[ROM]ICE_DS v.4.1 ICS | 4.0.4 | Sense 3.6 | 4.10.405.1
Specimann
Specimann
Hey Gemeide ich dachte mir da ich mit der Rom sehr zufrieden bin und ich die hier noch nicht gesehen habe poste ich sie mal :)
ICE DS v 5.2
ICS 4.0.4 Sense 3.6 Stock​
Based in official RUU ICS_35_S_HTC_WWE_14.01.401.2​
Screens im Originalpost von xda
Features:
- Based on RUU ICS_35_S_HTC_WWE_14.01.401.2 release-keys HTC Desire S
- Tweaked kernel v 7.1 - 3.0.43-amidabudha
- AOSP Lockscreen (optional)
- Bravia Engine Service (optional)
- HTC IME with arrows (optional)
- HTC Notes
- This is improved version of stock ROM - no visual changes!
- Very fast, clean & stable!
- Full HTC Sense 3.6 Interface
- Multi-language (WWE)
- ROOT (su + SuperSu Permissions - Thanks to chainfire)
- JB animations
- HTC IME without arrows
- Super Full Beats Audio (optional)
- RAM optimizations
- init.d scripts (BusyBox run-parts) support
- Excellent battery life!
- Improved EXT4 performance
- more...
How to install:
1.Download "Full_wipe_DS.zip"
2.Install "Full_wip_DS.zip"
3.Wipe Cache + Dalvik cache
4.Install Zip
5.Reboot
6.Enjoy
Download:
v 5.1
Mirror 1
Mirror 2
v 5.1
Mirror 1
Mirror 2
FullWipe DS
OLD ROM:
v 4.4
Mirror 1
Mirror 2
md5: 73a572f878ef042c34afd6d767ee5e91
Mod's:
Alle Files übers Recovery flashen (Backup vorher nicht vergessen!)
Circle Battery (JB animations)
Honeycomb battery (JB animations)
Change log:
version 5.2:
- cleared for the best productivity and speed (with the first start of system Antutu benchmark shows 3200)
- removed some useless bloatware to fit on our system partition
- fixed init.d (removed all superfluous)
- added AOSP Lockscreen (optional)
- removed: andrev oc, OC/UV Beater, Leedroid tweaks etc...
- now ROM really FAST, STABLE, CLEAN and Excellent battery life!
version 5.1:
- added tweaked kernel v 7.1
- fixed vdd_levels (-50 for all & -100 for up to 1GHz)
- added andrev oc instead of virtuous oc
- added A-GPS patch Google build v 3.1
- fixed links issue
- fixed sweep2wake function (work correct)
- Camera quality tweaks
- build.prop tweaks for increased performance - link
- added sense 4 clock widget (optional)
- added HTC Sense Advanced Power Menu - shortcuts, recovery etc.
- added Overscroll Glow (white)
- fixed autobrightness
- Battery life is better now ;)
- more..
version 5.0:
- re-based to official RUU ICS_35_S_HTC_WWE_14.01.401.2 release-keys HTC Desire S
- added tweaked kernel v 5.0
- added OC/UV Beater 2 v 1.5 + virtuous oc
- Aroma installer
- build.prop tweaks
- more...
version 4.4:
- added LeeDroid Tweaks v 4.3 (thanks m0narX)
- Enable GPU rendering for 2D operations (thanks mike1986)
- new Modified Stock 3.0.16 kernel 1.5 GHz - optional (amidabuddha)
- HTC stock Camera
- fixed wifi
- beats audio skins for Music player
- added Hosts file
- Some init.d script changes and tweaks
- Lots more I have forgotten
version 4.3:
- build.prop tweaks
- Activated HW acceleration - smoother scrolling
- added Full Beats Audio
- added HTC Notes with widget
- Small framework tweaks
- changed bootanimation (HTC with beats audio)
- Antutu benchmark - 3056 !!! (SD 16Gb class4)
- Don't forget to Donate something if you like the work ;)
version 4.2:
- HQ Camera Ultra v 1.5 40mpbs - updated Camera to model with HQ picture compression and high bitrate videos - http://forum.xda-developers.com/show....php?t=1533238
- JB animations
- fixed mobile data connection
- Quick Boot from Play store
- Extended quick settings
- Car Home
- Custom wallpaper
- Updated all apps - SuperSu 0.94, Dropbox 2.1.7, Facebook 1.9.7, Adobe Flash Player 11.1.115.12, Adobe Reader 10.3.0, ES File Explorer 1.6.1.7, Twitter 3.3.1.
- fixed sounds
- more...
version 4.1:
- more free system memory
- SuperSU instead SuperUser
- RAM optimizations
- Sony Bravia Engine - HQ Image and Movie improvement (Optional)
- fixed FaceLock
- added more Multi-language (WWE)
- build.prop tweaks
- more..
version 4.0
- Rebased to RUU 4.10.405.1 release-keys HTC Incredible S (VIVO)
- HTC 3.0.16 Stock Kernel
version 3.0
- Rebased to RUU 3.04.401.1 test-keys HTC Desire S (SAGA)
- HTC 3.0.16 Kernel
- looks the description
version 2.0
-without aroma
-new LeeDroid tweaks (full work after install patch fix)
-stock battery with %
-add wifi tether
-wifi wake up issue fix
-add MX Video Player
-full Sense 3.6
-more...
version 1.1.1
-fix call sounds
-fix bluetooth sounds
-full beats audio
-more...
version 1.0.2
- some tweaks build.prop
- fix battery mod with %
- add new bootanimation
- clean and optimized rom
- some more...
version 1.0.1
- fix bootanimations
- fix playing video (use gallery)
- some more..
version 1.0
-initial release
Reaktionen: teeno
Bei mir klappen die Hotfile Downloads nicht ?!
