P4RTYH4RTY
XNOTE Build 3.0 N910F NK4
Soloilmeglio - Xentrix
Hinweis für Entwickler:
Wenn Ihr Mods in eurer Rom verwendet fragt vorher um Erlaubnis und gebt Credits zum X-Note Team an
Hinweise für User:
Weder Android-Hilfe.de, ich oder der Entwickler
sind für schäden an eurem Gerät verantwortlich.
Die Installation des ROM ist auf eigene Gefahr . Haltet euch an die Installationsanleitung
NEW FEATURES BUILD 3
- new installer script, now we have +120 mb free in system, wipe data is REQUIRED, don't dirty install otherwise you will have errors. Don't post bugs if you dirty install the rom.
- removed pen-up app
- reintroduced and fixed ability to show-hide sfinder and quick connect buttons in notification panel
- enabled TW launcher themes
- Added Xnote Lolli tw launcher theme
- Added X-Note AOSPlus tw launcher theme
- new dropdown themes ... + 10 material design backgrounds , switch with xnote app
- totally rewritten X-Transformer app, new layout, material design like, simple navigation mode to select the available options, native enabled multiwindow and samsung floating window mode
- Popup browser by xperiacle
- changed some system sound
- smart scroll mode enabled (xnote app)
- lockscreen view selection: clock only - clock + personal message (xnote app)
- ability to customize personal message lockscreen (xnote app)
- keyboard hidden settings enabled: pen track customization (xnote app)
- xnote app updated with all the new features
END NEW FEATURES BUILD 3
NEW FEATURES BUILD 2
*Modified parts of our code to have better battery life
*full multi dpi support incall screen and popup incall window
*no increasing ringtone
*10 max windowed app opened instead of 5
*remapping menu and home key - you can set the left key as menu instead of recent, longpress home open recents app instead of google now, select everything with xnote app
*Enabled all locked samsung features (xnote app) - Airview with finger (fully working), air motion settings (not everything works)
*Removed - quick connect buttons + sfinder buttons layout in notification panel
* Xtransformer app v2, NEW available densities
-410
-430
-460
-490
-520
-550
-580
-610
-640 (stock density)
+custom dpi
* Removed - Clock Second
* Added - Dropdown panel clock
* Removed - quick connect buttons + sfinder buttons layout in notification panel
* Custom StatusBar image background
* Custom Droppanel image background (12 images selection)
* Dropdown panel clock custom color
* Ability to show / hide OG Battery MOD +100 Battery icon
* Ability to show / hide 3Minit Battery MOD
* Ability to enable/disable CPU Widget on Dropdown
* Ability to change color of CPU Widget on Dropdown
* Ability to change color of toggles + heder background
* Removed the two status bar themes as now you can customize all colors
* Glance view support
* enabled installation of 3rd part apk from first boot
* Fully patched multi dpi play store, support all density
* Galaxy s5 one hand mode with favourite apps bar and contacts bar (the recent key become menu key if selected in xnote app)
* Added second server for OTA folders (Xnote app)
* Reduced size for XBattery.apk (from 90mb to 50mb)
* Added Monblanc exclusive content
END NEW FEATURES BUILD 2
#Deodexed, zipaligned, rooted, busybox
#Many apps moved to data partition to allow easy uninstall
#Working private mode
#300 fonts included
#Studio app accessible from launcher
#Disabled signature check by default
#face unlock feature
#Viper for android audio mod included
#3 sound boost levels accessible with xnote app
[X-NOTE app]
#totally rewritten X-Note control app... now the navigation is done with swipeable tabs.
when open the app the first page links to all tabs, the back key automatically redirect to first tab.
so you can swipe or navigate.
[ADVANCED MULTIWINDOW]
#unlocked floating multiwindow for all app (+ double window + quad window)
#unlocked multi instance support for all apps
#unlocked the scale feature (from the screen top angle) for all apps
#multiwindow key for all apps in the recent view screen
[MULTI DPI X-TRANSFORMER]
#X-Transformer feature: THE WHOLE ROM IS MULTI DPI (sview cover to-do)... available dentity: see the new features above
[TW LAUNCHER]
#TW launcher switcher, two different grid available:
4x4 home screen, 5 offset bar icons - 4 coloumns in folders
5x4 home screen, 6 offset bar icons - 4 coloumns in folders
#Enable/disable infinite scrolling
#Enable/disable wallpaper scrolling
[SETTINGS]
#Added new options in settings:
X-Transformer
X-note app
X-Reboot
#Enable all hidden settings widgets
[SCREEN]
#3 screen mode available
- black and white
- High contrast
- default
[Features MMS-SMS]
#Unlimited Contacts Joining, SMS/MMS Max Slide Count, Recipient Limit Messages Per Thread, Max Subject Length, Max Email Address Length.
