[ROM][N7100][4.4.4] *22.10.14* ParanoidAndroid 4.6 BETA 5
DirtyKlot
DirtyKlot
Ehrenmitglied
3.907
REVIEW ZUM ROM
Paranoid Android 3+ Review - YouTube
ANLEITUNG
1. UPDATE RECOVERY
2. FACTORY RESET
3. INSTALLIERT ROM, GAPPS
4. WIPE CACHE & DALVIK CACHE
5. NEUSTART
PA 3+ UPDATES BRAUCHEN KEIN FACTORY RESET,
ABER MAN MUSS DIE GAPPS INSTALLIEREN.
Bitte sowohl bei PhilZ als auch bei TWRP bestmöglich die neusten Versionen verwenden!
Downloads und Changelogs sind in Post #2 zu finden!
Bug List
BUGS 4.0:
  1. WiFi funktioniert nicht Fixed!
  2. Bugs aus 3.99 treffen auch bei 4.0 zu
Bugs 3.99:
  1. FM Radio: unsupported. Use Spirit FM Radio from Play Store instead
  2. TV Out: unsupported, will never work (proprietary, undocumented)
  3. No exFAT support (proprietary, Microsoft) -> Fixed!
ORGINAL FORUM
XDA-Developers
NOTE 2 G+ COMMUNITY
WICHTIG: Sichert eure EFS Partition, falls noch nicht geschehen, hier!
CREDITS:
AOSP/Google, Cyanogenmod, Goo, XDA, Krebsmilk, giannisgx89, imilka, beerbong, Liquid,
AOKP, our users, supporters and donators, everyone who's helped us in the past,
heartfelt thanks to all of you!
DONATIONS:
to molesarecoming
to D4rKn3sSyS
to jaybob413
to aaronpoweruser
Screenshots:
Reaktionen: Wegelagerer, R0cc0Naut, Darkmenneken und 12 andere
CHANGELOG
Changelogs - 30-09-2014
-updated from latest sources.
* updated to version Beta 3.
* cm theme engine fixes.
* Added few new features. Details below.
* status bar carrier logo. It seems to not work at my end, not sure if I have included my carrier. Pls check and confirm if u all are able to see the *logo on it status bar.
* App side bar
* Weather on status bar.
* Viper 4 Android. Equalizer app added. Turn it on from settings -> Sounds menu.
* New PIE logo in quick settings.
* bug fixes.
Changelogs - 09-20-2014
* Updated from latest Sources
* Updated to Beta 2 - 4.6 Beta 2
* Theme engine fixes
* Hover and swipe actions updates.
* System Stability fixes
* Lots of update to Telephony, Dialer and contacts.
* Call recording feature added, But no toggle is added due to legal laws. if you need to enable call recording check this post -"http://www.androidpolice.com/2014/08/22/cyanogenmod-adds-call-recording-to-nightlies-but-it-isnt-enabled-by-default/"
Note : DSB and new Recents UI are still in development and is not included in this build.
Changelogs - 8/29/2014
* Updated from latest sources
* Updated to BETA 3
* New Feature - App Circle Bar - Enable it from Settings->More
* Misc fixes for Theme engine
* Hover improvements
Change logs for 8/17/2014
* Updated too 4.45 Beta 2
* Theme Engine fixes
* General Bug fixes
* some enhancements to proximity feature
* Settings search improvements
* Few kernel updates
* Fixes for Noise suppression.
Change logs for 7/30/2014
* Updated to version 4.45
* theme engine upstream merges
* Systemui crash issue fixed. Pls test and let me know if any issue are seen.
* lot of bug fixes
* Kernel updates.
* Added chromecast support. Not tested it, need some one to test confirm if working.
Changelogs für den 24.07.2014
  • Updated from latest Sources
  • Updated to 4.44
  • Added Switch to last app feature - Enable it from the button menu
  • Upstream Theme engine merges
  • Added BT A2DP profile trigger
  • Battery Icon can now be hidden from status bar but still keeping it visible in the Quick settings.
