G900F [ROM][5.0][XXU1POFA] *18.06.15* Omega v18.0 [Omega Files][Kernel]
Schmidt9
Schmidt9
Omega v18:
  • Based on firmware XXU1POFA Android 5.0
  • Added:
  • Modded and Stock button mappings added to aroma as an option
  • Sec Kids Mode Installer added to aroma as an option
  • Updates:
  • Omegas Multi csc updated with new csc
  • Play Store
  • Samsung IAP
  • ANT+ Plugins Service
  • Chrome
  • Drive
  • Docs
  • S Note
  • S Translator
  • Backup Manager
  • Flipboard
  • Google Search
  • Google TTS
  • Google+
  • Maps
  • Phone Info Samsung
  • YouTube
  • Removed:
  • ChatON
  • All mods from previous Omega Lollipop 5.0 versions added
  • Rom is Deodexed + Rooted + Zipaligned
  • Rom is No Full Wipe
[ROM][G900F][5.0][XXU1POCF] *15.03.15* Omega v17.0 [Omega Files][Kernel]
Please read this post carefully.
Here you will find all information you need for the latest Omega Rom.
Do not download and flash before reading all the info provided here!
Download Center can be found at the end of this post
Changelog:
  • Based on firmware XXU1POCF Android 5.0 (Date: 15/03/2015)
  • Added:
  • Updates:
  • Play Store
  • Samsung IAP
  • Chrome
  • Drive
  • Docs
  • S Note
  • S Translator
  • Backup Manager
  • Flipboard
  • Google Search
  • Google TTS
  • Google+
  • Maps
  • YouTube
  • Removed:
  • ChatON
Omega Files:
Omega Files Pro:
Direct Download Links for v16 with resume option added to Omega Files Pro
OTA Update Notifications
Update repo to Omega Files Pro to get the updates for v16
Please read the following before flashing v16:
knox:
Omega Rom can be flashed only with a custom recovery.
This mean the knox will be triggered and your warranty will be void, more info:
All you wanted to know about KNOX Void Warranty 0×1
Wipe:
This Omega version is a Full wipe rom even if you are coming from a previous lollipop Omega
Backup:
Make sure to make and keep in a safe place an efs backup - nadroid backup - titanium backup - etc, in case you ever need to restore!
Installation:
1. Backup your device (nadroid backup, titanium backup, efs backup ... etc) and save the backup to a safe place.
**if you already run TW android 5.0 on your device ignore step 2.
2. Flash your variants stock Android 5.0 (Lollipop) firmware with odin
**if you already have custom recovery compatible to Lollipop like the latest TWRP ignore step 3.
3. Flash a custom recovery (Latest TWRP is the recommended one) with odin
4. Boot to Recovery (if you are using Philz recovery flash from internal sdcard only) and flash Omega with full wipe, first boot will take about 10 to 15 minutes
5. When android loads reboot device to install Data/app partition applications (first boot installs system apps, reboot installs data apps)
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
Omega Files Repo:
Omega Files repo is ready and included in Omega Files Free and Pro
SuperSu:
If needed open SuperSu and update SU binary, then choose normal and reboot device.
Remove bloatware:
You can remove all bloatware during Omegas installation - Screenshot with Omega de-bloated
csc:
Multi csc included in Omega
Tips:
*Paypay with Fingerprint scanner works only with stock kernel, Flash stock Kernel from Omega Files
*To change Battery icons use 3minit batteries app, more than a thousand battery icons included.
*3Minit Battery mod can be removed from Omega Files
*Change Battery icons to Stock from 3Minit Battery app if you want to keep Sfinder small button at Notification Panel
*For Accuwheather widget transparent go to Accuwheather widget Settings and select the Widget transparency you like
If you like Omega v17 + Omega Files app and you use them please consider a donation.
Finde die v15 nirgendwo :sad:
Und die v14 zieh ich gerade mit 100kb/s sowas ist echt zum K...
