[AOKP-ROM][JellyBean] *30.03.13* [4.2.2] Android Open Kang Project [JB-MR1][BUILD 6]
Chris1996
Chris1996
Stammgast
141
Hi Leute! Den einen oder anderen wird es bestimmt freuen, dass es nun auch AOKP offiziell für unser s2 gibt :D Mehr Infos kriegt ihr auf der Aokp-Page oder im XDA-Thread.
Viel Spaß damit und Happy Flashing! :thumbup:
JB-MR1 Bild 6
• New features
Code:
• Fully rEvamped NavBar and Lockscreen UI in ROMControl
•Themeable lockscreen
•Scrollable toggleS are back
•WebGL on the Nexus 10
•Option to daydream on wireless charger
•Volume adjusT sound preference
•Open sOurce Superuser thanks to Koush
•StatusBar hide toggle
Sleep toggle
• Milestone 1
• New Features:
Code:
• Adjustable NavBar width for Tablets
• Allow "Vibrate on Touch" behavior for Slide unlock
• Toggles can be hidden like in ICS - long press on the Settings button!
• Clickable (short & long configurable) Clock and Calendar in the Notification Slider
• Build 5
• New features:
Code:
• Custom NavBar for Tablets
• NavBar widgets are back from ICS
• Highly customizable Lockscreen Ring targets, with a shiny new editor in ROMControl! (also thanks to CM for the base of the framework part)
• Alternate default app picker (like in GB)
Menu UI Overflow Toggle
Option to disable vibration for Notification expansion
RAM Bar in the Recents panel
Timeout and instant lock options for Slide lock
Tons of beautiful new icons by Kwes
VPN Traffic amount in human readable format
We are working with the guys at CyanogenMod to submit our features & enhancements back upstream to their source.
[B][COLOR="Red"]Warning:[/COLOR][/B] If you are a flashoholic and not coming straight from Build 4 (you built it from source, or tried some unofficial/nightly builds), you might have to reset your Lockscreen targets, as we changed some critical code in the last few days.
Adam made an awesome app for AOKP - [URL]=https://play.google.com/store/apps/details?id=com.cashew.kangerator]Kangerator[/URL] - you can track / download our new releases or even the Gapps packages with it. Don’t forget to check it out!
Gapps has been updated as well, please flash the newest one with this release.
•Build4
Code:
[B]New features:[/B]
• Custom NavBar Ring on tablets
• Force dual panel view on any device
• Flip or shake your device to snooze/dismiss the alarm (check alarm settings)
• Take screenshot from NavBar
• Enabled USB mass storage emulation for certain devices (i9*)
•We fixed the NavBar custom icon bug, and some minor issues with eg. fastcharge and autobrightness as well.
•Build 3
Code:
• SMS QuickReply
• Stopwatch & Countdown in the Clock app (CM)
• Expert Calculator functions (Graph, Matrices, etc.) (CM)
• IME Switcher & Vib/Ring toggle as NavRing target
• We fixed some serious bugs (you can set custom
ringtones now), and made a few other fixes & improvements as usual.
Code:
1) Macht ein Nandroid Backup
2) führt einen Fullwipe durch
3) flasht die [URL="http://androtransfer.com/get.php?p=AOKP/i9100/aokp_i9100_jb_build-4.zip"]ROM[/URL]
4) flasht die [URL="http://goo.im/gapps/gapps-jb-20121011-signed.zip"]Gapps[/URL]
5) reboot
• Official Releases
goo.im | androtransfer | Google Apps
• Nightlies
• Hier klicken für den mit JB kompatiblen Flash Player
• Hier klicken für den Apollo Music Player
Reaktionen: JobbeDeluxe, Angel30, Steili und 9 andere
Bin schon gestern drüber gestolpert und in einen anderen Post da drauf schon hingewiesen! :biggrin:
Hatte es auch schon ca. 24h am laufen!
Kann man Problemlos nutzen. In der zeit in der ich es drauf hatt ist mir nix negatives aufgefallen ... :thumbsup:
die unterschiede zu aosp sind vermutlich ähnlich denen von ics aosp zu aokp?
sent by s2 JellyBean 4.1.1
Also ich habe mich getraut und die AOKP JB läuft seid gestern als second Rom. Erstes Fazit: schnell und smooth. Bisher läuft sie Top und ist absolut alltagstauglich. Keinerlei Probleme.
Also traut euch. :thumbsup:
Macces
Ist die ROM auf Deutsch? Oder ist das alles auf Englisch?