  • Many bug fixes
  • Device & Kernel updates
    Imp Notes :
  • New Cards style recents is not in my build as the source is still private and is being developed.
  • Paranoid OTA App is still broken, you will not be intimated when the build is uploaded as Goo has made a few changes to their site and we need the new API to trigger OTA updates. we are working on fixing this functionality.
Change logs for 7/9/2014
* updated from latest sources
* Updated to version 4.42
* upstream theme engine merges
* Enhancement to Heads up feature
* Added search feature into settings menu.
* Some UI enhancements to Lock screen Notification
* many bug fixes.
Changelogs für den 19.06.2014
Updated to RC 2.
Hover
- General improvements and bugs fixes
Peek
- Improved sensors algorithm - but this does not make a lot of sense as Peek is still not working as it has to work on samsung phones.
Quicksettings
- Fixed theme support
- Separate dimension for dual tile switch so themers can edit it separately
- Other small fixes
Pie
- General improvements and fixed systemui crash on boot
Theme Engine
- Upstream feature patches/fixes
- Fixed system and on the spot dialogs theming
- Other fixes and enhancements
Recents
- Fixed clear all glitch on quick double press while many apps are loaded
- Crash preventing patches
General
- Fixed various force closes (Chrome, Settings, DocumentsUI)
- Fix input settings empty screen when launching from keyboard
- Fixed Safe Headset Volume dialog Softboot
- Added Kitkat supported camera drivers, DRM drivers, started to use closed source sensor drivers. LPM and EGL drivers.
Note : There is one bug that is not yet fixed. when you try to open Google now via PIE, you will see systemui force close. This issue is seen only when using PIE, google now as a app works fines. This issue will be fixed in the future build.
Ältere Changelogs:
Change logs for 6/4/2014
- Updated from latest sources
- Updated to version 4.4 Beta 1
General
- Translated into over 30 languages!
- Backported numerous fixes from AOSP master.
- Improved quicksettings.
- modified lockscreen blur feature to work along with custom lockscreen background from Theme Engine.
- Added workaround for proximity sensor to work correctly after a call. Options need to be enabled from Settings -> Display -> Inaccurate Proximity.
- Added Blacklist option for Peek and floating windows. user can now blacklist an app from either Peek or floating windows. this feature can enabled on any app. Go to Setting -> app - select app and choose Blacklist either from Peek or Floating windows or from both.
Theme Engine
- Numerous updates to the Theme engine
- CM Fixed a few bugs
Pie/Immersive
- Fixed immersive API Thanks for the developers who helped diagnose the issue
- Vastly improved triggering, and allow you to trigger from any area on the edge on tablets.
- Pie now rotates like the navBar (will appear on short edge).
- Enabled pie only on immersive mode enabled by quick settings tlie (not in app immersive).
- Fixed AOSP immersive bug issue where apps would register a touch when swiping statusBar and/or navBar.
- Fixed numerous freezes.
Download the ROM from Goo.im or the mirror site or use the Paranoid OTA app on your phone.
28.95.2014 4.3 BETA 7
* Added support for Peek app
* Cleaned blacklist code
* New blacklist interface in apps settings
* Fix crashes with incoming calls
* Lots of fixes and enhancements to the Theme Engine
* added IME back button on PIE menu
* some BT fixes
* many more general fixes for system stability and functionality.
15.05.2014 4.3 BETA 4
* Updated to Beta 4
* Added New CM Theme Engine
* Added New CM Lock screen Wallpaper
* Fixes for Floating mode in Recents
* Modified circle Battery UI
* Fixes for PIE
* Some translations updates
* Many more bug fixes
Note : If you have applied a theme on your phone, then set your phone back to the system team before applying installing this update. This uses a new Theme Engine UI there are chances for hitting some errors. Also would advice to take a backup if required. In my testing i have not seen any issue, but it is always better to take some precautions.
