Domi_nex
Stammgast
- 145
@MasterOfSamsung funktioniert es nicht?
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Was wird da genau gepatcht?SoLdieR9312 schrieb:Dex Patch
commit d000665351d7b1489d430e256f01fb7d535f17dc
Author: Barna Keresztes <kbarni@kbarni.net>
Date: Fri Sep 15 20:29:08 2017 +0200
Dex support for any HDMI adapter
diff --git a/arch/arm64/configs/exynos8895-greatlte_eur_open_defconfig b/arch/arm64/configs/exynos8895-greatlte_eur_open_defconfig
index 2db14da..f44fc9a 100755
--- a/arch/arm64/configs/exynos8895-greatlte_eur_open_defconfig
+++ b/arch/arm64/configs/exynos8895-greatlte_eur_open_defconfig
@@ -3045,7 +3045,7 @@ CONFIG_SUPPORT_DOZE=y
CONFIG_SUPPORT_DSU=y
CONFIG_SUPPORT_HMD=y
CONFIG_DECON_SELF_REFRESH=y
-# CONFIG_DISPLAYPORT_ENG is not set
+CONFIG_DISPLAYPORT_ENG=y
CONFIG_LOGGING_BIGDATA_BUG=y
# CONFIG_SUPPORT_INDISPLAY is not set
CONFIG_DUMPSTATE_LOGGING=y
diff --git a/drivers/ccic/ccic_alternate.c b/drivers/ccic/ccic_alternate.c
index 838b0d9..0e07752 100644
--- a/drivers/ccic/ccic_alternate.c
+++ b/drivers/ccic/ccic_alternate.c
@@ -282,16 +282,6 @@ static int process_check_accessory(void *data)
USB_CCIC_VR_USE_COUNT);
#endif
break;
- case DEXDOCK_PRODUCT_ID:
- dock_type = CCIC_DOCK_DEX;
- pr_info("%s : Samsung DEX connected.\n",
- __func__);
-#if defined(CONFIG_USB_HW_PARAM)
- if (o_notify)
- inc_hw_param(o_notify,
- USB_CCIC_DEX_USE_COUNT);
-#endif
- break;
case HDMI_PRODUCT_ID:
dock_type = CCIC_DOCK_HDMI;
pr_info("%s : Samsung HDMI connected.\n",
@@ -313,6 +303,13 @@ static int process_check_accessory(void *data)
+ if (!dock_type || dock_type == CCIC_DOCK_HDMI || dock_type == CCIC_DOCK_MPA){
+ dock_type = CCIC_DOCK_DEX;
+ pr_info("%s : Samsung DEX connected.\n", __func__);
+#if defined(CONFIG_USB_HW_PARAM)
+ if (o_notify) inc_hw_param(o_notify,USB_CCIC_DEX_USE_COUNT);
+#endif
if (dock_type) {
usbpd_data->acc_type = dock_type;
ccic_send_dock_intent(dock_type);
