[ROM]SmartDroid|Berserk Mode:ON|AOSP+Sense3.6+Sense4.0|HyBrId|Gaghiel|1.5 online
Zekene
Zekene
Enthusiast
2.239
SmartDroid team present
Compatible with Sensation, Sensation 4g, and Sensation XE
Hey guys, this is my brand new hybrid project. After sense 3.6 mushed with sense 4.0, I thought to do the same stuff but with an huge amount of aosp frameworks,libs and stuff. The result is a sense 3.6 based rom, but with ALL the sense parts removed to let the aosp framework free to run, and with some sense 4 structural parts. This rom can't be considered a no-sense rom, cause sense is still present in a way, I left the sense part useful and needed to make all the things work properly. So this is the hystory, now you tell me if this is not the fastest hybrid experience ever! Enjoy
*RUU 3.32.401.105+_R
*Aosp+Sense 3.6+4.0
*Android 4.0.3
*Kernel: 3.0.2.6-Bricked
*Tmous 4g support
*disabled apk signature check
*zipaligned and optimized for a better RAM management
*png compression and optimization for a better theme experience
*APM
*Custom Bootanimation
*Ad-Free
*Speed tweaks
*Ext4 Support
*Rooted
*Busybox
*DeOdexed
*Removed useless things
*Multilanguages
*Bravia Engine
*Sense 4 audio system
*Sense4 Keyboard
*Sense 4 wallpapers system
*Full tweaked build.prop
*init.d script support
*zipalign script
*battery calibration script
*bloatwarefree
*spywarefree
*HQ V1.5 Camera (Sense Camera in the ROM)
*Aosp Tweaks
*some useful apps
*Good Support ^_^
Code:
--V 1.5 Gaghiel-- updated Bricked to 1.31 version updated mms aosp apk with themed one (no mms working, flash the fix as always) updated dsp beats engine updated bootanimation with a more aosp one, the old black one is available through installer deleted transparent UI deleted circle battery deleted toggle4g deleted more useless apk found a workaround to wifi calling (check 2nd op please) --V 1.4 Ramiel-- updated bricked to 1.3, awesome fixed wrong icon in apm menu fixed some wallpapers redraws (but not preview) delete useless libs (a lil bit more) updated ram engine more i can't remember on the base now the funny part, my installer 13 items!! bravia custom boot anim dsp+beats engine (newest mod) HQ camera MIUI Cam New Music aosp app plus theme Beats Sense Engine and music app Ram Hack and SD engine (updated) Tmous support toggle4g icon circle battery icon with% transparent systemUI (status bar and other stuff) WP7 launcher (experimental, if you like it ) Enjoy:fingers-crossed: ps. try to avoid not to flash same things, like for ex. two music engine, sense one and aosp one, they won't work together... --V 1.3 Shamshel-- -Huge update -new RAM+SD card management by me, increased performances a lot -new EGL drivers, smoother than ever -new cleanups to the base -NEW debugging info massage, plus jar, apk and png compression and optimization -more I can't remember now --V 1.2_Sachiel_ added Xperia Launcher, unique version sense 3.6/4.0 hybrid, resized and optimized by me:D NOBODY can use it in his rom without my permission, just ask! Added Sense 4x1 Clock Widget Added a lot of more widgets available through the new launcher enhanced music player sound fixed Music player controls fixed MMS issue DOWNLOAD fixed quadlock controls for music player added SonyClock widget (available through XperiaLauncher) added RIL-Info's app to check your RIL easily more clean up in the base --V 1.1_Lilith_ ot of cleanups removed htc weather crap, htc weather wall and its related crap fixed gallery reintroduced sense 3.6 gallery introduced and fixed Radio fm sense 3.6 added htc dockmode sense 3.6 added google reader fixed lot of themed parts added inverted gapps lot more i can't remember now --Initial release 1.0_Adam_
Code:
Credits go to -XDA Community for the amazing support -desidunda from SmartDroid Team for hosting support -Shnizlon for AOSP framework and themed-base apk -Razer(x) for Infinitum theme -Mattlke from SmartDroid Team for banners and custom wallpaper -@Wilkii from SmartDroid Team for banners and custom wallpaper -AlexAnberlin for support and testing -Madden91 for support and testing -following guys for Sense 4.0 parts: -Steve0007 and Jerrytan93 for themed Sense4 keyboard -ra3al, websar1 and Yngwie Malmsteen for Xperia Launcher base apk -spider for Hypernosense -awesome for awesome beats -bassini for beats engine -mmmcfc for wp7 launcher -show-p1984 for Bricked kernel
Sense 4.0 parts in the rom (05/19/2012)
Code:
-Audio system -Wallpaper system -Keyboard -Bootanimation
Sense 3.6 parts in the rom (05/19/2012)
Code:
gallery cam dockmode
Known bugs
Code:
major bugs: none minor bugs: Htc wallpapers don't show the preview, to see the preview just click on "preview" mms seems not working for some users rom will start with a 100% black wall (it's my choice lol)
you tell me
3.32 firmware is recommended
[4EXT Recovery Touch is recommended]
-Place the zip in your sd card
--reboot into recovery
---format all partition (except SD card!!)