06.05.2014 4.3 BETA 3
* Version bumped to 4.3 BETA 3
* Launch floating mode apps from notification shade (long press)
* Launch floating mode apps from recent apps
* Root access modes (disabled, apps only, adb only, apps and adb)
* Added Incoming Call in Background feature
* Allow disabling the IME selector notification
* Many more Bug fixes
* Translation updates
29.04.2014 4.3 BETA 1
* updated from latest sources.
* PA version bumped to 4.3 beta 1
* Peek is official and is included
* lots of kernel updates and optimization. New governor added.
* Google camera settings issues fixed.
* updates to the new Theme engine
* updates to stock recent and slim recent
* Enhancement to paranoid ota app
* option to pause, resume or stop a download feature added.
* Added some security enhancement to the lock screen. Check them out under settings -> security
* many more bug fixes and enhancements
22.04.2014 4.2 BETA 5
* Version bumped to BETA 5 -
* Enhancements to Slim Recents
* System UI fixes
* New battery Icon
* Added Chamber of Secrets feature from Slim rom - this can be enabled from Settings -> Developer options -> Last hidden option. watch this video Chamber Of Secrets
* Added few translations
* New CM Theme Engine
* couple of other system fixes.
08.04.2014 4.2 BETA 4
* Update to PA 4.2 - Beta 4
* Bug fixes
* Show advanced reboot menu only if device is unlocked
* Enhancement to password encryption
* Some minor fixes to Audio
* fixes to PIE
* Removed Telo's *connection manager & added New feature, Battery Saver mode - Enable it from Settings -> Battery
* Removed SuperSU and SuperUser from CM11.
* some of you might see a calender storage fc popup post updating to this ROM, just reboot the phone once and that will be fixed.
Note : Delta based OTA update is still not working as i am still working on getting my server up. Download the full ROM for now and flash.
Note : I have made changes to the ParanoidOTA app, so going forward from the next update onwards you will receive my ROM update notification in this app. Stock ROM update will not be shown in this app any more. If any one wants to install the stock ROM then you can download the ROM from the goo site.*Goo.im Downloads - Browsing *
01.04.2014 4.2 BETA 3
* Update to PA 4.2 BETA 3
* Bug fixes to PIE
* Bug fixes to Immersive mode and new drawables in QS tile
* Lockscreen Blur: Disable if music is playing
* Added evening time and new image to status bar header
* fixes to custom lockscreen wallpapers
* fixes to lockscreen notifications
* Setup wizard (Welcome screen) crash issue fixed.
* fixes to quite hours.
22.03.2014 & 27.03.2014 4.2 BETA 2
* Updated to 4.2-BETA2
* Added PIE
* Added PEEK (Still WIP, might have some issues)
* Some fixes to BT and Notification LED
* Option to turn on & off Activity indicators on WiFi and Mobile data
* Fixed Clock style settings. Now clock setting changes works
* Added Live Volume Steps - feature is under Sounds menu
* enhancements to Quick settings and immersive mode.
* New features to Slim recents.You can now move recents menu either to the right or left corner and also change the size of it.
* Added favorite mode to slim recents
* Made gesture Lockscreen more secure
* Added keyguard/Lockscreen colors option. now every part of the lockscreen can be customized.
* Added Dialer lookup.
* Added Quiet Hours Automatic Switch.
* Added QS Sound Tile
* Added AOSPA new Custom Lockscreen wallpaper, removed the old implementation. To set the lockscreen wallpaper go to Settings -> Display - >Wallpapers -> Lockscreen
* Removed HALO.
* Fixed issue with Pin and password entry on lockscreens that was seen in the previous build.
Install the New update via OTA, If OTA fails, download the full zip from any of the below two locations.
11.03.2014 4.1 BETA 2
* Updated to 4.1 BETA2
* PIE is still being worked upon and is not in this build. :(
* Changes to App ops and new features and modes added.
