colarus
Stammgast
- 185
Ich mach mal ein Neues Thema auf, um die beiden Versionen von CM10.1 (mit und ohne 3G) zu trennen.
Hier der LINK zum original Beitrag bei den XDA Developers.
Anleitung:
1. Neustart ins Recovery (WICHTIG: TWRP 2.3.1.2 verwenden!)
2. Nandroid Backup erstellen
3. Full-Wipe
4. CM flashen
5. GAPPS flashen
Downloads:
Bugs / Fehler:
eak1080 schrieb:CyanogenMod 10.1 AOSP 4.2.1 JellyBean
#include
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
For Nexus 7 3G [Tilapia]
PSA: Install the Tilapia Recovery first in order to flash this rom
[CWM][TWRP] Root + Recovery for Tilapia - xda-developers
Installation Instructions
1. Download from CyanogenMod Downloads
2. Download GAPPS from Goo.im Downloads - Downloading gapps-jb-20121212-signed.zip
3. Place on SD card(internal storage)
Note: The latest TWRP 2.3.2.1 is needed to recognize the new folder structure of 4.2, see above link
4. Reboot to recovery, flash nightly_xxxx.zip, flash gapps.zip
5. Reboot and enjoy
6. For new Nightlies use the build in CM updater.
NOTE: If clean flashing do not hit the "Format Data" Button when wiping otherwise you will loose your internal storage(SD card)
Changelog
Assuming most changes are the same, will update when BBQ website updates for 3g version.
BBQLog - Official CyanogenMod 7, 9, 10 and 10.1 Changelog for Android distrubtion
If you want to know the bleeding edge of what is being worked on/Merged
1. Nexus 7 3G gerrit Gerrit Code Review
3. CM G+ https://plus.google.com/u/0/+CyanogenMod/posts
Features which don't work right now (I will update as users report issues/findings) :
1. Quick settings toggles WIP https://plus.google.com/u/0/117962666888533781522/posts/asjB4S3fxar
NOTES:
Read before flashing https://plus.google.com/u/0/117962666888533781522/posts/9X561GFMxL5
For those that want picasa sync:
xda-developers - View Single Post - [ROM] CyanogenMod 10.1 [OFFICIAL]
or
Anleitung:
3. Full-Wipe
4. CM flashen
5. GAPPS flashen
Downloads:
- Recovery [CWM][TWRP] Root + Recovery for Tilapia - xda-developers
- CM 10.1 für Nexus 7 3G CyanogenMod Downloads
- Gapps Gapps 20130301
- Inoffizielle Builds von temasek
http://forum.xda-developers.com/showthread.php?t=2061233
Bugs / Fehler:
