zacharias
Stammgast
- 639
SGS edition of the Platypus Revolutions kernel
This Project is inactive/low activity for a longer period of time
Kernel
CM7 & MIUI only
NEO series
(since May 24th '11)
(thanks to Tk for the layout idea )
before you ask for any ETAs:
The first rule of CyanogenMod [and this project]: DO NOT ASK FOR AN ETA!
First step before install & kernel switch:
Always have this cleaning script on your internal SD card ready
If you're switching kernels, have issues with auto-rotation, the cam, bootloops or other sorts of problem (failed overclock attempt),
please use lippol94's updated cleaning script (apply via CWM recovery) :Multiupload.com - upload your files to multiple file hosting sites!
Introduction:
Hi guys,
this is my first modded kernel for the SGS (CM7/MIUI only)
I first needed to test it to make sure that it'll be stable & boot at the first place
so far it's very fast & responsive & smooth
This thread shall serve as the center for my testing kernels (stability & functionality-wise)
DISCLAIMER: the kernel (binary) and driver modules are provided as is. If problems occcur they most probably are from upstream and can be fixed with the newest version. Since I'm doing this in my free spare time as a hobby (quenching my thirst for tweaks & performance) updates will occur irregularly as time permits and I see fit (most probably when new features & bugfixes arrive). YOU are responsible for the actions that you take (such as over- or underclocking), etc. You agree that I can not be held liable for any potential damage that arises from your actions in combination with or the usage of this kernel and other related parts.
Kudos:
* Google, Andy Rubin & the whole Android crew
* Linus Torvalds & the kernel hackers for upstream Linux
* cyanogen & all the devs out there hacking on this
* Supercurio for enriching our media experience of this smartphone
* codeworkx, coolya, guiper, atinm - the whole teamhacksung|cmsgsteam crew and all other hackers working on CM7
* laststufo, hardcore, nikademus, existz and all the other kernel hackers on the SGS forum
* zen-kernel team for inspiration to create a kernel, too
* all other contributors (devs, users, etc.) who make this possible
The purpose of these kernels is extensive stability testing addressing the following sticking points:
- overall stability & functioning of the kernel and phone
- call drops, missed calls, etc.
- lags (suggestions for improvements are welcome)
- auto-rotation, sensors, etc.
- Voodoo Control Plus [any crashes ? compatibility problems ?]
- working on CM7 or MIUI ?
- scheduler, sound, video synchronisation & lags: Tap Tap Revenge 4 (especially at the beginning of songs)
- scheduler, sound, video synchronisation and any other issues: doodle dash (while shooting & sound activated)
- proper pmem memory layout & settings: proper functioning of Google Googles
for those who love SAUCE (Source):
old source:
ALL MY SAUCE for QUORRA KernalZ ^^
new source:
android_kernel_samsung_aries
(fork and 1:1 update to upstream kernel source - changes in different branches)
(latest changes sometimes might not be in [yet] but in the whole repo everything should be available)
current UV & OC stable values:
Recommended apps for OC/UV:
- Pimp my CPU (also available here on XDA for those who don't have a credit card, etc.)
- Xan's VoltageControl
on stability testing:
xda-developers - View Single Post - [KERNEL]05.12.2011 test-kernels [CM7/MIUI] platypus;SECURITY,VOODOO,OC/UV,nodebug,...
(start with "Q: I'm new in OC/OV operations so please could you explain to me how to set it in the best way?")
the following OC/UV values are only applicable for kernels with the old OC/UV implementation (max. 1.3 GHz)
my current UV (undervolt) stable Values :
old OC/UV implementation (morfic, bilboa1/kang, TheEscapist):
1300000 0 (haven't tested 1.3 GHz much yet)
1200000 -25
1000000 -50
800000 -75
600000 -100
400000 -100
200000 -125
100000 -150
edit:
1200000 -50
1000000 -75
800000 -75
600000 -225
400000 -125
200000 -150
100000 -175
thanks jetcz !
new OC/UV implementation (morfic, bilboa1/kang, TheEscapist - Tk-Glitch):
3D performance and games:
recommended apps:
[root] Chainfire3D
Kernel
CM7 & MIUI only
NEO series
Do you want to discuss on this kernel, get the news on the current state of development, or test kernels even fresher than fresh ?
connect via webchat from your browser:
QuakeNet Web IRC (qwebirc)
and join #platypus-kernel
(recommended)
Fire up your IRC client, and join via client
the server (for now is) : irc.quakenet.org
port : 6667
Channel : #platypus-kernel
(recommended)
port : 6667
Introduction:
Hi guys,
Kudos:
old source:
new source:
1200000 -25
1000000 -50
800000 -75
600000 -100
400000 -100
200000 -125
100000 -150
edit:
1200000 -50
1000000 -75
800000 -75
600000 -225
400000 -125
200000 -150
100000 -175
thanks jetcz !
Tk-Glitch schrieb:Note that these UV settings will be unstable on many devices. It's only informative.
1600 MHz - 1.500v / -> That's high and many devices will fail on this frequency. Find working UV for you if any.
1500 MHz - 1.500v / -> That's high and many devices will fail on this frequency. Find working UV for you if any.
1440 MHz - 1.475v / -75mv
1400 MHz - 1.450v / -75mv
1300 MHz - 1.400v / -75mv
1200 MHz - 1.350v / -75mv
1000 MHz - 1.250v / -50mv - If you have stability issues, try to let this one by default.
800 MHz - 1.200v / -75mv
400 MHz - 1.050v / -100mv
200 MHz - 0.950v / -150mv
100 MHz - 0.950v / -200mv - (can be very different between two devices)
More volts is not always equal to more stability. Try to add more UV (less volts) if the frequency you're trying to achieve is unstable.
Considering all phones will respond differently to OC/UV, to tweak the values to suit your device will be required.
By default, no overclock/undervolt is applied. You'll need to use one of the tools below to adjust the frequencies and voltages.
Note : Never ever use SetCPU with this kernel. You could encounter many stability problems like random reboots or bootloops.
recommended apps:
[root] Chainfire3D
This will be the last kernel for some time since I need to take care of personal things
I will still continue development on the Talon/Platypus Kernels in the background but will
keep a "small footprint" on XDA and phone-related stuff
All what you post will be read but I most likely will only answer what not already has been asked and e.g. some troubleshooting, etc.
Thanks for your understanding