* new transition to Quick Settings
* Added Slim recents, You can enable it from the settings -> More menu
* Updates to Notification reminder and Layout changes
* bring original volume panel expand icon back
* Update the color of the expandable volume panel icon
* BT fixes.
* Fixed backlight issue. Now you can turn off the back light from the settings -> button menu.
OTA server is up and working, Update using OTA method.
Full Zip has been uploaded into goo.im.
05.03.2014 4.1
Note : OTA server seems to be down, due to this OTA update is not working. Please download the full rom zip and flash it on ur phone.
* many bug fixes
* Updated Network traffic meter with new drawables
* Changed Status bar custom image, this looks better now
* Enhancement to Quick settings, small changes to the Tile drawable
* Added Lockscreen Customizable Shortcuts
* Added All in one Animation control and Toast Animation.
* Added Notifcation Reminder - Thanks to Slim rom for this feature. check this video out for this feature in action. SlimRom Notification Reminder - YouTube
* Some graphical changes to the Recents page.
* Enhancement to speed up phone booting on multicore. This is nice little fix that helps the phone to boot up quickly into home screen
* enhancements to Disable safe headset volume warning. There is no more an option/check box to disable this feature. when you plug in ur headset for the first time, your are prompted with an on the spot preference and you sent it based on ur liking.
* Added app lock option to Recent clear all app.
* Added option to bold the clock text
* Added Clear All Apps button location, now you can change the location of this button the screen.
* Lots of Fix to Telephone/ril and added Multi sim support.
* PIE is still on development and is not yet available for legacy devices like ours.
19.02.2014 Beta 6
OTA
* updated to android 4.4.2_r2
* few Bug fixes
* Added Profiles feature from CM
* Added RamBar into recent panel
* Added clock font styles
* Added Network Speed indicators
14.02.2014 Beta 5
OTA
* Quiet hours
* National data roaming
* Updated and fixed a few APNs
* Update ParanoidOTA (no longer requires root access)
* Bug Fixes
* Custom notification LED code reworked
* Download speed not showing/expanding
* Quick settings fixes
* Fixes to Lock screen notification
* fixed issues with custom wallpaper in the lockscreen
* A few AOSP fixes
New Features
* Added 180 degree rotation, this was broken previously.
* Force Expanded notification - enable it from Settings -> more menu
* Added App ops
* Added National Data Roaming
* option to enable left hand Nav bar in landscape mode - Enable it from Settings -> more menu
* Added Lock screen & Lock handle customization. - Enable it from Settings -> more menu
* Disable Safe headset volume - enable it from Settings -> Sound menu
* Added system tweak features like build.prop editor, Wake lock blocker and system app remover
* Added battery level around lock ring
* Added headset hook(Launches Voice over headset) - Settings -> Buttons
* Added Volume panel styles - Settings -> Sound menu
* Added Notification drawer background customization & Transparency
05.02.2014 Beta 4
OTA
* updates from mates sources.
* Gesture anywhere feature added
* gesture lock screen feature added.( u might see a setting force close error when u add a unlock gesture. That is know and I will fix it in the next built.)
* omniswitch added.
* Speed updates to the notification pull down menu.
* Tap to sleep feature added to the lock screen ring, pattern and pin fields.
* keep Notification led on when screen is on feature added.
03.02.2014 Beta 4
OTA
* Fixes for Quick settings & tiles
* Some more BT fixes
* Camera fixes
* New Feature : Connection Manager / Smart Radio - enable from Settings menu
* LockScreen Notification enchancements
* Status Bar Brightness Control - slide the status bar to decrease or increase the phone screen brightness. Enable from settings -> More menu.
* New Feature : Audio Theme - Enable from Settings -> sound
Demo - OmniROM - Sound Packs demo - YouTube
Sample pack: https://app.box.com/s/ok729zc4gljgshhwpji3
* Added options to change Lockscreen Notification Custom background color
* Custom Lockscreen wallpaper - Enable from Settings -> more menu
* Few more bug fixes.
