO] Building Android Platforms 1.1.2
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-platforms ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-platforms\1.1.2\android-platforms-1.1.2.pom
[INFO]
[INFO] Building Android Platform 1.5 API 3 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-3 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-3 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-3\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-3\1.1.2\android-3-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-3 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-3\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\1.5_r4\android-1.5_r4.jar
[INFO]
[INFO] Building Android Platform 1.6 API 4 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-4 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-4 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-4\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-4\1.1.2\android-4-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-4 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-4\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\1.6_r3\android-1.6_r3.jar
[INFO]
[INFO] Building Android Platform 2.1 API 7 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-7 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-7 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-7\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-7\1.1.2\android-7-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-7 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-7\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\2.1_r3\android-2.1_r3.jar
[INFO]
[INFO] Building Android Platform 2.2 API 8 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-8 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-8 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-8\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-8\1.1.2\android-8-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-8 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-8\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\2.2_r3\android-2.2_r3.jar
[INFO]
[INFO] Building Android Platform 2.3.3 API 10 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-10 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-10 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-10\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-10\1.1.2\android-10-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-10 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-10\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\2.3.3_r2\android-2.3.3_r2.jar
[INFO]
[INFO] Building Android Platform 3.0 API 11 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-11 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-11 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-11\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-11\1.1.2\android-11-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-11 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-11\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\3.0_r2\android-3.0_r2.jar
[INFO]
[INFO] Building Android Platform 3.1 API 12 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-12 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-12 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-12\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-12\1.1.2\android-12-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-12 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-12\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\3.1_r3\android-3.1_r3.jar
[INFO]
[INFO] Building Android Platform 3.2 API 13 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-13 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-13 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-13\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-13\1.1.2\android-13-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-13 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-13\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\3.2_r1\android-3.2_r1.jar
[INFO]
[INFO] Building Android Platform 4.0 API 14 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-14 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-14 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-14\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-14\1.1.2\android-14-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-14 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-14\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\4.0_r3\android-4.0_r3.jar
[INFO]
[INFO] Building Android Platform 4.0.3 API 15 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ android-15 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-15 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\platforms\android-15\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-15\1.1.2\android-15-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ android-15 ---
[INFO] Installing D:\Programme\Android\android-sdk\platforms\android-15\android.jar to C:\Users\Cracksoldier\.m2\repository\android\android\4.0.3_r1\android-4.0.3_r1.jar
[INFO]
[INFO] Building Android Add-Ons 1.1.2
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ android-add-ons ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\add-ons\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\android-add-ons\1.1.2\android-add-ons-1.1.2.pom
[INFO]
[INFO] Building Android Add-On Google Platform 1.5 API 3 (Maps) 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ google-apis-3 ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ google-apis-3 ---
[INFO] Installing C:\Users\Cracksoldier\Downloads\mosabua-maven-android-sdk-deployer-101ffe3\add-ons\google-apis-3\pom.xml to C:\Users\Cracksoldier\.m2\repository\com\simpligility\android\sdk-deployer\google-apis-3\1.1.2\google-apis-3-1.1.2.pom
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install-file (default) @ google-apis-3 ---
[INFO] Installing D:\Programme\Android\android-sdk\add-ons\addon-google_apis-google_inc_-3\libs\maps.jar to C:\Users\Cracksoldier\.m2\repository\com\google\android\maps\maps\3_r3\maps-3_r3.jar
[INFO]
[INFO] Building Android Add-On Google Platform 1.6 API 4 (Maps) 1.1.2
[INFO]
[INFO] --- properties-maven-plugin:1.0-alpha-2:read-project-properties (default) @ google-apis-4 ---
[INFO]
[INFO] Maven Android SDK Deployer ........................ SUCCESS [0.382s]
[INFO] Android Platforms ................................. SUCCESS [0.020s]
[INFO] Android Platform 1.5 API 3 ........................ SUCCESS [0.266s]
[INFO] Android Platform 1.6 API 4 ........................ SUCCESS [0.082s]
[INFO] Android Platform 2.1 API 7 ........................ SUCCESS [0.050s]
[INFO] Android Platform 2.2 API 8 ........................ SUCCESS [0.061s]
[INFO] Android Platform 2.3.3 API 10 ..................... SUCCESS [0.053s]
[INFO] Android Platform 3.0 API 11 ....................... SUCCESS [0.074s]
[INFO] Android Platform 3.1 API 12 ....................... SUCCESS [0.068s]
[INFO] Android Platform 3.2 API 13 ....................... SUCCESS [0.072s]
[INFO] Android Platform 4.0 API 14 ....................... SUCCESS [0.065s]
[INFO] Android Platform 4.0.3 API 15 ..................... SUCCESS [0.078s]
[INFO] Android Add-Ons ................................... SUCCESS [0.010s]
[INFO] Android Add-On Google Platform 1.5 API 3 (Maps) ... SUCCESS [0.129s]
[INFO] Android Add-On Google Platform 1.6 API 4 (Maps) ... FAILURE [0.003s]
[INFO] Android Add-On Google Platform 2.1 API 7 (Maps) ... SKIPPED
[INFO] Android Add-On Google Platform 2.2 API 8 (Maps) ... SKIPPED
[INFO] Android Add-On Google Platform 2.3.3 API 10 (Maps and USB)  SKIPPED
[INFO] Android Add-On Google Platform 3.0 API 11 (Maps) .. SKIPPED
[INFO] Android Add-On Google Platform 3.1 API 12 (Maps and USB)  SKIPPED
[INFO] Android Add-On Google Platform 3.2 API 13 (Maps and USB)  SKIPPED
[INFO] Android Add-On Google Platform 4.0 API 14 (Maps and USB)  SKIPPED
[INFO] Android Add-On Google Platform 4.0.3 API 15 (Maps and USB)  SKIPPED
[INFO] Android Extras .................................... SKIPPED
[INFO] Android Compatibility Extra V4 .................... SKIPPED
[INFO] Android Compatibility Extra V13 ................... SKIPPED
[INFO] Total time: 1.912s
[INFO] Finished at: Thu Dec 22 16:19:43 CET 2011
[INFO] Final Memory: 7M/108M
[ERROR] Failed to execute goal org.codehaus.mojo:properties-maven-plugin:1.0-alpha-2:read-project-properties (default) on project google-apis-4: Properties file not found: D:\Programme\Android\android-sdk\add-ons\addon-google_apis-google_inc_-4\source.properties -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR]   mvn <goals> -rf :google-apis-4
Ich habe auch alle Google APIs neu installiert wie auf der Developer
Site beschrieben aber ich komme einfach nicht mehr weiter.
MFG Cracksoldier
Katharina1985
Anz
Anz
swa00
swa00
Mr-Fisch
migi01
migi01
Mr-Fisch
Mr-Fisch
Mr-Fisch
mkuz24
