[ROM][AOKP][ICS] Android Open Kang Project
Keinbockwurst
Keinbockwurst
Enthusiast
670
Schaut mal, was ich schönes gefunden habe.
[i9001][ROM][AOKP][ICS] Android Open Kang Project - xda-developers
What's working:
- Anrufe und SMS
- Wlan
- 3G
- Bluetooth
- BT handset
- GPS
- Kamera
- Themes
Not working:
-USB-tethering
Changelog(Crybert Releases) :
Code:
build 5
(new) modded kernel (compiled with gcc 4.4.3, based on ivendor) smartass2/sio/vr
(removed) Trebuchet Launcher
(fixed) Bluetooth deepsleep problem (thanks @ivendor)
(new) inverted Mms (thanks @speedydaniel)
(new) inverted Contacts (thanks @speedydaniel)
(new) inverted Email (thanks @speedydaniel)
(new) inverted Calendar (thanks @speedydaniel)
(fixed) wrong translation in ROMControl
(added) ability to disbale/enable BLN in Settings->Display (thanks @ivendor)
(fixed) USSD bug (thanks @ivendor)
(Fixed) an issue with deep sleep and BLN (thanks @ivendor)
(Fixed) BLN in deep sleep mode (WARNING! it means that BLN will stop deep sleep while the keyboard led is powered on) (thanks @ivendor)
(Fixed) audio on voip calls (thanks @ivendor)
(fixed) OTAUpdater manually flashing
changed some repos
more to come
build 4
(fix) init.d support
(new) BurstMode Feature for Camera (merged from CM9)
(new) Big Caller Photo (Credits mnazim)
(new) Hardware Info in Settings
(new) added OTAUpdater in Settingsmenu
added latest changes by arco/ivendor:
Lowered haptic feedback strength (credits @arco)
Powersave governor and limited min frequency in offline charging mode (credits @arco)
Updated wifi driver and changed wifi country code to ALL (credits @arco)
Fixed issue with turning on phone when charging (credits @arco)
Fixed non working zRam (credits @arco)
Kernel improvements from arco's trunk
More bitrate for 720p video recorded.
New static boot logo with cyanogen logo
build 3
-(new) added CM9 Browser to sources
-(Removed) AOKP Browser from sources
-(new) added CM9 MMS to sources
-(Removed) AOKP MMS from sources
-(Removed) Achromatic theme from sources
-(new) added German Translation to AriesParts
-(new) added DockSettings
-(new) added OTAUpdater Support
-Synced with latest ivendor sources:
-Fix battery drain when switching 2G/3G toggle
-Added Hungarian translation for Backlight Timeout Credits @czobor
-Smoother picture shot with camera
-Fixed issues with 5-picture camera crash
-Revert lastest Adreno libs to fix 720p video recording
Build 2
-(fixed) Date not shown in Notification
-(new) LongPressToKillApplication
-(removed) NovaLauncher.apk
-(added) HoloLauncherHD.apk
Build 1
-Release
Changelog(Oisis Releases) :
Code:
Beta-11:
- New apps: Launcher2.apk, OiSiSPapers.apk
- New bootanimation
- New media_profiles.xml
- Libs for camera
- Changes in build.prop
RC1
- Latest HAL wrapper(ivendor)
- Latest AOKP sources
- New bootanimation
- New graphics drivers
- New wallpaper - if you don't like it or want AOKP just delete /system/app/OiSiSPaper.apk
- In-call volume - not tested
- Kamera fixes
- [U]UNSTABLE[/U] (Nehmt Beta 11)
Beta-10
- Fixed WiFi thetering
- New kernel drivers(BT, WiFi)
- Data meter fixed
Beta-09
- basierend auf AOKP Build #40
Beta-08
- Incall volume patch included
- Added nano
- Added wireless-tools
Beta-07
- Build 39 - [URL="http://aokp.co/site/index.php?/topic/437-release-build-39/"]AOKP Build 39  Changelog[/URL]
- Added apps: (GanOptimizer, Provision, QuickSearchBox, SpeechRecorder, Stk, Tag, VoiceDialer, DreamTheater)
- AOKP Stats
Beta-06
- Camera test 01 included(use Camera360 or PuddingCamera)
- New build.prop tweaks
- OiSiS kernel 01 included
Downloads(Crybert):
Build 5
- Dev-Host - aokp_ariesve_milestone-6_build_5.zip - The Ultimate Free File Hosting / File Sharing Service
Build 4
- Dev-Host - aokp_ariesve_milestone-6_build_4.zip - The Ultimate Free File Hosting / File Sharing Service
Build 3
- Zippyshare.com - aokp_ariesve_milestone-6_build3.zip
Build 2
- aokp_ariesve_milestone-6_build2.zip
Build 1
- Zippyshare.com - aokp_ariesve_milestone-6_build1.zip
Downloads(Oisis):
Beta 11
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-11.zip
RC 1
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-RC1.zip
Beta 10
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-10.zip
Beta 9
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-09.zip
Beta 8
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-08.zip
Beta 7
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-07.zip
Beta 6
- http://www.broken-arrow.pl/oisis/aokp/i9001-aokp-beta-06.zip
Addons/Patches(Nur für Oisis-Releases):
- In-call-audio-patch:
- http://www.broken-arrow.pl/oisis/aokp/aokp-soundpatch-01.zip
- Kamerapatch 01:
- http://www.broken-arrow.pl/oisis/aokp/aokp-camtest-01.zip
- Oisis-Kernel 01
- http://www.broken-arrow.pl/oisis/aokp/kernel-aokp-01.zip
- Arcos Standard CM9-Kernel
- http://www.broken-arrow.pl/oisis/aokp/kernel-arco-cm9.zip
crybert schrieb:
Hey,
ich habe mittels des PDroid-ICS-Patchers von Pastime1971 (xda) einen Patch für die AOKP Beta07 erstellt.
