Status des Themas:
Es sind keine weiteren Antworten möglich.
  1. Cpt. Future, 17.06.2012 #1
    Cpt. Future
    Cpt. Future Threadstarter Gast
    SVA ROM JB v5.1 Superb UBLS4 from 30-12-2012 (the my latest firmware for GT-N7000)
    Includes all the latest mods and patches.
    Default - battery-bagel and normal icons in the status bar.
    Mods of batteries and type statusbar put separately to taste, as well as enable/disable scrolling cache, and a scrollable desktop with auto-rotation.
    Download:
    MD5: 1144a026c0a20731f0b20ab2d194add6
    Hier mal zwei FTP Mirrors für die letzte SVA Rom danke an Fred
    Mirror 1
    Mirror 2
    ........................................:rolleyes2:........................................
    SVA ROM JB v5.0 UBLS4
    First, put SVA ROM JB v5.0 UBLS4, then upgrade.
    Download:
    • MD5: 89bf3b94688c7d94c3fee2a8bc5e0a09
    • Upgrade to version SVA ROM JB v5.1 Superb UBLS4 with 23 toggles and all
    usual mods and my additionals:
    md5: 52a876db344dd1f2dabcaedd60236f59
    • LidroidSettings (QuickPanelSettings) - I foggot include it in ROM. You can download it from here
    • 23 toggles Battery & statusbar mods for UBLS4
    • Big stock battery and big icons in statusbar: here
      Big circle battery and big icons in statusbar: here
      Normal stock battery and normal icons in statusbar: here
      Normal circle battery and normal icons in statusbar: here
    • TW Scrolling wallpaper: here
    • TW Autorotation home screen mod: http://narod.ru/disk/64505762001.88b...patch.zip.html
    • Slightly updated framework for v5.1 and fix power_profile.xml: download
    Screenshots hereInk effect for SVA ROM JB v5.1 Superb UBLS4 (thanks majdinj): sva_ink_effect_ubls4.zip
    Screenshots hereMods: Disabling & enabling scrolling cache for UBLS4
    Disabling scrolling cache: here
    Enabling scrolling cache: hereAdvanced mod of SecPhone.apk for UBLS4 here
    1. Integrated call recording
    2. Disabled increasing the volume when receiving a call
    3. Off Delay after the call disconnected
    4. Off message notification service in dialer ("Incoming call", "includes conditional call forwarding"
    1. "Call divert", "Call on hold," "Transferred call", ...)​
    Stock dialer for UBLS4: here
    Upgrade to version SVA ROM JB v5.1 Superb UBLS4 with 23 toggles and all​
    Einzig die Quickpanel Settings ergeben nen FC der Settings.
    Screenshots:
    [​IMG] [​IMG]
    Power_profile fix
    <item name="cpu.idle">4</item> // kernel number
    <array name="cpu.active">
    <value>577</value>
    <value>408</value>
    <value>249</value>
    <value>148</value>
    <value>55</value>
    </array>
    <item name="battery.capacity">2100</item> // batteri capacity
    to:
    <item name="cpu.idle">2</item> // kernels
    <value>577</value>
    <value>408</value>
    <value>249</value>
    <value>148</value>
    <value>55</value>
    </array>
    <item name="battery.capacity">2500</item> // battery capacity
    Did Ink effect for SVA ROM JB v5.1 Superb UBLS4 (thanks majdinj)​
    Screenshots:
    [​IMG] [​IMG]
    Hier das erste Theme für die v5.1,
    Dank meines Freundes tobiasos
    sieht mal wieder richtig cool aus :D
    [​IMG][​IMG]
    das mit der zu kleinen ausgeklappten Statusbar liegt an meiner 213 dpi und nicht am Theme ;)
    SVA ROM JB v4.5 XXLSC Superb 09-12-2012
    Changelog:
    1. Two themes - standard blue _SVA_ and stock green with simi-transparent pulldown and all the usual _SVA_ mods
    2. Two types of toggles: standard stocks and 23 toggles.
    3. Includes all the latest bug fixes and mods
    Original post with screenshots (in russian): here
    Download:
    SVA ROM JB 4.5 Superb XXLSC from 09-12-2012
    md5: 2adbc7cea0d5815cd750764f76506d82
    [​IMG][​IMG]
    SVA ROM JB v4.0 XXLSС Superb from 02-12-2012
    Credit to:
    Phil3759 for the Kernel and new Recovery
    ThaiDai for this stock
    Changelog:
    Based on stock Jelly Bean XXLSC (N7000XXLSC_N7000DBTLSC_N7000XXLSC)
    1. CSC - DBT Multi
    2. Kernel: PhilZ-cwm6-XXLSC 7.3
    3. Modem: XXLSC
    4. Deodexed
    5. Zipaligned
    6. Optimized
    7. SuperSU 0.98
    8. CWMManager 3.60
    9. Applications remain after a wipe data, as they now are in the / preload and not in / data
    10. In / data are only standard / data applications
    11. Framework (_SVA_ theme)
    12. Black Statusbar
    13. In Statusbar in the top right corner of the icon-added button "Lock"
    14. Battery with a percentage of the charge and the charging animation
    15. Mods with large and normal icons in the status bar
    16. Mods for stock battery and battery-bagel
    17. Semi transparent Pulldown (and notification too)
    18. In pulldown added buttons Lock and Tasks
    19. Intelligent screen rotation
    20. Removed lock mode icon (Dormant mode) in the notification and status bar
    21. Added airview fix + airview in Gallery (thx ianbbaa and Robbie!)
    22. Added modes Multi windows all apps
    23. Added mod Android 4.2 keyboard with gesture support
    24. Added mod Android 4.2 GMail
    25. Added mod SonyBravia
    26. Added mod AvespmeBEATS
    27. Added mod Disable scrolling cache
    28. Added mod Enable scrolling cache
    29. Added mod Install standart data application (hubs and so on ... )
    30. SecEmail.apk - hacked
    31. Delete the restriction on the length of the message signature for e-mail
    32. In the Phone settings, as an extension of SVA ROM, added:
    1. Cpu Spy
      Monitor Cpu
      Viewing / Changing the Country / Region Code CSC
      Switch Fast Dormancy​
      USB-mode switch
    2. Crt-off effect (works partially when the Wifi, if not on wifi works rarely)
    3. Changed theme dialer (_SVA_ theme)
    4. Dialer with russian/ latin or just latin - automatically based on the current language
    5. Built-in dialer call recording
    6. Callrecorder works fine
    7. Removed accessing ringtone
    8. When surfing the Internet and using programs with ad-advertising - advertising is blocked
    9. SMS and MMS are removed from the call log;
    10. Disabled auto convert SMS in MMS
    11. Increased the number of recipients per 1 SMS to 200
    12. Increased the send SMS to 1 MB
    13. SMS input mode is set to auto
    14. Extended menu off - 4 types
    15. Tweek GPS, DNS
    16. ...
    Stock apps that can be removed during installation ROM
    1. Accu Weather:
      • AccuweatherDaemon.apk
      • AccuweatherWidget.apk
      • AccuweatherWidget_Main.apk
    2. All share app and service
      • AllshareMediaServer.apk
      • AllshareService.apk
      • AllSharePlay.apk
    3. ChatOn app: ChatON_MARKET.apk
    4. Dropbox app and service
      • Dropbox.apk
      • DropboxOOBE.apk
    5. Addional stock fonts
      • HelvNeueLT.apk
      • RoseEUKor.apk
      • ChocoEUKor.apk
    6. Fota client and service
      • FotaClient.apk
    7. Live wallpapers and Secret Walpapers
      • SecLiveWallpapersPicker.apk
      • Aurora.apk
      • Bluesea.apk
      • OceanWeather.apk
      • PhotoWall.apk
      • Microbes.apk
      • TopicWall.apk
      • WeatherWall.apk
    8. Samsung Analog Clock widgets
      • AnalogClockSimple.apk
      • DualClockAnalog.apk
    9. Samsung Apps
      • SamsungApps.apk
      • SamsungAppsUNA3.apk
      • Samsungservice.apk
    10. Samsung sCloud Apps and service
      • CloudBackupApp.apk
      • CloudBackupProvider.apk
      • CloudDataRelay.apk
      • CloudDataSync.apk
      • CloudSyncBrowser.apk
      • CloudSyncCalendar.apk
      • CloudSyncContacts.apk
      • CloudSyncSMemo.apk
    11. SSuggest, SNS and Social hubs
      • SSuggest.apk
      • SNS.apk
      • GameHub_2.0_ICS.apk
      • MusicHub_30.apk
      • VideoHub.apk
      • MoreServices.apk
    12. Google+ app: PlusOne.apk
    13. Dialer and Favorite widget
      • DialerWidget.apk
      • SamsungWidget_FavoriteApp.apk
      • SimpleFavoritesWidget.apk
    14. Removing Web Manual: WebManual.apk
    15. Yahoo stock and news
      • YahoonewsDaemon.apk
      • YahoonewsWidget.apk
      • YahoostockDaemon.apk
      • YahoostockWidget.apk
    SVA ROM JB installation:
    1. Download the ROM to the external card
    2. Reboot into recovery and without any wipes, run the installation SVA ROM JB.
    1. In this case:
    2. If you are upgrading from another operating system (eg ICS to JB), it is recommended to do a full wipe in the selection process of installation of Rom by selecting Wipe my / data partition (in the installation script will become a wipe of all, you need to wipe).