Update using OTA or download it from Goo.im
Note : Before you enable Audio Themes, using a file manager go into the Internal storage and make a folder named "SoundPacks" and copy the sample pack into it. Once copied go into Settings -> Sound and Install "Sound Packs". After installation select sound pack to activate the custom sounds. for more details see the demo video.
30.01.2014 Beta 4
OTA
* Updated from latest sources.
* BT issue fixed, audio now come through the BT headset. Some enchancement for BT car stereo connectivity
* Lightbulb fixed
* Added "x" to Network tile when data connection is disabled
* Bug fixes.
27.01.2014 Beta 4
OTA
- Restored two finger quick setting pull down
- Improved lightbulb activation time on tablets
- Immersive mode fixes (also, now a dual tile)
- Network toggle tile is disabled if Google dialer is installed
- Sleep tile long press opens power menu
- Long press rssi (mobile network) tile takes you to data usage
- Dimmed dual tile switch icon
- Downloads notification now expandable (show download speed) <thanks to community member +Lasse Brudeskar Vikås >
- Fixed Nexus 10 bootanimation
- Add SuperSU to settings, hide app from launcher
- Fix type in APN for SKT Telecom
- Little performance improvement
- PA OTA fixes
24.01.2014 Beta 3
OTA
* Added custom carrier feature. Enable them from settings -> more
* Added status bar clock feature. Enable from settings -> more.
* enhancement to lockscreen notification.
* Bluetooth fixes.
* bug fixes
* dual tile for immersive mode in Quick settings.
20.01.2014 Beta 3
OTA
*Quick settings 3.0
*New Boot Animation
*Maximize lockscreen widgets
*Fix bug with rotation lock tile
*Fix network tiles for CDMA devices
*Update AOSP dialer icon to Google dialer icon
*Separate device encryption password from lockscreen password
*Contextual "on-the-spot" preference dialog (first implementation: Quick settings pull down)
*AOSP dialer check (removes features that rely on AOSP dialer if Google dialer is installed)
*Quite Hours Feature added and Tile added
*Enable sound or vibrate feature when phone is connect or disconnected from power point.
*Home button call answer
*Updated HALO. Some of the old issue have been fixed.
*Notification Counter feature added .
*Lockscreen Notification : Added new feature to exclude apps from being displayed.
*Other AOSP bug fixes
14.01.2014 4.0 Beta 2
OTA
* PA 4.0 is now BETA2
* New Feature added - Driving Mode(Experimental, but works great) - Activate it from Settings > More
* New Tiles added - USB Tether, Network Mode & Torch
* Swipe to switch more fluid
* Hide apps Notification Icon from the status bar. To activate long press on a notification and choose "Hide apps Notification Icons"
* Added Increasing Ring tone and Minimum Vibration duration
* Added screen recorder option to power menu. Enable it from the screen recorder page.
* Added Screen off animation - Various mode available now
* fixed Touch wake feature. Now the settings stick once enabled. No need of Trickster mod any more for this functionality.
* Blur Radius slider is fixed. You can set the radius of blur you need now.
* Many bug fixes
* NO HYBRID YET.
11.01.2014 4.0
OTA
* added a slider bar for changing the navigation bar size on the fly. No more reboot required.
* added screen recorder feature with audio into display settings.
* added lock screen blur feature.
* Added swipe to switch the notification menu to quick settings and vice versa.
* Added touch wake feature.
07.01.2014 4.0
OTA
* custom header for notification panel. This will change based on the system time.
* Option to enable navigation bar.
* modification to immersive mode.
04.01.2014 4.0
OTA
* New Feature : added Theme engine.
* some fixes to camera and option to scan storage devices.
* updates to kernel components.
* Many more fixes and enhancements.
02.01.2014 4.0
OTA
* System.ui fixed
* Pointer for Stylus added
* Additions for Lockscreen Notifications
01.01.2014 4.0
OTA
* Camera and BT fixes
30.12.2013 4.0
Use OTA mode to update to the latest version.
