pengu1981
genau das ist auch mein Stand.
ICS 4.0.x -> Kernel 3.0.8
MorphX schrieb:Nein, ist kein ICS siehe: https://www.android-hilfe.de/forum/...as-move-u8600.347278-page-5.html#post-4918895 und folgende
tImpl.java:238)
E/NetdConnector( 379): at android.net.LocalSocket.connect(LocalSocket.j
ava:98)
E/NetdConnector( 379): at com.android.server.NativeDaemonConnector.list
enToSocket(NativeDaemonConnector.java:119)
E/NetdConnector( 379): at com.android.server.NativeDaemonConnector.run(
NativeDaemonConnector.java:88)
E/NetdConnector( 379): at java.lang.Thread.run(Thread.java:856)
I/Netd ( 1108): Netd 1.0 starting
E/Netd ( 1108): Unable to create netlink socket: Protocol not supported
E/Netd ( 1108): Unable to open quota2 logging socket
E/Netd ( 1108): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1108): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
E/NetdConnector( 379): Communications error
E/NetdConnector( 379): java.io.IOException: No such file or directory
E/NetdConnector( 379): at android.net.LocalSocketImpl.connectLocal(Nati
ve Method)
E/NetdConnector( 379): at android.net.LocalSocketImpl.connect(LocalSock
etImpl.java:238)
ava:98)
E/NetdConnector( 379): Error in NativeDaemonConnector
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1130): Netd 1.0 starting
E/Netd ( 1130): Unable to create netlink socket: Protocol not supported
E/Netd ( 1130): Unable to open quota2 logging socket
E/Netd ( 1130): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1130): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1152): Netd 1.0 starting
E/Netd ( 1152): Unable to create netlink socket: Protocol not supported
E/Netd ( 1152): Unable to open quota2 logging socket
E/Netd ( 1152): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1152): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1174): Netd 1.0 starting
E/NetdConnector( 379): java.io.IOException: Connection refused
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
E/Netd ( 1174): Unable to create netlink socket: Protocol not supported
E/Netd ( 1174): Unable to open quota2 logging socket
E/Netd ( 1174): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1174): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
I/Netd ( 1196): Netd 1.0 starting
E/Netd ( 1196): Unable to create netlink socket: Protocol not supported
E/Netd ( 1196): Unable to open quota2 logging socket
E/Netd ( 1196): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1196): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1218): Netd 1.0 starting
E/Netd ( 1218): Unable to create netlink socket: Protocol not supported
E/Netd ( 1218): Unable to open quota2 logging socket
E/Netd ( 1218): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1218): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1240): Netd 1.0 starting
E/Netd ( 1240): Unable to create netlink socket: Protocol not supported
E/Netd ( 1240): Unable to open quota2 logging socket
E/Netd ( 1240): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1240): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/Netd ( 1262): Netd 1.0 starting
E/Netd ( 1262): Unable to create netlink socket: Protocol not supported
E/Netd ( 1262): Unable to open quota2 logging socket
E/Netd ( 1262): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1262): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
I/dun_service( 90): The value returned from dun_getusbmodemstate_fromsys is 2
I/Netd ( 1284): Netd 1.0 starting
E/Netd ( 1284): Unable to create netlink socket: Protocol not supported
E/Netd ( 1284): Unable to open quota2 logging socket
E/Netd ( 1284): Unable to start DnsProxyListener (Protocol not supported)
E/SocketListener( 1284): Obtaining file descriptor socket 'dnsproxyd' failed: Pr
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
F:\u8600 rooten>
I/Netd ( 1130): Netd 1.0 starting E/Netd ( 1130): Unable to create netlink socket: Protocol not supported E/Netd ( 1130): Unable to open quota2 logging socket E/Netd ( 1130): Unable to start DnsProxyListener (Protocol not supported)
