[ROM][JB][4.2.2][JDQ39E] CyanogenMod 10.1 BETA (Build 4)
gabsi
Arco hat eben CM10.1 released.
XDA Thread von Arco
XDA Diskussions Thread
Ihr könnt es nach der Anleitung von THE-E installieren.
Was funktioniert:
Audio
Telefonie
GPS
Compass
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
Camera
Torch
Wifi/USB tethering
Vsync
Ärgernisse:
Movie Studio läuft nicht stabil und kann ein "Einfrieren" des Bildschirmes verursachen.
Download:
  • 2014-05-09: CM-10.1 beta4 [DOWNLOAD]
    MD5SUM: c7e9114d760c0e924919b1be95425048
    • Various fixes
    • Kernel 3.4.89
  • 2014-01-25: CM-10.1 beta3 [DOWNLOAD]
    MD5SUM: 6626bdfc53d236e90537637aa11d2d13
    • Brought over various fixes from CM11, mainly video and memory allocation related
    • Kernel 3.4.77
  • 2013-12-24: CM-10.1 beta2 [DOWNLOAD]
    MD5SUM: b0841a719cee8b483bf51e643b6fd9f2
    • Hybrid ION/PMEM (credits to ADC-Team for their work)
    • Updated Adreno drivers
    • Brand new kernel based on CAF jb_2.5 branch
    • Kernel 3.4.75
  • 2013-10-10: CM-10.1 beta1 [DOWNLOAD]
    MD5SUM: 0086F7DE9B4561E31D130E55CABBF7ED
    • Workaround for white screen issue (thanks to Keff91 for the idea)
    • Kernel 3.4.65
  • 2013-09-25: CM-10.1 alpha9 [DOWNLOAD]
    MD5SUM: 73A9F9C65A414463BA75C4D73167016C
    • CM Account
    • Synced with CM 10.1.3
    • Kernel 3.4.62
  • 2013-08-13: CM-10.1 alpha8 [DOWNLOAD]
    MD5SUM: A55B60EADF32329B788EB6AE760BC813
    • Reverted patch causing battery drain (causes random white screen though)
    • Enable volume rocker and home button wake
    • Synced with CM (security fixes etc.)
    • Kernel 3.4.57
  • 2013-06-12: CM-10.1 alpha7 [DOWNLOAD]
    MD5SUM: 725DAAE6A58D16E040C64DE343D9E868
    • Disabled unsupported functions on front camera
    • Switched back to kernel 3.0 in order to get feedback on battery usage compared to 3.4 kernel
    • Kernel 3.0.81
  • 2013-05-28: CM-10.1 alpha6 [DOWNLOAD|MIRROR]
    MD5SUM: a6aab9ad73a5a8e27487a4e78764806f
    • Fixed WEP connection
    • Fixed bluetooth MAC address during boot
    • Kernel 3.4.47
  • 2013-05-12: CM-10.1 alpha5 [DOWNLOAD]
    MD5SUM: 369C24C1441F2FEC5ACC821B89A2D20D
    • Fixed wifi tethering
    • Fixed bluetooth file transfer issue
    • Fixed "pop" sound on shutdown and entering PIN (credits CastagnaIT)
    • Kernel 3.4.44
  • 2013-05-05: CM-10.1 alpha4 [DOWNLOAD] [MIRROR]
    MD5SUM: 3589DFAF223ABCE111880F79CB32409D
    • Fixed issue with certain games
    • Added fix for thumbnail size growing out of control
    • Fix for gps icon not going away
    • Kernel 3.4.43
  • 2013-04-22: CM-10.1 alpha3 [DOWNLOAD]
    MD5SUM: F016141C94BBA4DB01FFFAEA797D1094
    • Fixed VOIP
    • Display HAL updated to version 1.1
    • Added system.prop for switching SD cards without changing vold.fstab
    • Added support for GooManager (download/update rom)
    • Kernel 3.0.74
  • 2013-04-07: CM-10.1 alpha2 [DOWNLOAD]
    MD5SUM: FAE0E3ED1FCEAD84522E63088C6B6D0F
    • Disabled software HDR in camera app
    • Updated CM logo in boot splash (removed CID head as it was kinda pink)
    • Issue with audio routing after using Google Search should now be fixed
    • Scrolling in camera settings should not be messed up anymore
    • Fixed cLock weather due to API changes from Yahoo
    • Fixed torch widget
    • Enabled NTFS read support in kernel
    • Ad-hoc (IBSS) support added
    • Fixed WEP issue (credits to ivendor for finding this one)
  • 2013-03-30: CM-10.1 alpha1 [DOWNLOAD | MIRROR]
    MD5SUM: 479398DA64BA0F737F76DF6BE0D948DF
    • Erste Release
Für mögliche Fehler oder Verluste trage ich keinerlei Verantwortung. Alles auf euer eigenes Risiko!