Also die grundsätzlichen Einstellungen sind alle komplett in Deutsch. Ein paar Einstellungsmöglichkeiten in der ROM-Control sind noch auf Englisch, dass ist aber nicht dramatisch.
Nandroid machen und Ausprobieren.
Macces
P.S. Ich finde es wieder eine tolle ROM. Unter ICS war ich auch nor mit AOKP unterwegs und habe es nie bereut.
so nachdem ich cm9 aokp immer genutzt hatte und dann auf rush cm10 umgestiegeb war hab ichs jetzt auch mal geflashed.. als primary rom. laeuft mmn gefuehlt schneller, smoother und öffnet apps schneller als aosp.. akku kann ich noch nix sagen.. aber super rom :) bleibt erstmal drauf
Endlich echtes JB-AOKP :rolleyes:
Werds mir heute mal als Second-ROM installieren, wenn der Akku passt, bleib ich dabei ^^
...vom SII getapatalked...
Also ich hab mir die Rom mal geflasht und werd sie mal länger testen ;) mal schaun wie die Akkulaufzeit so ist :D
Sent from my GT-I9100 using Tapatalk 2
Hiho,
sodele hab mir voher auch mal die Rom geflasht *gg* werd se die Tage mal ausprobieren, erster Eindruck ist schon mal guat =)
Andi
ENDLICH !
Werde mal diese AOKP testen, die RR AOKP lief bei mir nicht so wie sie sollte
Gleich mal als Second ROM installieren. :D
Von mir +1 dafür! Seid release drauf mit dorimanx kernel (neuster) und läuft auf 800mhz genauso smooth als auf ics auf 1200mhz, an manchen stellen, zb scrollen oder der taskmanager läuft jb sogar ohne funktionierenden hw compiler, schneller als ics! Wie wirds dann erst mit hw compiler werden? :)
Scheint wohl ne neue Version zu geben: http://xfer.in/get.php?p=pier/i9100_AOKP_jb/aokp_i9100_jb-build-1_20120827.zip
Changelog:
Code:
Project name: android_build
  •Steve Kondik - build: Add Qualcomm's helper macros
  •Emilio López - Removed references to CM build
  •Andrew Boie - select.mk: Tune ccache options
Project name: themes-platform-vendor-tmobile-apps-ThemeChooser
  •Sébastien - Update French translation-ThemeChooser-CM10
Project name: proprietary_vendor_samsung
  •codeworkx - i9100g/p31xx/p51xx: remove prebuilt hostapd
  •Shareef Ali - d2tmo: missing blob
  •Shareef Ali - d2: update blobs for rest of the line
  •Steve Kondik - d2: Update props
Project name: vendor_aokp
  •Pierpaolo Pernici - vendor_aokp: fixing our build zip naming (Bajee borked it!)
Project name: android_system_core
  •Steve Kondik - window: Add API to set the min undequeued buffer count
Project name: packages_apps_Settings
  •YULIANGMAX - Update Simplified Chinese translations
Project name: packages_apps_ROMControl
  •YULIANGMAX - Updated simplified Chinese translation of more suitable. Connect strings of xml and javacode to "strings.xml". Fix translation errors. Remove toggles translation.Because they need overlays.
  •BMc08GT - Add IME Toggler (2/2)
Project name: packages_apps_Camera
  •Danesh Mondegarian - Camera : Fix camera crash
  •Steve Kondik - camera: Remove the rotation parameter for video
  •Steve Kondik - camera: Add options to better control video preview size
  •Steve Kondik - camera: Restart the preview if record size changes
  •Tanmaya Godbole - Camera: Fixes the camcorder preview freeze at 1080p
  •Tanmaya Godbole - Camera: Fixes stretched and shrunk preview issue on camera
Project name: platform_manifest
  •Jonathan Steadman - manifest: track external/qrngd
  •BMc08GT - Track cm's openssh
Project name: android_hardware_libhardware_legacy
  •Steve Kondik - audio: Add missing enum
  •Mingming Yin - audio: Support for more QCOM audio features
  •Seth Shelnutt - libaudiohw_legacy: Add second #ifdef to set channels when using legacy audio and not using ics audio blobs.
