		Nurihan2018
Gast
Dr.Ketan ROM / Note 10 N975F/DS
Original Quelle
Weder ich noch Android-Hilfe übernehmen eine Haftung für eventuelle Schäden an euren Geräten..!!
⚠Durch das Rooten wird Knox auf 0x1 gesetzt und ist nicht wieder umkehrbar..!
Original Thema
Original Quelle
Original Thema
ROM Features (Pie)
Quote:
- Based on official Pie - check changelog for exact Info
- DEX supported
- S Pay with Gear wearable (Only supported models) - Provided you have installed required packages and hidden 'pay' stuff with magisk hide.
- Reduced call disconnect delay.
- High Volume warning disabled
- Screenshot in Secure Tab (ROM Tool - Mod & Fix - Enable Dual SIM + SD)
- Denoxed with minimally debloated (tried to preserve most functions though)
- 3minit battery (ROM Tool)
- Clock Position (Lt/Center/Rt) on the fly
- Dual SIM + SD support aroma selection (Recommended to enable this mod later from ROM Tool)
- GoodLock included without CSC restrictions (ROM Tool - GoodLock)
 - ClockFace
- LockStar
- MultiStar
- NavStar
- QuickStar
- Task Changer
- Added some important samsung stuff
 - Calculator
- Music
- S Health
- Probable fix for Titanium Backup schedule
- Internet browser Secret mode
- S Health patched for using with rooted device.
- Able to web login with biometrics on samsung browser
- ROM Tool with following options
 - Ad-Free Quick Panel Toggles
- Reboot Quick Panel Toggle (Reboot to magisk system)
- Auto detect Busybox and auto flash if requires.
- NavigationBar heights on the fly (Smaller/Stock)
- Long Press Home customization : Select Device assistance as LP Home from settings, then select if you want to use it to assign to any available app/service), You can reset choice from ROM Tool
- Scloud - As this is major battery killer, You ca enable/disable anytime from ROM control
- Fbind Helper : Small tool to use Fbind magisk module (Need to install separately from Magisk - Download - Magic Folder Binder. It is same like folder mount. You can mount Int SD folder to Ext SD
- Viper sound mode - Single click enable/disable Viper sound mode
- ROM Control - See below for more details
- Battery icon - stock/3minit battery on the fly.
- Clock Position - Left/Center/Right on the fly. (Center is useless because of central camera)
- Mods & Fix- Enable Dual SIM + SD support
- Netflix/Optus sport fix
- BT Pair fix - N960F ROM shouldn't have issue out of box but can trigger with flashing xyz, Use only if you are having issue
- Auto Call Record (Without CSC features)
- Biometrics on Reboot. (Currently this mod is not working)
- Update & Fix section
 - Battery Bar with thickness and color option
- Network meter with Toggle (Lt/Rt/Quick Panel/None) with color option
- Virtual Key with Toggle (Lt side - Menu, Rt side - Power, Centre - Home)
- Double tap statusbar to sleep
- Navigation Bar color
Installation und Download
Wichtig:
- Deine Garantie wird dadurch erlöschen.
- Samsung Pay und der sichere Ordner werden nicht mehr funktionieren, auch nach einem Unroot nicht. (Hoffen wir, dass dies in Zukunft auch, auf Geräten mit zerstörtem Knox funktionieren wird).
- OTA Updates funktionieren auf gerooteten Geräten nicht.
Installation:
Wenn Du von der orginalen Firmware und dem orginalen Recovery kommst, führe folgende Schritte durch:
Als erstes, roote Dein Gerät und installiere ein CWM kompatibles Recovery wie [tr1_old][td_old]TWRP (@hanspampel hat eine Übersetzung geschrieben wie man das macht, es war für das S10 aber so geht es auch beim Note 10/Plus) . Wenn du TWRP Recovery installiert hast, folge den nächsten Schritten.
Wenn Du ein custom Recovery installiert hast, folge den nächsten Schritten.
1. Downloade die Rom und verschiebe sie auf den internen oder den externen Speicher, überprüfe auch den MD5 Wert.
2. Begib Dich in das Recovery Menü, wähle “Factory Reset“ an, und flashe die Rom, die Du im ersten Schritt auf Dein Gerät kopiert hast. Wenn Du die Rom flashst, wähle „Flash vendor option“ im Aroma-Installer aus.
3. Es kann 6-7 Minuten dauern, bis die Installation abgeschlossen ist. Wenn die Installation abgeschlossen ist, wähle “Reboot“ und halte den Power + Volume Up Button. Wähle den Power Button, um fortzufahren, und warte, bis das Gerät startet.
4. Öffne Magisk, und prüfe ob es korrekt installiert wurde. Hier sollte “Magisk installiert“ angezeigt werden. Wenn du nach “Einrichtung der Umgebung“ gefragt wirst, lass dies zu und starte neu. Wenn Du den 3. Schritt nicht erfolgreich ausgeführt hast, wirst Du sehen, dass Magisk nicht installiert ist. Starte Dein Gerät neu und halte die Volume Up + Power Taste. Klicke auf die Power Taste und lass diese los, sobald Du dazu aufgefordert wirst. Nach dem Neustart sollte Magisk installiert sein.
5. Du erhältst eine Benachrichtigung zum Anwenden eines “Applying Essential Fix“. Erlaube diesen Fix. Solltest Du diese Meldung nicht erhalten, öffne das Tool (Magisk?) manuell.
6. Wenn Du um einen Neustart gebeten wirst, lass diesen bitte zu.
7. Wenn Du eine Gear Watch, oder ein anderes Zubehör verwendest, richte es ein und führe danach die persönliche Einrichtung durch.
8. Lasse das Gerät starten, und lese die ROM-Spezifikationen durch.
Fertig!
Einige ROM-spezifische Dinge
1. In der Rom ist keine CSC enthalten, da die CSC eine separate Partition besitzt (ODM). Die Rom löscht und verändert keine Daten in der ODM-Parition. Du hast Deine alte CSC auch nach dem flashen der Rom.
2. Die Vendor-Partition, muss im Aroma-Installer ausgewählt werden (ob diese geflasht werden darf).
3. Möglicherweise ist die OEM-Option in den Entwickleroptionen zu sehen, diese wurde jedoch deaktiviert, da ein Fix angewendet wurde. Im realen Fall, falls diese Option deaktiviert ist, kannst Du die ROM nicht mehr mit TWRP starten.
Lese das ChangeLog der Rom, um spezifische Anweisungen zu erhalten. Der Link zum ChangeLog, steht in Beitrag 3 bereit.
Kann ich die ROM “dirty flashen“? Nein, empfehlen wir auch nicht. Wenn Du in der Lage bist, die Konsequenzen eines “dirty flashs“ zu bewältigen, fahre fort, bitte poste dann aber keine Fehler im Forum, ohne die Rom sauber installiert zu haben.
PS: Wer mit den Folgen eines “dirty flashs“ umgehen kann, muss diese Fragen auch nicht im Forum stellen.
Download: www.drketanrom.com/note10.html
Die oben angegebenen Anweisungen gelten nur für die neuste Rom. In früheren ROM-Versionen kann es sein, dass diese nicht zutreffen. Wir empfehlen, nur die neuste ROM zu flashen.
Mitwirkende
dr.ketan → dr.ketan - Recognized Developer / Recognized Contributor - Gujarat, India - XDA Forums
ROM OS Version: 9.x Pie
ROM Kernel: Linux 4.x
Informationen zur Version
Status: Stabil[/td_old][/tr1_old]