Bitte bedankt euch bei Arco für diese tolle Arbeit!
Reaktionen: Kaio, hzprky, gerrus und 6 andere
So, ich habe es mir gerade geflasht und bin soweit auch ganz zufrieden.
Es gibt einige schöne Neuerungen, wie z.B. die Fähigkeit zum 2G/3G umschalten über die Benachrichtigungsleiste.
Jedoch vermisse ich in den Einstellungen die Bereiche Entwicklung und Leistung.
Wo finde ich die jetzt?
Entwickler Optionen und Leistung aktivieren:
Sieben Mal hintereinander unter Info auf die Build-Nummer klicken
Mein Fazit zur Alpha 1:
Sehr sehr schnell, alles was man braucht funktioniert und sie ist für den Alltäglichen Gebrauch tauglich.
Meiner Meinung nach die beste ROM für unser Galaxy W und es ist erst die Alpha 1!
Reaktionen: masterxxxxxxl
Sofern ich jetzt genug Beiträge hätte um mich zu bedanken, so würde ich es tun.
Vielen Dank.
Ich hoffe arco vernachlässigt die anderen ROMs nicht.
Vielleicht hätte er noch CM9 fertig bringen sollen. Ich denke 3 ROMs zu pflegen ist schon ne arbeit..
Gesendet von meinem GT-I8150 mit Tapatalk 2
Werd es direkt raufmachen :)
Aber was mich wundert warum schon alles läuft.
Ich kann mich noch daran erinnern das man für die Kamera bei CM9 und CM10 Monate gebraucht hat und jetzt bei CM 10.1 funktioniert sie sofort. Bin aber froh das alles läuft was man braucht :p
Da hat ja arco uns ein schönes Ostergeschenkt gemacht ^^
Achja an alle, schönen Ostersontag :)
Oh man und das genau dan wen mein Akku Defekt ist.... :(
Ärgerlich..... :S hat es schon jemand drauf ? Gibt es neuerungen in sachen Performance ?
Joa, ich hab nen leichten Performance-Schub bemerkt.
Ist es normal das die externe SD Karte nicht als external_SD angezeigt wird?
Ich kann sie z.B. nicht als Speicherort für die Kamera auswählen.
Sinus
@Sinus
Ja ist so! Du kannst es aber manuell ändern. Muss aber bei einem Update wiederholt werden!
Anbei die Erklärung bzw. TUT vo KaiRideBMX ;)
KaiRideBMX schrieb:
1. Hab ich für leute die es interressiert letztens gepostet wie es geht: https://www.android-hilfe.de/forum/...hen-remapping.168913-page-5.html#post-5375039 und war en kleiner fehler drinn hier ist der post wo ich geschrieben hab was im langen post der fehler war https://www.android-hilfe.de/forum/...hen-remapping.168913-page-5.html#post-5458615
Wie ich das remappen kann ist schon klar. Mir würde es schon reichen wie im Stock unter der internen SD Karte einen Link external_sd zu haben, und diesen dann in der Kamera auswählen zu können.
Der ursprüngliche Beitrag von 11:42 Uhr wurde um 13:40 Uhr ergänzt:
Was mir jetzt auch noch aufgefallen ist, die Kamera funktioniert zwar, aber ich kann nicht zoomen und auch die Auflösung verstellen geht nicht. ist das bei euch auch so?