    3. Wipe /data - recomended!, but from v3.0 you can without wipe data.
      You may try without wipe /data, but stable work not guaranteed.​
    4. Flash ROM
    5. Use ROM
    6. And ... all!
    Download
    SVA ROM JB v3.0 XXLSA Superb from 24-11-2012
    Credit to:
    Phil3759 for the Kernel and new Recovery​
    eybee1970 for this stock​
    Changelog:
    Based on stock Jelly Bean XXLSA (N7000XXLSA_N7000DBTLSA_N7000XXLSA)
    1. CSC - DBT Multi
    2. Kernel: PhilZ-cwm6-XXLSA 6.3
    3. Modem: XXLSA
    4. Deodexed
    5. Zipaligned
    6. Optimized
    7. SuperSU 0.98
    8. CWMManager 3.60
    12. Black Statusbar
    27. SecEmail.apk - hacked
    28. The restriction on the length of the message signature for e-mail
    29. In the Phone settings, as an extension of SVA ROM, added:
    30. Cpu Spy
    31. Monitor Cpu
    32. Viewing / Changing the Country / Region Code CSC
    33. Switch Fast Dormancy
    34. Crt-off effect (works partially when the Wifi, if not on wifi works rarely)
    35. Changed theme dialer (_SVA_ theme)
    36. Dialer with russian/ latin or just latin - automatically based on the current language
    37. Built-in dialer call recording
    38. Callrecorder works fine
    39. Removed accessing ringtone
    40. When surfing the Internet and using programs with ad-advertising - advertising is blocked
    41. SMS and MMS are removed from the call log;
    42. Disabled auto convert SMS in MMS
    43. Increased the number of recipients per 1 SMS to 200
    44. Increased the send SMS to 1 MB
    45. SMS input mode is set to auto
    46. Extended menu off - 4 types
    47. Tweek GPS, DNS
    48. ...
    3. In this case:
      Wipe /data - recomended! ​
    Flash ROM
    Use ROM
    And ... all!
    Download
    Please do not make any mirrors of the ROM and torrents​
    Thank you for your understanding!
    Zuletzt von einem Moderator bearbeitet: 31.12.2012
    primicx, hara74, skysat und 4 andere haben sich bedankt.
  2. bangsti, 17.06.2012 #2
    bangsti
    bangsti Threadstarter Gast
    Jetzt noch die Assassin´s Rom und alle neuen sind da.
    Danke Viper5 für deinen Einsatz.
    Rom gibt es natürlich auch schon auf galaxyrom.com bzw habe ich für die DEVs einen Mirror gemacht.
    Robby57, Reddy, Cpt. Future und eine weitere Person haben sich bedankt.
  3. lena na BMW, 17.06.2012 #3
    lena na BMW
    lena na BMW Erfahrener Benutzer
  4. Cpt. Future, 17.06.2012 #4
    Cpt. Future
    :confused2::confused2::confused2:
  5. lena na BMW, 17.06.2012 #5
    lena na BMW
  6. bangsti, 17.06.2012 #6
    bangsti
    Nicht wirklich hilfreich deine Aussage!:thumbdown:
  7. frank e., 18.06.2012 #7
    frank e.
    frank e. Android-Lexikon
    Ist schon ok lena dafür hast du schöne mods fürs Goa Rom gemacht.:thumbup:
    Besser erst testen und dann ein Urteil abgeben.
  8. lena na BMW, 18.06.2012 #8
    lena na BMW
    was soll ich den berichten wenn ich diesen rom nicht kenne..... ist doch oben schon alles gesagt
    mach doch drauf und berichte...
    mir reicht der GoA....
    Der ursprüngliche Beitrag von 23:08 Uhr wurde um 23:10 Uhr ergänzt:
    ja danke für rükmeldung....
  9. cheezusweezel, 18.06.2012 #9
    cheezusweezel
    cheezusweezel Android-Ikone
    Warum schreibst Du dann etwas zu einem Dir fremden ROM ? Nur, um nochmal GoA erwähnen zu können ? ;)
    Reddy bedankt sich.
  10. lena na BMW, 19.06.2012 #10
    lena na BMW
    damit die faulen ausprobieren... und nicht warten auf rückmeldung von anderen...
    und das ist das letzte was ich meine zu diese sache...
  11. manupot, 19.06.2012 #11
    manupot
    manupot Android-Lexikon
    Tztztztztz
    :thumbdown::thumbdown:
    Edit:
    damit es jeder versteht.