  •R. Andrew Ohana - wifi.c: allow devices to specify driver delay if needed
Project name: android_hardware_qcom_audio
  •Arne Coucheron - audio: Interface changes for the msm7x30
  •Steve Kondik - audio: Don't depend on kernel objects
  •Vidyakumar Athota - hardware/alsa_sound: Fix for  VOIP call issue
  •Mingming Yin - libalsa-intf: ucm: Set appropriate volume for headphone device
  •Aviral Gupta - audio: Interface changes for the msm8660 and 7627
  •Steve Kondik - alsa_sound: Add new ACDB function
  •Mingming Yin - alsa_sound: AudioPolicyManagerALSA implementation for QCOM added feature.
  •Vidyakumar Athota - hardware/alsa_sound: Port fixes in ICS to JB
  •Mingming Yin - libalsa-intf: Port fix in ICS to JB
  •Vidyakumar Athota - alsa_sound: VOIP bringup and add flags to openOputputStream.
  •Tejas Shikhare - hardware/qcom/audio: Misc fixes for LPA/Tunnel
  •Tejas Shikhare - hardware/alsa_sound: Implement AudioSessionOut to support LPA and Tunnel.
  •Sriranjan Srikantam - hardware/alsa_sound: Add NULL check for pcm handle in recover code
  •Mingming Yin - Add support for wifi display
  •Mingming Yin - alsa_sound: Enable QCOM proxy device in audio HAL
Project name: android_hardware_qcom_display
  •Sravan Kumar D.V.N - display : Fix Enable vsync for MDP3 targets
  •Arun Kumar K.R - hwc/fb/overlay: wait for fbpost and pan display
Project name: frameworks_av
  •Steve Kondik - camera: Set the min undequeued buffer count to 2 for camera
  •Steve Kondik - audio: Unbreak ALL the things
  •Steve Kondik - stagefright: Build QCOM players for all QCOM targets
  •Steve Kondik - audio: Fix another ifdef fail.
  •Ethan Chen - audioflinger: fix bad parentheses placement
  •Tejas Shikhare - frameworks/av: Implement DirectTrack and DirectTrackClient
  •Ricardo Cerqueira - OMXCodec: Support older QCOM video decoders
  •codeworkx - audioflinger: workaround for samsungs volume bug
Project name: frameworks_native
  •Steve Kondik - surfacetexture: Add API to set the min undequeued buffer count
Project name: frameworks_base
  •BMc08GT - Add IME Toggler (1/2)
  •Bajee11 - SystemUI:HSPA+ Support
  •Rajulu Ponnada - frameworks/base: fix for garbage screen updates in certain testcases
  •Danesh M - WebView : Add openUrl menu item
  •sethyx - Port lockscreen info-lines from ICS (1/2)
  •Vairavan Srinivasan - VibratorService: Fix to ensure actual delay in a vibrate pattern
  •Vishal Mahaveer - Fix interface name for tethering
  •isimobile - Change SIM Pin lock entry to center of window with transparent background for devices with large screens (Tablets)
  •Arun Ravindran - Services: Adding HSPAP info in Android
  •Pawit Pornkitprasan - Make "SD Card removed" notification dismissible if the removed SD Card is not the primary storage
Reaktionen: Chris1996
Morgen :)
So an sich läuft die Rom spitze, Akku Leistung ist bisher auch gut. Bin dennoch wieder zur meiner anderen Rom gewechselt. Hatte in den letzten zwei Raucherpausen zweimal das Problem das sich mein Handy komplett aufgehängt hat beim Surfen mit Tapatalk :-\
Werd heute abend mal die neuste Version flashen und schauen wie die läuft :D
Andi
Gesendet von unterwääägs :D
In der Tat sehr nice die ROM. Läuft bisher ohne Probleme flüssig & schnell. Die Bootani ist bissle gay, da muss ich ne andere nehmen, sonst top.
Das Pferdchen ist halt das AOKP Pferdchen :D
Ohne jemandem Nahe treten zu wollen, aber dieses Einhorn oder eher die Regenbogenmähne geht echt garnicht :D
Rom ist sonst sehr gut. Aber alles zu groß für mich ;)
Sent from SGS II powered by PARANOIDANDROID
Bootani kann man doch in der Rom-Control abschalten. Und was heisst die Rom ist zu groß?
Also ich finde die Rom saustark. War schon unter GB ein AOKP-Anhänger.
Macces
Komme mit der Stock DPI nicht mehr zurecht :rolleyes:
Das meinte ich mit zu groß.
dj3d
karu2003
Pr0TuRk38
Pr0TuRk38
Pr0TuRk38
j1gga84
vonharold
vonharold