* Added HALO
* new feature added to lock screen notification to set the count of notifications to display.
* bug fixes.
* camera is still inverted in hangout. Fix available but not included in this build.
* kernel enhancements.
27.12.2013 4.0
* Updated from latest Sources.
* New feature - LockScreen Notification - this can be enabled from Setting -> Security
* HALO - This feature has been removed temporarily as it is still in development.
* Quick Tiles - Added one click turn on/off feature for Data/Signal Tile
* Quick Toggles - added Right side pull down of Status bar to open quick toggles, Left side will bring Notification menu.
* Camera Enhance feature added with Color Effects and Scene Mode
* Bluetooth Fixes - No more force closes.
* Kernel Updates - Added Touch wake feature, more governors & schedulers and exfat support. Use Trickster Mod from the playstore to turn on touchwake feature.
* many more updates added.
* OTA update is working fine now from build dated 12/25 onwards
17.12.2013 4.0
- Added Display rotational setting back
- Added Sleep gesture feature - This is experimental
- Reverted all BT fix as it was causing some connectivity issue
- many other enhancements and bug fixes
15.12.2013 4.0
- updated from latest 4.4.2 sources and also including PA and CM sources.
- Lots of bug fixes to various apps.
- Added Battery LED on/off feature
- Advance display updated
- OTA update for the N7100 fixed. Full functional feature. No more of manually downloading the delta and update files. No other PA supported device has this OTA feature.
- HALO feature has been removed in this ROM due to an error in the code. Will get it back in the next update.
- exfat supported added. large SD cards are now detected and functional.
- Fixed secondary storage support
- Added wake on plug feature under display settings.
Note : OTA update of this ROM is not possible this time alone. You will have to download the full zip and flash. All follow on updates will be through OTA.
07.12.2013 4.0
https://plus.google.com/108321221872...ts/8RoboCgKLpH
29.11.2013 4.0
-fixed sensor. All sensors are working now including proximity, compass and gyro.
- Notification LED added
- Quick toggles added to the notification bar
- Immersive mode added to the quick toggle menu.
- HALO added - this is still experimental feature and is not official yet. Most of the halo feature works.
- some bug fixes and enhancements.
19.11.2013 4.0
* Updated to Android 4.4_r1.2
* ROM is still stock AOSP, no PA features added yet.
* Notification LED customization added
* New Kernel Sources & Mali GPU drivers from Samsung added.
* Data connection in call issue fixed.
* Proximity sensor in call is still broken, working on a fix, No ETA at present.
15.11.2013 4.0
* updated from latest 4.4 sources
* Camera, WIFI, ext SD, BT, GPS, NFC & Sensors are all working
11.11.2013 4.0
* This PA 4.0 built out of Android 4.4 Sources. This build does not contain any of the PA specific features. Only features that are not working currently is "Wifi', rest all features are working. This build also contains the updated Mali GPU drivers and Kernel sources from Samsung.
DOWNLOADS
HINWEIS ZU DEN OTA-UPDATES: Um die OTA-Delta-Updates zu erhalten, braucht ihr eine komplette ROM-zip (bestenfalls die aktuellste) im /sdcard/OpenDelta Ordner. In diese wird dann das Update eingepflegt und per OpenRecoveryScript geflasht (TWRP nutzen!). Die Updates erhaltet ihr NICHT über den ParanoidOTA, sondern über Einstellungen->Über das Telefon->Systemupdates.
PA-Gapps
Goo.im
PA Rom
Codefire
Moin moin, herzlich willkommen und allzeit Gutes gelingen! Wenn Du Unterstützung brauchst, so sage bitte bescheid.
Gruss
Bin am runterziehn, PARANOIDANDROID war schon auf meinen letzten androiden mein FAV :)
Aaaaaber, was ist denn der unterschied zur JELLYBAM?
