[ROM]EQDKP Sense 3.5 idogx base [SENSE 3.5 zero][deutsch]
ONeill
ONeill
Ehrenmitglied
6.091
Hallo Leute,
wie versprochen auch noch ein deutsches Sense 3.5 Rom, bisher noch das einzige ;)
zu finden in xda:
[ROM] EQDKP Sense 3.5 - GB2.3.5 idogx base - OC [m1ndh4x8r mod] 2-19-12 - xda-developers
Eckdaten
Based off the HTC_Marvel_idogx_2.3.5_Sense3.5_0210 -
HTC framework themed with battery percentage and overscroll glowing effect. 4X5 Rosie, changed htc wallpapers
Overclocked kernel. with tun,cifs,utf8
Rooted with the latest version of Superuser and Busybox, Zipaligned
sio IO added including the use of ext4 with writeback journaling for all mounts and larger read-ahead buffer for improved sdcard performance.
Extended Quick Settings and Extended Reboot Menu
Deodexed
Add Google Accounts in Sync, Maps, Gmail, ES File Explorer, Flash player, Adfree, Gingerbread Keyboard, Nofrills, Terminal, Youtube
Download
Download
Credits
Google
HTC
idogx
Football
Quens
Hintay
Team Hydra
mstfkaratas
matt5eo
d33ps1x
djpbx
SummerL
Changelog
4.2
Added:
bravia engine by djpbx
Gps Fix by d33ps1x
Facebook App
SummerL bootanimation and sound
Multilanguage fix by mstfkaratas
Camcorder lag and flash fix by matt5eo
Removed android and HTC spyware
4.1
Unofficial kang fix from Hintay 3.5 ROM
Add other language: Arabic, Bulgarian, Danish, German, Greek,Spanish, Finnish, French, Croatian, Hungarian, Italian, Dutch, Polish, Portuguese, Russian, Slovak, Slovenian, Swedish, Czech, Japanese, Korean, Thai, Turkish, Vietnamese etc
Update Google Services Package
Change Weather Sync Provider to AccuWeather proxy
Add HTC Quick Lookup from Euprop RUU and add other languages
Account Sync Manager fixed
A little fix in build.prop
hast du eine Ahnung wie es hier mit app2sd aussieht?
das native App2SD funktioniert super, Link2SD hat bei mir leider nicht funktioniert :(
ist es komplett deutsch oder nur die apps also wie bei der app "more locals"?
interner speicher wieder bei 75 mb schätze ich?
ich bin direkt wieder zurück aufs cm
zu wenig speicher
aber sieht hübsch aus
edit ist komplett deutsch auswählbar
gut dann werd ich es mal draufschmeissen :)
an den anderen ports hat es mich gestört dass es einfach nur englisch ist.
ich kann zwar gut englisch aber es nervt irgendwie.
gegen den speichermangel gibt es ja ein paar abhilfen.
Habs mir auch grad draufgeschmissen, dass einzige Problem ist wirklich mit dem internen Speicher.
Werde mir wieder CM 7.2 draufpacken
Der speicher ist wirklich ein wenig gering. Soll aber bei anderen 3.5 ports behoben werden.
Ist wie bereits gesagt komplett deutsch, nur einzelne fehlermeldungen sind ggf. Auf english, aber das kriegt man auch hin ;)
Hab's jetzt auch mal auf dem WFS meines Sohnes installiert, er ist begeistert vom "Look & Feel". Link2sd funktioniert mit der aktuellen Version (4.5), damit komme ich auf 35-40MB freien Speicher. Weniger, aber erstmal ausreichend. Mal schauen was da noch an Verbesserungen kommt.
CU
Waldi
Bin ich auch mal gespannt. Allerdings muss ich sagen, das da in letzter zeit nicht viel gekommen ist. Wenn es was großes gibt, schreibe ich nochmal.
Zur not auf das .sense rom umsteigen, ist mindestens genauso gut, wenn nicht besser.
Gesendet von meinem HTC Wildfire S mit der Android-Hilfe.de App
also ich wollte das Rom installieren aber irgendwie hänge ich in der Bootschleife!?
Muss ich da irgendwie nen Kernel installieren oder so?
ich hab mein WFS mit dem HTCDEV Tool entsperrt und CWM draufgeschmißen Kernel ist noch gleich...
nein, du musst nur einen Full Wipe machen:
Wipe
also ich hab den
Data Reset
Clear Cache
Dalvik Cache
das hab ich alles gemacht?
und nach dem installieren des Rom hab ich das beats audio addon installiert aber habs dann ohne Addon getestet geht auch nicht...
aber wenn ich doch auf Werkseinstellungen zurücksetze geht doch Root CWM und alles verloren?
NEIN!!! Werkseinstellungen bezieht sich auf das Rom. Soll heißen, das die /data-Partition gelöscht wird. Mehr nicht.
Wie lange wartest du, bis du das Warten aufgibst? Der erste Start kann bei nem Sense 3.5 Rom bis zu einer halben Stunde dauern!
achso so 10 min
also nur die Caches leeren wie schon gemacht dann warten?
Dauert das dann immer so lang oder nur beim ersten mal ??
wo muss ich den FullWipe machn?
Es dauert nur beim ersten mal so lange
FullWipe: Wipe cache, wipe data, (wipe dalvik cache)
INFO:
Ich werde über dieses Rom keine weiteren Infos mehr aus dem xda-Forum hierher übernehmen. Solltet ihr also weiterhin auf den neuesten Stand über dieses Rom bleiben wollen, so nutzt bitte den im 1. Post gegebenen Link.
Danke!
Hat die ROM zufällig jemand im Einsatz? Hatte von anfang an Probleme mit der Facebook-App. Hab deshalb eben mal die ROM auf den aktuellen Stand gehoben. App funktioniert aber irgendwie immernoch nicht. Bekomme immer die Meldung: Beim Laden dieser Seite ist ein Fehler aufgetreten.
Neuinstallation der App brachte keine Verbesserung. Weiß jemand was das sein kann?
Gesendet von meinem HTC A510e mit der Android-Hilfe.de App
  • Kevinjoa
Kevinjoa
TSC Yoda
TSC Yoda
TSC Yoda
djolivier
Softterrier
