[AOKP-ROM][JellyBean] *02.09.13* [4.2.2] Resurrection Remix [V. 4.0.7]
Masta_Gee81
Masta_Gee81
Enthusiast
5.396
[ROM] GT-I9100 Resurrection Remix® v4.0.6 [12/08/13] PA.AOKP.CM (4.2.2)
About Resurrection Remix ROM ®
Changelog
Installation
Downloads and useful links
Donations
Resurrection Remix the ROM has been based on AOKP, CM, PA and original Remix ROM builds, this creates an awesome combination of performance, customization, power and the most new features, brought directly to your Device
[FONT=Verdana, Arial, Helvetica, sans-serif]Many things that in previous versions were tweaked with mods, are now included by default in the ROM so, please enjoy![/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Resurrection Remix[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]supporting many devices[/FONT]
Special thanks to the AOKP team ParanoidAndroid team, the CM team, and of course to all the supporters
Included Mods
-HALO & Colors
-PIE & Colors
-Hybrid Settings
- Music Toggle
-Halo toggle
-Hybrid Toggle
-Full AOKP toggles
-Pitch Black UI Mode
-ListView Animations
-Disable full screen keyboard
-Keyboard rotation/rotation time
-Lockscreen see through
-Show wifi name
-Headset action
-Low battery warning
-Lock clock widget
-Dash clock widget
-Privacy guard
-Permission management
-Lockscreen tint colors
-Ribbons
-Lockscreen walpaper
-Power sounds
-Share rom
-More batteries
-Changelog
-Lockscreen options and tagrets
-Center Clock/No clock/Right Clock
-AM/PM display
-AOKP clocks and Digital Clock
-New Wallpapers
-Volume rocker moves cursor when keyboard is open (optional)
-Nova/Stock launcher included
-%1 battery mod and CircleMod battery
-Brightness adjustable via statusbar if auto brightness is disabled. It even shows your current brightness percentage as you slide!
-There's also a "Emergency Broadcast Settings" that allows you to check/uncheck for notifications of "Amber Alerts" and other such Local Emergencies. I personally haven't seen this yet in the other Jelly Builds.
-Change NavBar targets and long-press actions
-Battery Bar
-Change NavBar height
-Volume Panel (Volume Rocker allows you to change ALL volume levels in one Menu)
-Notification Counter
-Disable Boot Animation
-Device Options (Color Tweaks)
-Led Options (Color and Pulse Rate)
-NFC Polling Mode (NFC with Screen Off or Locked)
-Theme Engine
-Quiet Hours
-T9 Dialer
-Notification Shade Wallpaper Changer (And Transparency)
-Lockscreen Wallpaper Changer
-Wait To Lock Screen
-Volume Wake
-Quick Pin Unlock
-Phone Face-Down Ringer Setting (Silent/Vibrate)
-Headphones Plugged in Ringer Setting (Silent/Vibrate)
-Bluetooth Connection Ringer Setting (Silent/Vibrate)
-Lockscreen Weather
-Performance/Color Settings
-Brightness Control Slider
-Added Device (Color) Settings To Maguro
-Flip Phone To Silence Incoming Call
-NavBar Open/Close Notification Shade Option
-A Plethora of BugFixes and Updated Translations
AND MORE....
-Installation-
1.- Wipe data / factory reset (mandatory if you coming from STOCK OR 4.2.X version or another ROM)
2.- Install the Main ROM
3- install gapps
4.- When you're back on recovery go to Advanced
5.- Wipe Dalvik Cache
6.- Fix Permissions
7.- Wipe Cache Partition
8.- Reboot
IMPORTANT: If you come from another ROM, have some issues or want a really clean installation then follow the 'Extended steps to install the ROM' featured on the General FAQ
Installation Files
ROM
Gapps
P.S. Danke drücken kostet nix :)
Reaktionen: s2i9100, m3stolo, xnicplayax und 124 andere
ICS 4 (SDK) läuft mittlerweile auf dem Nexus One!
:thumbup: KI8 Soon at 22.10.2011. :thumbup:
Hat die schon jemand drauf und kann was dazu sagen ?
