AcmE85
Enthusiast
- 5.702
OnePlus hat soeben eine aktualisierte Community Build veröffentlicht.
Wie bereits vom OP2 und OPX bekannt handelt es sich hierbei um Test-Builds die manuell geflasht werden müssen!
Mit dieser Build soll man wohl nur community OTAs bekommen!
Offizielle OTAs erhält man nur per clean flash auf die letzte aktuelle OOS Version.
OxygenOS 3.5 Community Build for the OnePlus 3 - OnePlus Forums
OnePlus 3 OxygenOS 3.5.0 Community Build
What is OxygenOS 3.5?
Put simply, we think it’s a better OxygenOS. New features include:
Vorhandene Bugs:
- Several UI improvements
- New and improved OnePlus apps, including clock, weather and file manager
- Improved camera software
- More robust settings and and customization features
- Android Pay is not currently supported
- Only English is currently supported in several OnePlus apps
- Some performance issues
- Some UI issues when using custom themes
- System UI tuner is unstable (do not use); using the system UI tuner could cause serious issues that can only be resolved via factory reset
- You will need to re-register your fingerprints if you have fingerprint authentication enabled