    ROM :thumbup::thumbup::thumbup:
    Aussagen und verhalten mancher user :thumbdown::thumbdown::thumbdown:
    Reddy bedankt sich.
  12. manupot, 19.06.2012 #12
    manupot
    @Fred, Gerne :D
    Eines muss ich noch loswerden.
    Ein Feedback ist doch nicht nur für user die neugierig auf die/das Rom sind. Sondern auch für den Entwickler der Rom. Je mehr Feedback er bekommt desto schneller kann er eventuelle Fehler finden und versuchen diese zu beheben.
    Also ich finde die Rom "sehr gut", bleibe jedoch bei meinem Liebling und das ist cm9 (so, das es jetzt auch dieser weiß )
    In diesem sinne flasht die/das Rom doch einmal denn jede Rom hat ihren eigenen reiz.
    Testen schadet doch nicht!
    Für den einen ist die beste halt goa und für den anderen rr v6 und und und.........
    Das muss eh jeder für sich selbst entscheiden.
    So jetzt ich haben auch fertig.
    Schönen Fußball Abend noch! :p
    Cpt. Future, lena na BMW und Reddy haben sich bedankt.
  13. lena na BMW, 19.06.2012 #13
    lena na BMW
    auf jeden fall nicht dich.... kenn schon solchene user
  14. Reddy, 19.06.2012 #14
    Reddy
    Reddy Moderator Team-Mitglied
    Ich bin dann mal so frei und trau mich den Flash dieses ROM's :)
    full - Wipe mit Sicherheits-Kernel
    dann installation des ROM's
    ... komischer Weise hat es sich danach gleich selbst gebootet ...
    aber es hat. CSC war SEB ... hab ich gleich in DBT geändert .. noch ne full Wipe :)
    Root-Rechte habe ich.
    Mir ist sofort die Geschwindigkeit aufgefallen. Extrem schnell.
    Jetzt mach ich mit TB mal meine App's drauf und berichte dann wie es läuft ;)
    lena na BMW und manupot haben sich bedankt.
  15. bangsti, 19.06.2012 #15
    bangsti
    Ich bin gerade am uploaden für ALBA aber sobald ich fertig bin wird es auch von mir einen Mirror geben.
    @Reddy
    Du Allesflasher. Danke dir fürs testen und liebe von Gabi und natürlich mir.
    @manupot
    Von der CM9 Sucht kommt man einfach nicht los. Ist meine Daily Rom.
    In eigener Sache.
    Wegen Serverumzug kann es in den nächsten Tage zu Downloadproblemen kommen auf GalaxyRom. Habt bitte Verständnis.
    Robby57, frank e., Reddy und eine weitere Person haben sich bedankt.
  16. Reddy, 19.06.2012 #16
    Reddy
    Danke für die lieben Grüße:thumbup::thumbup::thumbup:
    Gern zurück!! An Gabi und Dich und wer noch mag :thumbsup:
    Zur Rom ....
    Wer eine soliede gut laufende, sorry schnell laufende ICS Rom will,
    ist hier gut bedient.
    Es ist alles drin was man braucht ... und was zuviel kann ja mit TB gelöscht werden.
    Für die Optik ist auch hier jeder User sein eigener Künstler :wubwub:
    Den CF Kernel werd ich sicher durch den Goku Kernel auswechseln.
    WLan auf Anhieb ... auch sonst keine Probleme am Anfang.
    :thumbup:
    Ps, die Schriftgröße iss auf Oldy Red gestellt ;)
    frank e. bedankt sich.
  17. bangsti, 19.06.2012 #17
    bangsti
    Man so blöd bin ich schon.
    Habe für diese Rom ja bereits einen Mirror gemacht und ich Trottel habe die Rom jetzt nochmals runtergeladen.
    Ich brauch Urlaub!!!!!!
    SVA ICS ROM V5.1
    Reddy bedankt sich.
  18. Reddy, 19.06.2012 #18
    Reddy
    Tasse Kaffe geht auch!!!!
    Ich hab gerade noch Kernel-Wechsel gemacht ... besser iss :thumbup:
  19. bangsti, 19.06.2012 #19
    bangsti
    Gute Idee werd ich machen.
    Reddy bedankt sich.
  20. Starwalker, 19.06.2012 #20
    Starwalker
    Starwalker Android-Lexikon
    @Reddy
    Wie würdest Du die Performance des Roms im Vergleich zum Rocket v6 (das Du ja auch genutzt hast) beurteilen, welches für mich bisher den Maßstab für flüssige Performance darstellt?
    Danke und viele Grüße
    Lars
Status des Themas:
  1. jb.v5
  2. SVA ROM GT-N7102 v5 скачать
