Cloud
Moderator
Teammitglied
- 18.985
Version Information
- Status: Beta
- Original Thread XDA
- Source Code
- Changelog
- Kernel Thread
Bugs
- Bluetooth Audio funktioniert mit manchen Geräten nicht richtig
- Sollte sich LTE beim Boot nicht aktivieren lassen -> einmal APN wechseln und wieder zurück
- Wifi Standby Bug behoben !!!!! (Kernel)
Features
ROM:
- Using the CyanogenMod 13 Nightly base
- Built with the UBER GCC 4.9.x Toolchain
- Compiled with optimized compiler flags by @Arter97
- Add ability to hide SU icon in statusbar, off by default (Settings > Status Bar)
- Add switch to enable full-screen recents (Settings > Developers Options)
- Added Quick Unlock for PIN Lockscreens
- Tweaked Ambient Display schedule
- Display the current app being optimized during boot
- Smoother Upload/Download status bar animation
- Improve scrolling and scrolling cache
- Sped up framework animations slightly
- Update stock audio to the Nexus 5 factory image audio
- Added SuperSU to Settings menu, if installed
- Developer Options should be enabled by default
- Allow MultiWindow option to be shown in userdebug builds
- Slightly tweaked ART and bionic repos thanks to @Arter97
- Updated jemalloc and SQLite repos thanks to @Arter97
- AdAway v3.1 included
- Marshmallow bootanimation included from here
- Added default Nexus 6P wallpaper, removed default live wallpapers
- Updated to the linux 3.4.110 kernel base
- Built with UBER GCC 5.2.x Toolchain
- Intelli-plug Hotplug, MPDecision disabled
- Intelli-plug
- Added Sweep2Sleep. Sweep from above the Back button across to above the Menu button to put screen to sleep.
- Sensors: Add SM-S975L and SGH-S970G to variants list
- Updated Interactive CPU Governor from @temasek's Hlte kernel
- Updated CPU boost driver from @temasek's Hlte kernel
- ROW I/O Scheduler set by default
- CPU Voltage Control
- Dynamic Fsync toggle (disabled by default)
- Power Efficient Workqueues for powersaving
- Enabled SCHED_AUTOGROUP for better multitasking
- Westwood TCP congestion algorithm enabled by default
- Reduced bcmdhd wakelocks
- Modified Ramdisk
- Many more various tweaks that can be found here
Downloads
Installation
Bitte nur installieren, wenn ihr wisst, was ihr tut.
Jeder ist für sich und eventuelle Schäden, die durchaus möglich sind, selbst verantwortlich.
Durch das Flashen erlischt deine Herstellergarantie! (KNOX Warranty Void 0x1).
- Data und Cache Partitionen können bei Bedarf in F2FS konvertiert werden. (empfohlen)
- Wenn ihr von einer anderen ROM kommt -> FullWipe
- Wenn ihr von einer CM12/CM12.1 ROM kommt -> FullWipe
- Wenn ihr von einer CM13 Build kommt -> FullWipe
- Backup, Backup, Backup! Bevor ihr flasht immer ein Backup des aktuellen funktionierenden Systems erstellen
- ROM zip und passende GApps runterladen
- Alle zip-Files auf die externe SD-Karte packen
- Neustart ins Recovery
- Advance Wipe " /System /Data /Cache /Dalvik /Internal Storage "
- Bei Bedarf Partitionen zu F2FS konvertieren
- Wähle "Install zip from SDcard"
- Installiere ROM zip file
- Installiere GApps zip file
- System neustarten
Update einer bereits installierten Synergy-ROM
- Aktuelle ROM-Version und passende GApps runterladen
- Advanced Wipe " /System /Cache /Dalvik Cache " [/system bei Bedarf]
- Installiere GApps zip file (Nur wenn /system gewiped wurde)
- Advanced Wipe " /Cache /Dalvik Cache "
- System neustarten
Der erste Bootvorgang kann nach dem installieren/updaten bis zu 5 Minuten dauern. Also Geduld.
"Features" ist 1:1 von Synergy´s Thread in XDA übernommen und wird von Zeit zu Zeit aktualisiert!
Solltet ihr Fehler entdecken oder etwas wissen das in den Startpost gehört -> PN an mich!
Anmerkung der Moderation:
Fragen und Diskussionen zum Kernel kommen bitte nach hier.
https://www.android-hilfe.de/index.php?threads//
Danke
Bearbeitet von:
COB93
- Grund: Ergänzt
