[ROM][ICS Sense 4][21 April]RCMixSmartD Faster Smoother Better Tweaks, MMS
Zekene schrieb:
Ich mags wenn ee sauber ist ;D
Ja sense 4 ist iwie halt sense 4 :D
Gesendet von meinem HTC Sensation mit Tapatalk 2
mäno ich weiss einfach nicht ob ich capys rom flashen soll :(
neue rom kommt, 2.1 :)) glaub jetzt wirds dann geflasht
Changelog 2.1
-changed all the lib's system for a better performance
-changed an huge amount of key libs,etc,and bin files for a better system management
-revised all the build.prop tweaks for a better launcher management in terms of fps, and better tweaks performance
-updated a lot of system app to fit the new speed tweaks
-removed batt% due to request ;)
-added new better drivers for touch responsive management
-removed nova launcher
-added Apex Launcher
-added Google Reader
-added aosp Sense 4 clocks widgets for a bit of Sense experience for aosp launcher lovers
-added @XxXPachaXxX as a new team member for a better team experience LOL
-updated internal app's
-more clean up's to the base
-something I can't remember now
Downloads:
Rapidshare
4Shared
Muss sagen das Rom läuft wirklich sauber. Ich hab noch die Mods von PkMn Team drauf gemacht und jetzt ist das Rom auch schön :D Die Tweaks von PkMn sind viel besser als die von Capy's Rom, neija vielleicht ändert Capy noch was.
liamstears schrieb:
Please read the thread and use search function!! I will no longer answer any post if it has been asked/answered previously so please use the search function or read the thread first!
PkMn Theme Animation
What to expect:
All statusbar icons have been skinned with colorful icons and many are animated.
Animated icons: Battery and charge, all signal bar icons, all data icons (h, g etc), wifi, gps, sync, download, upload
Also lots of icons have been changed to more realistic colorful icons.
I will also try to bring improvements and tweaks if/where I can
This is the first sense 4 theme to have everything this has!! :-D
(All changes in newer versions will be mentioned with each version and then added to the list above)
Current bugs:
You tell me.
To Download Go Here
To Make downloads easier all links will only be posted on my site, the above link.
Recommended recovery 4ext touch!
Current release version 1.1 for PkMn 4.5
Always make a nandroid backup before flashing my theme! Bad downloads and failed flashes do happen.
If for any reason flashing fails please try mounting system and data and wiping cache and dalvik in clockwork recovery first.
Please Donate :)
Screenshots:
For all screen shots go here: Index of /screenshots
A lot of work has gone into this theme, if you wish to use it in any way please contact me first and leave the proper credits
2.1 läuft echt gut. Ein echt guter Sense 4 Rom!
Gute alternative zu OrDroid und InsertCoin Evolution.
Was macht der Akku??
Leider nicht besser als bei den anderen Sense 4 Roms :/
Grüße Marcel
Gesendet von meinem HTC Sensation Z710e mit Tapatalk 2
Muss man aber trotzdem noch paar Ladezyklen abwarten bis man das genau beurteilen kann. Alternative wäre der Anker-Akku ..
Habe einen mit 2400mAh aber trozem hält der akku nicht so gut wie bei ner AOKP
Sense verbraucht halt sein strom, dafür find ich es aber schöner ..
Schon nur ich will schon über den tag kommen ;/
so schlimm?
also ein Tag sollte es ja wirklich mindestens halten
m4ik schrieb:
so schlimm?
Tuts aber nicht :p
Zekene schrieb:
Tuts aber nicht :p
das ist schlecht :thumbdn:
klarer ausschlussgrund
Genau! Und dort funtzt nicht mal der faux Kernel
Ich komme immer über einen Tag ohne zu laden! Mit der neusten Faux Beta , geht das ganz gut :)
Kriege ich n Link? :rolleyes:
MarciWoi schrieb:
http://rootzwiki.com/index.php?/top.../CPU-OC~1.73Ghz/uv/Intellidemand/power-Saving[May-07]
Grüße Marcel
Das oberste ist doch der richtige oder?
Nein nimm den von der letzten Seite in diesem Thread ! Sollte 7 b2 sein :)
Der?
Also ich hab noch den Kernel drauf, der dabei war, also der rcmix Kernel. Und ich hab das Rom heute Morgen geflasht und hab noch über 75% Akku, normalerweise hat man ja den stärksten akku Verbrauch nach dem flashen, würde für mich heißen, dass der Akku lang hebt.
Gesendet von meinem HTC Sensation Z710e mit der Android-Hilfe.de App
  • candlebox
daniel9180
O
OneGamer
O
ger_kar
Bench
Bench