Bin aber gespannt auf dieser Rom, gibt es zufällig ein dunkles tw thema
Habe den Startpost nun mal angepasst. Sollte mir ein Fehler unterlaufen sein, meldet euch bitte bei mir bzw. meldet diesen. Möglicherweise werde ich einen neuen Thread für die Lollipop-Version erstellen, damit da keine Komplikationen und Missverständnisse auftreten.
Reaktionen: Schmidt9
Gerade mal ein wenig gelesen... uff. Ich bin ganz froh noch die 13 drauf zu haben :)
WENN ich das mache, dann würde ich vorher die original Samsung Lollipop flashen und dann Recovery + Omega 14 oder höher.
Aber nun mal ein paar essentielle Fragen:
- geht denn XPosed jetzt? Auf deren Homepage steht nämlich nix von Lollipop.
- geht XPrivacy (Xposed Module) denn, falls XPosed läuft?
Danke für die Hints!
Da Omega auf Samsung FW basiert würde ich es nicht versuchen, da auf Stock Bootloop kommen sollen.
Xposed läuft grundsätzlich mit lollipop, nicht aber mit samsung-basierten ROMs! Da müssen wir noch etwas warten!
In v15 läuft der SPlaner nicht ... kann das jemand bestätigen?
Wo hast du die v15 her?
Bist du Betatester?
Sagen wir mal so...ab und zu darf man nicht nur nehmen! ;-)
na dann wie soll das jemand bestätigen :D Die V15 kommt heute oder morgen
Es gibt ja mehrere, die nicht nur nehmen ;-)
Habe das Problem inzwischen gefunden! Die V15 ist eine FULL WIPE ROM! Nur drüberbügeln reicht also nicht!
hei
15 ist da
gruß
Omega v15 Opening Post and Download Center
For Galaxy S5 G900F – G900I – G900M – G900T – G900W8
Changelog:
Based on firmware DXU1BOC2 Android 5.0 (Date: 11/03/2015)
New:
Omega kernel for G900F and Omega kernel for G900I
Build from Samsung LL sources
Build with Toolchain 4.8
Selinux status set to Permissive
ExFAt sdcard support
Busybox
init.d support
Insecure
Adb Insecure
Mods:
App ops enabled at settings
sms save and restore option
Removed:
Security warnings
Added:
More csc to choose as default during installation - new countries: ETL - Czech Republic & BRI - Taiwan
Updates:
Omegas Multi csc updated with 32 new csc
Dolphin Browser
Google Drive
Google Play Books
Google Talkback
Maps
WiFi Scuduler
Rom is Full Wipe
Omega Files:
Omega Files Pro:
Direct Download Links for v15 with resume option added to Omega Files Pro
Update repo to Omega Files Pro to get the updates for v15
Please read the following before flashing v15:
knox:
Wipe:
Backup:
Installation:
Omega Files Repo:
SuperSu:
Remove bloatware:
csc:
Tips:
Download Center:
Please do not make mirror links
Donation:
If you like Omega v15 + Omega Files app and you use them please consider a donation.
Enjoy the new Omega
Reaktionen: Riggo, Dreamweaver und hoffisoft
hei
irgend etwas stimmt da nicht.
habe das Omega logo 30 Minuten laufen lassen. no start
bat. raus neu gestartet jetzt ist er am optimieren.
danach alles ok
gruß
Welche Datei im in einer custom rom sorgt dafür das mit den vol tasten Musik Titel gewechselt werden kann
Hab ich das richtig verstanden, wenn ich die v14 drauf habe muss ich wenn ich die v15 drauf machen will erst ne Stock flashen
Nein musst du nicht, ist nur empfohlen, wegen bl und modem. Ansonsten mit fullwipe flashen. Das ganze gilt so hab ich das mal verstanden wenn due von v13 auf v15 upgraden willst.
LG msprenger
Reaktionen: SemperFi-72
Also bis jetzt läuft V15 super bei mir.
msprenger
Foh
Foh
Schmidt9
DrOidAnDy
DrOidAnDy
Triple_H72
Nobby1960
Nobby1960
