[ROM] CyanogenMod 9 für das Milestone (CM9) - ICS
-FuFu-
-FuFu-
Ikone
3.296
da ich irgendwie keinen CM9 Rom Thread finde, mach ich den mal neu auf ;) und falls es doch einen gab, dann sorry :D
Original Thread auf XDA: [ROM] CyanogenMod 9.1.0 (Android 4.0.4) [20121205] - xda-developers
Seit dem 05.12.2012 gibt es das erste CM9 mit 2ndboot und Custom Kernel...
Download: https://github.com/downloads/nadlabak/android/cm-9.1.0-umts_sholes.zip
Download der Gapps für CM9: Dev-Host - gapps-ics-20120605.zip - The Ultimate Free File Hosting / File Sharing Service
Diskussions Thread: https://www.android-hilfe.de/forum/...it-2ndboot-fuer-das-milestone-cm9.342052.html
Hier keine Diskussion oder so, nur Romupdates, alles andere wird gelöscht...
danke
Reaktionen: Mais, Monzta1988 und motoroller
Version vom 11.12.12: 9.1.0a
Download:
https://github.com/downloads/nadlabak/android/cm-9.1.0a-umts_sholes.zip
Changelog:
- fix relaunch of some activities on keyboard slide out/in (e.g. YouTube playback, Root Explorer...)
- CMFileManager included (backport from JB)
- fix unwanted lcd-backlight activation by camera button while the screen is off (was related to the light sensor workaround that allows to use camera button to provoke sending of light sensor data without waiting for ALS interrupt)
- better handling of Basband Processor panic (by maniac103) - instead of immediate reboot like in stock firmware, user is notified and can choose to postpone the reboot (e.g. when he's got some work to finish first). Note about the reason of reboot is displayed after restart.
- workarounds for some motorola RIL issues that cause occasional data connectivity problems (by maniac103)
- optional swap activation on boot via /system/etc/init.d/12swap
-- requires swap partition present as third partition on sdcard
-- swap size (in kB) is determined by persist.sys.swapsize property
-- no persist.sys.swapsize property defined or set to 0 means no swap activation example how to set persist.sys.swapsize property in terminal:
su
setprop persist.sys.swapsize 16384
Reaktionen: motoroller und Mais
Version vom 26.12.12: CyanogenMod 9.1.0b (Android 4.0.4)
Download:
Dev-Host - cm-9.1.0b-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
GApps: Dev-Host - gapps-ics-20121225.zip - The Ultimate Free File Hosting / File Sharing Service
OpenRecovery 2ndbootOR: http://code.google.com/p/cyanogenmod...ootOR_v1_1.zip
- fix VoiceSearch, VoiceTyping and Talk (voice) - please use the updated gapps package Dev-Host - gapps-ics-20121225.zip - The Ultimate Free File Hosting / File Sharing Service
- fix adb toggle
- fix possible crash when recording videos and re-enable limited preview frame rate for better Camera app responsiveness
- fix backup of system files (mostly gapps) during ROM updates
- add built-in call recording option; no beeps every 10s during call recording any more
- updated CMFileManager
- wifi: disable 802.11n support by default (HT_Enable in tiwlan.ini) to prevent stale data connections when using certain N routers
- kernel: reverted doubling of the DAC fifo size to 16384 (to prevent audio drop-outs) as it caused broken audio playback in certain games
in case you're wondering why the new build is not uploaded to github as before, see https://github.com/blog/1302-goodbye-uploads
Reaktionen: iammarc, motoroller und -FuFu-
Ich bin zu langsam für diesen Fred ;-)
Version vom 07.01.13: CyanogenMod 9.1.0d (Android 4.0.4)
Download:
CM9.1.0d: Dev-Host - cm-9.1.0d-umts_sholes.zip - The Ultimate Free File Hosting / File Sharing Service
gapps 20121225: Dev-Host - gapps-ics-20121225.zip - The Ultimate Free File Hosting / File Sharing Service
OpenRecovery 2ndbootOR: OpenRecovery_2ndbootOR_v1_1.zip - cyanogenmod4milestone - OpenRecovery 1.46 with 2ndboot to 2.6.32 kernel (fixes sdcard issues; adds battery charging in recovery) - Issue tracker for Milestone CyanogenMod port - Google Project Hosting
9.1.0d (4.0.4) 07.01.2013
- fix: keep keyboard backlight off while keyboard is hidden
- fix crash on launch of certain apps (e.g. Aldiko) - use workaround for occasional mysteriously zeroed bitmap scale parameter
- Apollo music player fixes - jellybean backports; reworked image fetching and caching (by iwo)
9.1.0c (4.0.4) 30.12.2012
- call recording: fix recording for calls with asterisk in the phone number
- fix the per app HW acceleration disable code to work according to application package name as specified by HWA Settings app (the original implementation [which pre-dated HWA app usage] used process name, not package name)
- re-implement the 'Disable Dock Observer' option - for users of phone cases with magnetic closures (to prevent the screen turning on in reaction to a magnet appearing near the phone)
Reaktionen: Monzta1988, Mais und -FuFu-
coolzero3389
  • coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
coolzero3389
-FuFu-
paysano
paysano