Funktioniert bei mir ohne Probleme. Der Patch enthält einige veränderte jar Dateien, die PDroid benötigt um richtig zu funktionieren. Näheres dazu hier: [APP] PDroid - The Better Privacy Protection [2012-03-18: Bugfixes in Patch 1.32] - xda-developers
Installation
1. Downloade den Patch
2. Flashe die zip via Recovery
3. Reboote
4. Downloade PDroid aus dem PlayStore
Download
Patch
Restore
Hinweis
Mit der Restore.zip könnt ihr wieder den Ursprungszustand herstellen.
Installation:
Installation:
1. Arcos CWM verwenden Anhang anzeigen CM9_Recovery.zip (zip, welche im Feamod installiert wird und diesen durch CWM ersetzt) Alternative Installationsmöglichkeit per ODIN als one-package: recovery-clockwork-5.5.0.4-ariesve.tar.md5
2. Wipe: data, cache, dalvik-cache
3. Installation von i9001-aokp-alpha
4. Wipe: data, cache, dalvik-cache
5. Google Apps flashen Google Apps Download (CWM-package)
6. Wipe: data, cache, dalvik-cache
7. Fix permissions
8. Viel Spaß!
Screenshots:
Reaktionen: M@rco, Starship706, Flextrick und 7 andere
Was ich mich schon immer fragte, bietet AOKP eigentlich mehr Features als CM9?
Echt schön noch ne ICS Rom hier zu sehen^^.
vorallem je mehr roms und je mehr leute sich mit sowas beschäftigen, desto größer ist die chance, dass man bald nen dev findet der die kamera fertig macht :)
Ähnelt meiner Meinung nach sehr CM9. hat aber einige sehr Interessante Features und ist deswegen eine gute Alternative, sobald es läuft. ;)
Oh ja, die Kamera.. Mein Sorgenkind. :D
Ja. Allerdings hat CM9 kräftig in Sachen Features nachgelegt, und mit Reloaded ICS statusbar mod hat man unter CM9 auch eine viel besser konfigurierbare Statusbar. Da fehlt nur noch eine Wetteranzeige, die AOKP hat.
Hier ist ein Video (auf Englisch), was viele AOKP Features zeigt:
aokp
Reaktionen: change63
Sieht richtig gut aus !
Sobald die Cam funktioniert,werd ich mir die auch flashen.
Wenn beides gleich gut läuft werde ich wohl auch eher zu AOKP greifen. :thumbsup:
Funktioniert eigentlich das Touchscreen schon??
Nein, funktioniert noch nicht.
oisis ist wohl mit der Kamera und diversen Kernel-Spielereien derzeit ausgelastet...
Athanatos
Nein.
Gesendet von meinem GT-I9001 mit Tapatalk
Dann muss man halt noch warten, aber das mit der Kamera hört sich doch sehr gut an!!! Die müsste dann ja auch im CM9 funktionieren!! Hoffentlich funktioniert die bald.
also auf kamera könnt ich verzichten aber auf den touchscreen irgendwie will i da net drauf verzichten :)
Auf den Touchscreen kann man auch schlecht verzichten. :p
Hauptsache die Kamera funktioniert :)
War ein Scherz :D
Es gejt ja um die Cam im CM9. Wie sollte er in einer ROM, bei der kein Touchscreen geht, die Cam weiter entwickeln?
Außerdem funktioniert die Kamera in CM9 auf unserem I9001 teilweise schon.
Je nach Kombination APP/Libraries kann man Photos machen, Panorama-Bilder aufnehmen, kurze Clips drehen, oder die Front-Cam funktioniert.
Das was jetzt kompliziert ist, ist das, herauszufinden warum was wann funktioniert, und das irgendwie zu einer voll funktionierenden Kamera zu kombinieren.
Gruß!
Lt. Oisis wird er ab nächster Woche oder am kommenden Wochenende an einem neuen Kernel arbeiten, mal schauen ob wir da schon was neues haben.
Habe ein paar private Worte mit ihm gewechselt. Unter Umständen wird es sogar ein 3.X Kernel.
Sind ja bei allen neueren Modellen mit ICS Standard, und sollen eine bessere Hardwareverwaltung (=schneller?) bieten.
[Mobil gesendet][GT-I9001]
[CyanogenMod9 by Arco]
Touchscreen gefixt, Alpha 2 da! Alles weitere ist dem Startthread zu entnehmen. :thumbsup:
Reaktionen: Pereira.Pedro
Aber läuft noch nicht gut oft kommt außen Rum so ein rotes Rechteck und es hängt oft leider
  • Lohenstein
se1111
Rhonin
Blackjubel
Blackjubel
Rhonin
TimoMF