Thx
wann kommt die ROM raus?
soll im laufe des tages rauskommen :cool2: ca. 16-17Uhr oder früher laut bezke
Kann man bei dem ICS Launcher Home, Zurück und Menü irgendwie ausblenden? Falls nein, dann ist dieser Launcher - sofern man kein Galaxy Nexus besitzt - komplett sinnlos, da die Buttons übereinander doppelt vorhanden sind.
gute frage : das kann man aber erst sagen wenn die rom im laufe des tages zur verfügung steht ...
aber interessieren würde mich das auch :cool2:
Also ich gehe mal davon aus, dass der Romersteller den ICS Launcher 1:1 übernimmt, wie er entwickelt wurde. Gibts auf XDA und im Market. Aber wir werden sehen.
hmm das wäre eigentlich ne stock mit launcher ... so wie du es meinst ..
oder???
also ich hab mir mal den thread von xda durchgelesen , es sollen sehr viele mods in der rom integriert sein ...
wir werden sehn ... ich werde es auf jedenfall mal testen ...
Ja irgendwie macht die doppelte Belegung das Display auch viel kleiner...also nicht unbedingt Vorteilhaft oder ;) Weiß denn jemand wann ca. 4.0 raus kommt ?
Moin Timsen ... ich glaub das weiss keiner so genau ... also du meinst die 4.0 Org. oder??
Weil die Rom hier ist nur Imitat wenn man das so sagen kann ;)
Google will ja den Launch von ICS voran treiben, damit Entwickler alle die gleichen Vorrausetzungen haben .
Ich denke, dass Samsung wohl einer der ersten sein wird.
Die haben ja schon eine ganze Weile damit gearbeitet.
Vielleicht kriegen wir um Weihnachten rum die ersten Leaks. Cyanogen wird sicher noch etwas schneller sein.
Getalptalkt von unterwegs
Ki8 Online ....
Downloadlink im ersten Post ... viel Spass ...
Ja Masta das meinte ich ;) Ich bin mal gespannt..und nein bis Weihnachten warte ich nicht..ich kaufe mir dann lieber das Galaxy Nexus bevor ich so lange warte...
Wie ist das Rom so ?
Ich muss erst Backup etc. machen ...
Werde die Rom denke ich morgen Testen und berichten ...
Ja aber wegen 4.0 jetzt ein Nexus zu kaufen , weiss nicht .. .
Also ich warte lieber ... ich bin super zufrieden mit meinem POWER S2 :drool:Best Phone Ever ...
Tchüss Apple:thumbdn: und Lernen von Samsung :thumbup:
bin sccho gespannt auf deinen bericht und screenshots:razz:
Sorry komm leider nicht dazu ... hab noch 3 andere Roms zum testen...
Wenn jemand die rom draufhat bitte berichten .... Danke!
NEU XWKJ1 Gingerbread 2.3.5
SPECIFICATIONS:
- Based on XWKJ1 Gingerbread 2.3.5
- Multi CSC GT-I9100OXAKI4
- Deodexed
- Speedmod k2-13 kernel
- Old Crt tv oFF anim added
- Overscroll glow (by default)
- Init.d tweaks added
- Google Talk with Video
- muveszur's Mms added /no auto convert after 4 sms, ...../
- GPS settings to europe /use fasterfix to any else/
- Wifi hacks added /thx to snake rom's/
- Adfree host list added /you dont the advertisements/
- some app added into data dir: cwm man, home swtchr, quadrant, miui music, voltage ctrl,
- wallpapers, cf3d plugins, install to sd card
- Percentage battery
- Modded TW4 with 5 icons
- Phone call record added
- Browser with user agent and without overglow
- modded some application to Ics themed
- and so many goods...
echt coole ROM, danke! ;) sieht gut aus, zwar nicht komplett genau so wie ICS, aber trotzdem gut und läuft sehr stabil, wegen den touch-keys braucht ihr euch keine Sorgen zu machen, die sind nur im Launcher vorhanden, ich empfehle ihn auch zu löschen, da er sowieso total verbugt ist. Stattdessen benutze ich Go Launcher EX mit nem ICS-theme!
Pr0TuRk38
abccba97
X IE N o T IR i X
X IE N o T IR i X
antsa