Wenn man die NAVIGATIONSBAR ändert und auf Phablet UI ändert beendet sich die Homeoberfläche andauernt, macht man die NAVIBAR dann wieder wie sie war(RESET) gehts wieder... ziemlich vervig wenn mans nicht weiss...
(Erledigt)
Frage - Wie stell ich die NAVIBAR AUS? Bei Jellybam ging dass... Habs geschafft!
Ich hab einfach meine statusbar unten auf den Bildschirm gestellt da ist es besser denn dann stört die navibar nicht
kannst mir verraten wie ich die navigationsbar weg bekomme?
Systemeinstellungen - Hybridparanoid Settings - Interface & da die NAV.BAR auf 0%
SO hab ichs gehandhabt! Obs anders auch geht weiß ich nicht aber funktioniert!
Reaktionen: McMallow
@onspeed
Warum zitierst Du Dich selbst? Habe es nun gelöscht, Beitrag 4 von Dir enthielt den Zitat von Beitrag 3 auch von Dir!
Hmmm irgendwie Ziet mir das Android OS den Akku leer bei der Rom bzw geht das Handy nicht in den Standby. Das OS hat bei mir Seit gestern 89% Akku gefressen obwohl ich nichts gemacht hab und der Akku ist von 96% auf 23% runter.
Weiß zufällig einer warum?
Flash mal neu, hätte ich gesagt!
Habs übernacht AUS gehabt weil ich zufaul war das Ladekabel zu holen :blushing:, kann also leider nichts sagen..
Hab halt das Problem das mein Handy nicht mehr in den Standby ging. Neu flashen hats irgendwie nicht behoben hab auch nen Fullwipe gemacht
Wie merkt man dieses Problem abgesehen vom Akku Verbrauch?
Ich glaube und spekuliere einfach mal, das er per CPU-Spy gesehen hat, dass das Handy nicht in den Deep Sleep geht..
Ich weiß, das man mkt BetterBatteryStats rausfinden kann, warum man nicht in den Deep kommt, aber von der App hab ich keine Ahnung ;)
gibt es hier zu einen gescheiten kernel? akkuverbrauch usw. gut ist???
Update
Change Log 10.05.2013
  • PA & CM latest sources
  • Version number says 3.5 but its really still 3.15
  • Removal of CM phone.apk as we want AOSP not CM
  • Removal of example video to save space
  • added N7100 specific PA-GAPPS so camera does not get wiped.
03.05.2013
  • Fix camera touch focus lockup\crash
  • Included later phone app (bluetooth fix thanks Tilak. Untested by me may need further tweaking)
  • Bluetooth driver update
  • Dalvik and further performance modifications (experimental)
Erste Seite up 2 date!
Reaktionen: Bundy
Seit heute ist ein Update verfügbar!
Change Log:
20.05.2013
Version number says 3.55 but its really still 3.15
added new N7100 specific PA-GAPPS
No Halo!! sources not available yet
Goo OTA updates (not tested yet)
MD5=ED6A4447B883FED2BB724609456EA92B
@Viper: Wenn du die Links auf der ersten Seite einfügen willst, nimm am besten die, die der Developer in einem der letzen Beiträge auf sein Google Drive hochgeladen hat. Bei den zips bei Goo ist ein corrupt zip dabei.
Die bei Google Drive funktionieren problemlos.
Reaktionen: Der_K und Bundy
Moinsen, vielen Dank für die Meldung. Der Thread Opener wird das sicher beherzigen mit den Links.
Gruss
Wieder ein Update verfügbar, ohne viele Änderungen.
Changelog:
25.05.2013
Revert modified hosts file
Added latest N7100 PA-GAPPS
Reaktionen: Bundy und yusufarif
Weiß man schon ob, und wann Halo auch aufs note 2 kommen soll? am N7000 ist es ja schon verfügbar.
Dr.No
Taker18
Sealsman
Androidwizard
Androidwizard
Androidwizard