Sinus schrieb:
][/COLOR]Was mir jetzt auch noch aufgefallen ist, die Kamera funktioniert zwar, aber ich kann nicht zoomen und auch die Auflösung verstellen geht nicht. ist das bei euch auch so?
Bei einer Auflösung von 5 Megapixeln kann unser W nicht zoomen. Du müsstest zum zoomen die Auflösung runterstellen, aber wieso das bei dir nicht klappt weiß ich nicht.
Bei mir funktioniert alles einwandfrei.
wie stellst Du die Auflösung ein? im Kameramenue, wo man auch einstellen kann ob der Standort verwendet wird? Da sehe ich zwar die 5 Megapixel, kann aber nichts verändern...merkwürdig.
Sinus
Was ist das schlimmste, war hier passieren kann, wenn was schief läuft (also beim Umstellung auf CM)? Das man das Gerät ggf. nicht mehr verwenden kann?
Positiv, dass man etwas ganz falsch macht, kann man einen Hardbrick Hervorrufen, dann muss das Board getauscht werden, oder man muss mit JTag vorgehen ,was viele nicht können/ haben, damit es wieder funktioniert.
Hat jmnd Ahnung, wie ich bei cm10.1 den Speicher swappen kann? Ich habe es mit der App probiert, jedoch schmieren die EInstellungen ab, wenn ich auf die Rubrick Speicher gehe, ansonsten funktoniert es.
Wie man den Speicher swappt steht im Link auf der ersten Seite.
Sinus
Um hier was falsch zu machen muss man sich ziemlich blöd anstellen.
Was für eine ROM hast du denn aktuell? Wenn du bereits eine Recovery (TWRP oder CWM) drauf hast kann eigentlich garnichts mehr schief gehen. Du musst nur Schritt für Schritt der Anleitung folgen.
Für den Fall dass du das nicht tust könnte das passieren was masterxxxxxxl schon schrieb.
@Sinus: Du musst erstmal die Hintere Kamera auswählen, dann ins Einstellungsmenü und die Auflösung antippen. Dann sollte sich ein weiteres Menü öffnen, in welchem du die Auflösung einstellen kannst.
@masterxxxxxxl: Speicherkarte Swappenhttps://www.android-hilfe.de/forum/...od-10-1-beta-build-4.400362.html#post-5499105
Reaktionen: Sinus und masterxxxxxxl
@gabsi
Ich habs nochmal neu geflashed, jetzt geht das auch mit der Kamera.
Jetzt flutscht es.
Sinus
Der ursprüngliche Beitrag von 12:28 Uhr wurde um 12:29 Uhr ergänzt:
[/COLOR]
Momentan verstehe ich noch nicht alles^^. Ich habe 2.3.6 GB drauf. Wie kann ich die ROM Version nachsehen?
Recovery habe ich noch keines drauf. Ich wollte wenn, gerne diese neueste Version des CM 10.1 für 4.2.2 drauf machen.
Was heißt eigentlich, man soll als Recovery ClockWorkMod v.6.0.1.2 flashen. Was passiert bei diesem Schritt?
LG Finch
Du hast momentan als ROM die originale von Samsung drauf (2.3.6 GB), auch Stock-ROM genannt.
Die Recovery ist eine tiefere Ebene und dient um ROMs, Kernels, Basebands, etc. zu flashen. Dort aber bitte direkt die aktuellste Version nehmen, das ist derzeit 6.0.2.9 bei unserem Gerät. Die Recovery bietet noch weitere Funktionen, zum Beispiel das Erstellen von Backups oder das Formatieren verschiedener Bereiche des Handys. Einfach mal flashen, dann siehst du es. Die Anleitungen findest du alle hier im Forum.
Falls dir das alles nicht gefallen sollte (was ich mir nicht vorstellen kann) gibt es immernoch Möglichkeiten das Handy wieder in den aktuellen Zustand zu versetzen.
masterxxxxxxl
Dattel
ClemiMD
Chris123456
Androidister
