[Firmware][10.0] OxygenOS 10.0.8 | 7 & 7 Pro
TomTim
TomTim
Ehrenmitglied
6.425
System
  • Newly added user assistance feature to help user master usage skills quickly (Route: Settings>OnePlus Tips&Support)
  • Optimized power consumption of the system and improve user experience (OP7 Pro Only)
  • Fixed the flashback issue with some third-party apps
  • Fixed known issues and improved system stability
  • Updated Android Security Patch to 2020.09
Reaktionen: W113, katerspike, arashi und 3 andere
Updateverlauf
System
System
  • Newly adapted OnePlus Buds, easier to take advantage of wireless connection
  • Provided a variety of clock styles for you. You can customize on your own. (Go to Settings>Customization>Clock style)
  • Fixed the issue that double tap could not wake up the screen in some settings
  • Updated Android security patch to 2020.07
Reading mode
  • Added the Chromatic effect option to adapt color range and saturation intelligently for a better reading experience (Settings - Display - Reading mode - Turn on reading mode - Chromatic effect)
Bluetooth
  • It has adapted to Bluetooth hearing aid app connection under the Android 10 Audio Streaming for Hearing Aid (ASHA) Agreement
Network
  • Fixed the wrong display of names of inserted SIM cards from different carriers
System
  • OnePlus Bullets Wireless Z can now be integrated with Dolby Atmos for better sound quality
  • Optimized the volume adjustment to improve user experience
  • Improved the battery life user experience
  • Improved system stability and fixed general issues
  • Updated Android Security Patch to 2020.05
Camera
  • Adding lens stain detection
Phone
  • Newly added Epic Games in Game Space(India only)
System
  • Optimized the Ram management
  • Improved system stability and fixed known issues
  • Updated Android Security Patch to 2020. 03
Gallery
  • Improved stability for recording videos in slow-mo
  • Fixed the random disappearance of screenshots in Gallery
  • Synched video playback speed with audio
System
  • Optimized the RAM management
  • improved black/blank screen issues with some apps
  • Added the feature to support reminders for privacy alerts
  • Improved system stability and fixed general bugs
  • Updated Android security patch to 2020.1
System
  • Improved the launching spped of some apps
  • Optimized the RAM Management
  • Optimized the black and white screen issues with some apps
  • Improved system stability and general bug fixes
  • Updated Android security patcht o 2019.11
Camera
  • Imprved the image quality
System
  • Updated Android security patch to 2019.11
System
  • Optimized the standby power consumption
  • Optimized the expanded screenshot feature
  • Optimized the Bluetooth connectivity in the automobiles
  • Improved the translation accuracy
  • Optimized overall communication (network, phone calls, mobile data) performance
  • Optimized charging performance with the third-party chargers
  • Fixed the blank screen issue
  • Fixed fingerprint icon animation issue
  • Fixed the volume issue with AirPods
  • Fixed the black bar issue while charging or playing a video
  • Updated Android security patch to 2019.10
Camera (7 Pro)
  • Optimized the performance of Super Stable feature in the Video for the Camera app
System
  • Upgraded to Android 10
  • Brand new UI design
  • Enhanced location permissions for privacy
  • New customization feature in Settings allowing you to choose icon shapes to be displayed in the Quick Settings
  • General bug fixes and improvements
Full Screen Gestures
  • Added inward swipes from the left or right edge of the screen to go back
  • Added a bottom navigation bar to allow switching left or right for recent apps
Game Space
  • New Game Space feature now joins all your favorite games in one place for easier access and better gaming experience
Smart display
  • Intelligent info based on specific times, locations and events for Ambient Display (Settings - Display - Ambient Display - Smart Display)
Message
  • Now possible to block spam by keywords for Message (Messages - Spam - Settings -Blocking settings)
Camera
  • Improved photo quality
System
Game Space
Smart display
Message
Weiß man denn, auf welche Version diese hier aufbaut? Beta 2?
Ich frage deshalb, ob sich der Umstieg lohnt inkl. eines Fullwipes.
Eine kleine Frage; ich habe die Beta 2-Version drauf. Wenn ich jetzt die Stable-Version will, muss ich dann wieder zuerst auf Pie downgraden und dann Android 10 hochladen? Danke
@fidus62 so in der Art wird es sein. Auf jeden Fall mit Fullwipe.
Reaktionen: fidus62
Ein Download für das 7'er existiert ja, nur nicht für die Pro.
Reaktionen: boOotdisk
Steht im vorigen Link:
However, if your device running the Open Beta version that OnePlus rolled out earlier this week, then you will need to manually install Oxygen OS 10 Android 10 full stock firmware (ROM) onto your OnePlus 7 (Pro) device via local upgrade method. The local upgrade method is fairly easy for anyone looking forward to an upgrade.
Reaktionen: fidus62
Reaktionen: iskalatur
Ich werde es mit TWRP versuchen und einfach drüber Installieren über die Beta2. Werd ja sehen ob es geht :D
Gibt's schon eine Fullzip?
Leider noch nicht.
@zaph wenn ich dies installiere , habe ich dann die Werkseinstellungen drauf und muss alles wieder installieren?🤔
@fidus62 ja, man wird auch gleich hingewiesen.
Reaktionen: fidus62
Basiert scheinbar nicht auf die beta 2, dann lass ich es mal.
auf ner älteren Version oder neuer als beta 2?
Laufen jetzt eigl Alternative Launcher unter 10 oder machen die Probleme?
Ich benötige zumindest ne Möglichkeit viele Apps bzw. nen Raster mit mehr Platz zu haben damit ich mehr Widgets etc. auf dem Desktop bekomme.
@Nuvirus laut meinen Recherchen ist es beta 1.
Alternative Launcher laufen perfekt, nutze den Nova ohne Probleme.
Reaktionen: Nuvirus
ja Nova hab ich auch gekauft nach Test der kostenlosen Variante nutze ich sowohl am Tablet als auch Oneplus 7 Pro.
Hieß es nicht das am Anfang die Launcher machen Probleme aufgrund dem vor und zurück an der Seite?
@Nuvirus hatte am Anfang Probleme damit. Mittlerweile geht's sehr gut.
Hat jemand schon das Update erhalten? Wird ja erst Mal wohl nur an wenigen Leute verteilt
NebulaOne
NebulaOne
NebulaOne
  • NebulaOne
2 3
NebulaOne
NebulaOne
NoNameRic