#Disabled SMS To MMS Auto Conversion For Long Text
#Disabled SMS To MMS Auto Conversion For Emoji
#Save And Restore Text Messages Using The Messaging App
#Enabled Group Conversations In Stock Messaging App
#Messaging App Screen On/Off Toggle
#Messaging App Split-View Mode
[Features Lockscreen]
#Lockscreen Select AOSP - Samsung
[Features Power Menu]
#Power menu customizable
- Show/hide reboot menu title bar
- show/hide data mode
- show/hide airplane mode
- show/hide power off
- show/hide restart
- show/hide accessibility
- enable/disable home button
[Features Statusbar]
#2 system UI theme switchable with xnote app
- stock theme
- xnote theme
# Double tap on status bar to turn off the screen + ability to
# Customized battery text style with the following options
text style
enable/disable Auto Color
Static Color selection
Charging Auto Color selection
Regular Auto Color selection
Medium Auto Color selection
Low Auto Color selection
# Show/hide Battery icon
# Show/hide Samsung Battery text
# Advanced Battery bar fully customizable
#Customized network Traffic Meter
# ability to change
Disabled
Outgoing
Incoming
Outgoing
# ability to autohide
# ability to change color
#Customized toggle
- ability to show/hide toggle status indicators (x-note app)
- ability to show/hide toggle text (xnote app)
- ability to change color of active toggles (x-note app)
- ability to change color of dim toggles (x-note app)
- ability to change color of OFF toggles (x-note app)
- ability to change color of toggle text (x-note app)
- ability to change color of active indicators (x-note app)
- ability to change color of dim indicators (x-note app)
- ability to change color of OFF indicators (x-note app)
#Additional toggles
- torch toggle
- X-Note toggle
- Xtransformer Toggle
- enabled many hidden samsung toggle
- Enabled Air gesture toggle (longpress on it to access to air gesture settings)
#Customized Clock
- Hide/Show Clock Second
- status bar clock right-center-hide
- status bar clock font selection - 5 fonts available
- enable/disable date near the status bar clock + small/big font selection
- uppercase/lowercase/normal font selection for status bar date if enabled
- 18 available date format: dd-mm-yyyy / EEEE-mm-dd-yyyy / etc.
#Customized Dropdown panel
- Show/Hide sfinder - quick connect buttons + top sfinder button in notification panel
- ability to change color of Droppanel
-410
-430
-460
-490
-520
-550
-580
-610
+custom dpi
#300 fonts included
[X-NOTE app]
[TW LAUNCHER]
[SETTINGS]
X-Transformer
X-note app
X-Reboot
[SCREEN]
- black and white
- High contrast
- default
[Features MMS-SMS]
- show/hide restart
- stock theme
- xnote theme
text style
# ability to change
Disabled
Outgoing
Incoming
Outgoing
#Customized toggle
#Additional toggles
- torch toggle
- X-Note toggle
#Customized Clock
(NUR FÜR N910F!!!)
1- Vergewissern dass die Reaktivierungssperre in den Einstellungen deaktiviert ist
2- ein EFS Backup der Kitkat Firmware
3- Checkt die MD5 Summe eurer heruntergeladenen XNote Rom
4- ins recovery booten
5- wipe data (andere Wipes sind nicht nötig)
6- install zip und die Rom von eurer SD auswählen
7-Nach Installation Gerät Ausschalten, nicht neu starten.
8-Wenn ihr kein NK4 Bootloader habt flasht ihn über Odin(notwendig), downloadbar HIER
9-Wenn ihr kein NK4 Modem habt flasht es über Odin(notwendig), downloadbar HIER
10- Beim ersten einloggen in euren Google Account unbedingt die Stock DPI 640 verwenden.
9- Viel Spaß mit der Rom
MD5: d9df3109c2d5e59d33e4d07776e59257
Android File Host
______________________________________________________________________________
[ROM][N910F][XXU1ANK4][4.4.4] *26.11.2014* X-NOTE v2.0
MD5: 2070d99442687864179c34b2e77eee4c
Android File Host
[ROM][N910F][XXU1ANJ4][4.4.4] *10.11.2014* X-NOTE v1.0
MD5: 7C26E77891F8CE2575A7C8180656F671
Android File Host
Android File Host
Android File Host
@ cyanogen rom team
@ AOKP rom team
@ dsixda - For dsixda kitchen
@ jovy23 - SecMms mods
@ Chainfire - For Superuser and a bunch of things
@ rovo89 - For Xposed framework, for updates click here
@ Tungstwenty - For Xposed Module (custom dpi density)
@ OsamaGhareeb for battery mods
Please pm me if I forgot some Dev
XDA DevDB Information
X-Note Rom Galaxy Note 4, ROM for the Samsung Galaxy Note 4
Contributors
soloilmeglio, xentrix
ROM OS Version: 4.4.x KitKat
Version Information
Status: Stable
Current Stable Version: 1.0
Stable Release Date: 2014-11-10