----wipe data factory reset
-----flash the rom*
*follow the instruction if you have a 4g device
Enjoy
__________________
How the ROM looks like once flashed
Wallpapers from @mattlke and @wilkii, smartdroid team members
Ist der Download noch nicht online? Link funkt nicht :confused:
Gesendet von meinem HTC Sensation mit der Android-Hilfe.de App
Benutz den mirror . Dort dann links auf SmartDroid klicken.
Gesendet von meinem HTC Sensation mit Tapatalk 2
Reaktionen: shamanous
außer Wallpapers vorschau keine andere Bugs?
WOW !!! :D:D:D:thumbup::thumbup::thumbup::)
Gesendet von meinem HTC Sensation XE mit der Android-Hilfe.de App
mal ne andere frage: wo bekomme ich das wallpaper her? sieht echt schnittig aus
Ich finde nirgendwo ne md5-Checksumme! :-(
Google ist dein Freund ;-)
Reaktionen: Xr0b
Gerade was in der gallery gefunden :)
So, ich habe nun mal ein paar Tage getestet.
( ohne Sense ) läuft sehr stabil bis jetzt keine Probleme gehabt.
Akku hält sehr gut. Einzige ist das wenn man auf Personalisieren geht stürzt die App ab, liegt wohl daran das ich kein Sense installiert habe.
Sonst hatte ich bisher keine Probleme.
Beats habe ich nachinstalliert und laufen super !!!
hi
die verion 1.2 Sachiel ist nun online.
mfg
Bin ich Der einzige der diese Rom gut findet?
Kaum beiträge in diesem Unterforum .....!
Was hattet Ihr bis jetzt für Bugs ?!:confused:
Akku ist deutlich besser als bei allen Sense 4 Roms.
--V 1.2_Sachiel_
SIZE=1]Gesendet von meinem HTC Sensation XE mit der Android-Hilfe.de App[/SIZE]
Kommt nacher mal wieder drauf
Ich habe mir den Apex Launcher installiert, damit kann man das Design auf seine Wünsche anpassen......
Ich finde, für mich eines der besten Roms im Moment, die Highlights der Sense ohne unnötige Akkufresser :D
Update auf 1.3 schaut sehr gut aus .....:D
hi
wie sieht es bei euch eigentlich mit dem wlanempfang aus? ich hab bei mir die erfahrung gemacht, dass alle roms die auf aosp basieren einen sehr schlechten empfang und verbindungsprobleme haben. selbst 30cm neben meinem router konnte sich mein tele nicht verbinden und versuchte vergeblich sich von diesem eine IP zu holen und bekam sie einfach nicht. das war beim sachiel. deswegen bin ich wieder zurück zum inquisition, dieses basiert nämlich auf nem sense-rom und da ist es mit dem wlan 1a.
danke euch
mfg
Bei mir 1 a! Zwischen dem Router und mir liegen 3 dicke an de und ca. 5-6m luftline und habe 2-3 balken
Der ursprüngliche Beitrag von 16:56 Uhr wurde um 17:51 Uhr ergänzt:
Habe mal die Überschrift und Post 1# Überarbeitet
Ich hatte hier auch noch nie Probs mit Wlan im Gegenteil, kommt mir mehr so vor als ob ich allgemein besserenh Empfang habe als mit SenseRoms
Hatte diesen Rom die letzten paar tage getestet. imho der beste custom Rom fürs Sensation... Läuft schnell. Hatte aber kleinere Probleme mit der Stabilität. Daher bin ich erstmal zurück aufs original HTC sense 3.6 Rom mit ics 4. Werde den aber im Auge behalten. Hat definitiv Potential.
Gesendet von meinem HTC Sensation XE with Beats Audio Z715e mit Tapatalk 2
Welche Phone.apk und Kontakte.apk wird im Rom verwendet?
O
OneGamer
O
ger_kar
Bench
Bench
michael861