Nachdem klicken auf "normaler Download" lädt die Seite ewig (nach dem die Wartezeit runter gelaufen ist) und danach wird mir angezeigt, dass die Webseite nicht verfügbar ist....
Also ich hab gerade getestet und ih kann es ohne probleme runterladen. Werde trotzdem es mal wo anders hochladen :)
Reaktionen: stoeppy
Super danke dir.
Dafür solltest du dir aber die Erlaubnis vom Entwickler holen.
Mirrors sind nicht gern gesehen.
Warum eigentlich? *blödfrag*
Vielleicht, weil der Entwickler die Kontrolle über seine Arbeit haben möchte?
Ein Beispiel:
Werden Bugs entdeckt, entfernt der Dev i.d.R. seinen Download und stellt einen neuen zur Verfügung.
Auf Mirrors hat er keinen Einfluss und die verbugten ROMs bleiben weiter im Umlauf usw.
Ich hätte ihn gefragt :) bin gerade dabei ihn zu schreiben :)
Reaktionen: stoeppy
ah ok, soweit hatte ich nicht gedacht :rolleyes2:
Und, wie ist denn die Rom? Bisher war ich von allen ICS Roms total enttäuscht... welche Kamera ist denn da jetzt bei? (ist ja auch noch eine andere flashbar?) Hätte einer Screenshots von den unterschiedlichen Versionen?
Also ich hab Sie drauf und ich find sie einfach nur geil :) Läuft alles schnell und flüßig hab auch bis jetzt kein fehler gefunden.
Kamera weiss nicht genau hab die andere geflashed und bin damit echt zufrieden.
Nur zur Info:
Heute Nacht ist die erste Full Sense 4 ROM erschienen.
Inclusive Homescreen im Landscape Modus!
Ja also ich hab bis jetzt jede die ich hatte schlechte erfahrung daher bleib ich erstmal bei der ICE_DS :)
Hab nen anderen Download link für v 4.1 hinzugefügt falls hotfile nicht klappt.
Reaktionen: Snirg0r und stoeppy
wird bei der installation auch gleich ein radio update gemacht oder müsste ich um die "empfohlene version" zu verwenden separat flashen? wenn separat, hättest du dann zufällig nen passenden link dazu? müsste ich das dann vor der installation vom ics machen oder geht das auch noch nachträglich?
grüße
Den Link muss ich dann nochmal gucken, musste den auch suchen aber soweit ich weiss ist er nicht zwingend notwendig.
Ansonsten werde den dann im #1 Post verlinken :)
€dit: Habe das Radio verlinkt. Einfach auf die Version klicken :)
Gesendet von meinem HTC Desire S mit Tapatalk 2
Reaktionen: Snirg0r
sehr nice!! ich bin auch echt zufrieden mit dem ROM. Es läuft schneller als das von Virtuous ([SAGA][ROM][May 23]Virtuous Saga v.1.0.0 [3.04.401.1][Kernel: HTC] SENSE 3.6 ANDROID 4.0.4 - Releases - RootzWiki) und auch super stabil. Zudem find ichs nice, dass der original HTC-Startbildschirm erhalten ist. Werde mir jetzt das Radio laden und installieren.
Grüße
Edit:
Kann ich das Radio nachträglich installieren? Zip einfach ins Root Verzeichnis der SD-Karte und dann in den Bootloader starten, oder? Habe es nämlich so versucht und es hat sich rein gar nichts geändert (rechts oben im Display lief der Prozessbalken hoch)! Hast du zufällig auch noch den MD5 Hash? Danke schon mal!
Also ich hab das ZIP einfach auf die ad und dann mit bootloader laufen lassen.
MD5 hab ich leider nicht.
Was macht denn das andere neue Radio Image eigentlich?
Hallo Gemeinde
Ich hab ein dickes problem
nachdem ich dieses radio über den Hboot geflasht habe ist mein DS wieder s-on und bootet nichtmehr .
ich bekomme andauernd ein handy mit rotem dreieck angezeigt wenn ich auf recovery gehe in den Hboot komme ich noch .
hat jemand eine lösung für mich und kann mir helfen?
gruß
Ich teste gerne Roms, auch sehr viele. Leider kann ich -das ist meine persoenliche Meinung- diese Rom nicht empfehlen.
Laeuft stabil, Akku Leistung ist super. Aber Fast & Smooth ist diese Rom bei mir nicht. Auch nach mehreren Fullwipes und erneutem aufspielen hat sich nichts gebessert. Bei mir laeuft Saga C&L, auch selbe Android und Sense Versionen, wesentlich fluessiger.
Gesendet von meinem Desire S mit Tapatalk 2
Darthluda
  • LilaLauneBaeaer
LilaLauneBaeaer
Scum
Splitt89
